Much appreciate the contributions made here and progress to date.
Because there are usual snippets of information scattered/dispersed all over the forum, would it not be a good idea to have a checklist/cookboot here in PDF format to help the uniniated?
PS I received my board yesterday.
The up-and-running thread, VisionFive 2 up and running instructions, has several good checklists. Problem is that it’s quite a moving target so the instructions change over time, I tried to collect all the latest stuff in my post towards the end which is known to work, well, as of a few hours ago.
The URL to the article (which could be translated to any language by most web browsers) can be found at:
The pdf file because its contents were generated from a website, also tries to connect to all the websites anyhow, so it is not like the pdf file is helping you avoid any tracking and monitoring that would typically be blocked with browser plugins (noscript, ABP AdblockPlus, Privacy Badger,…etc.).
As of now you dont need to flash firmware with the UART Dongle. It is not needed anymore.
You can do it much easier with the sdcard.img on the github repo.
This will boot and get a DHCP Adress then log in and patch the firmware.
Then you can reflash the sdcard with the 69er image.
It will then boot. IP will stay the same.
There are inscrutions in the other thread mentioned here.
After the successful firmware flash, flash the debian69 image onto the SDcard and boot it up. You can download the image from the Google drive. It will be zipped with bz2 you need to extract it first! Then flash.
you should have hdmi output.
To better help you please indicate in what step you need assictance with.
