SUCCESS
I repeated the “Recovering the Bootloader” procedure from QSG with u-boot-spl.bin.normal.out and visionfive2_fw_payload.img both from release 2.5
and now I’m able to boot into latest debian and login as user.
Fun fact, I flashed the 2.5 image to a microSD also and, for strange it may seem, It didn’t really go as expected and I couldn’t log in, for the curious here’s the (last part of) boot log (post was too long):
Starting kernel ...
[ 0.000000] Linux version 5.15.0 (jenkins@soft05) (riscv64-buildroot-linux-gnu-gcc.br_real (Buildroot VF2_v2.5.0) 10.3.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Sun Dec 25 20:59:22 CST 2022
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[ 0.000000] printk: bootconsole [sbi0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000023fffffff]
[ 0.000000] SBI specification v0.3 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10000
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: ISA extensions acdfim
[ 0.000000] percpu: Embedded 17 pages/cpu s31528 r8192 d29912 u69632
[ 0.000000] pcpu-alloc: s31528 r8192 d29912 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 debug rootwait earlycon=sbi root=/dev/mmcblk1p4
[ 0.000000] Unknown command line parameters: earlyprintk
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 7468836K/8386560K available (9878K kernel code, 4982K rwdata, 4096K rodata, 2191K init, 401K bss, 393436K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] random: get_random_bytes called from start_kernel+0x4d0/0x6e2 with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.008246] clocksource: timer@13050000.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.018469] clocksource: timer@13050000.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.028792] clocksource: timer@13050000.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.039098] clocksource: timer@13050000.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.049572] Console: colour dummy device 80x25
[ 0.053981] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=40000)
[ 0.064175] pid_max: default: 32768 minimum: 301
[ 0.069092] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.076762] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.086138] ASID allocator disabled
[ 0.089659] rcu: Hierarchical SRCU implementation.
[ 0.094578] EFI services will not be available.
[ 0.099418] smp: Bringing up secondary CPUs ...
[ 0.105514] smp: Brought up 1 node, 4 CPUs
[ 0.111424] devtmpfs: initialized
[ 0.122025] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.131811] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.152430] pinctrl core: initialized pinctrl subsystem
[ 0.158466] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.164992] cpuidle: using governor menu
[ 0.190469] platform soc:dsi-output: Fixing up cyclic dependency with 29400000.dc8200
[ 0.198770] platform 295d0000.mipi: Fixing up cyclic dependency with soc:dsi-output
[ 0.206752] platform 29590000.hdmi: Fixing up cyclic dependency with 29400000.dc8200
[ 0.226320] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.232947] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.242888] vgaarb: loaded
[ 0.245755] SCSI subsystem initialized
[ 0.249569] libata version 3.00 loaded.
[ 0.253520] usbcore: registered new interface driver usbfs
[ 0.258962] usbcore: registered new interface driver hub
[ 0.264414] usbcore: registered new device driver usb
[ 0.269698] mc: Linux media interface: v0.10
[ 0.273906] videodev: Linux video capture interface: v2.00
[ 0.279627] Advanced Linux Sound Architecture Driver Initialized.
[ 0.286018] Bluetooth: Core ver 2.22
[ 0.289550] NET: Registered PF_BLUETOOTH protocol family
[ 0.294884] Bluetooth: HCI device and connection manager initialized
[ 0.301313] Bluetooth: HCI socket layer initialized
[ 0.306242] Bluetooth: L2CAP socket layer initialized
[ 0.311373] Bluetooth: SCO socket layer initialized
[ 0.316581] clocksource: Switched to clocksource riscv_clocksource
[ 0.329829] NET: Registered PF_INET protocol family
[ 0.335854] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.351082] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 0.359877] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.368553] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.378318] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.385065] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.392216] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.400063] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.406312] RPC: Registered named UNIX socket transport module.
[ 0.412176] RPC: Registered udp transport module.
[ 0.416934] RPC: Registered tcp transport module.
[ 0.421692] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.428908] PCI: CLS 0 bytes, default 64
[ 0.433391] Initialise system trusted keyrings
[ 0.436937] Unpacking initramfs...
[ 0.437926] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[ 0.453686] NFS: Registering the id_resolver key type
[ 0.458707] Key type id_resolver registered
[ 0.462910] Key type id_legacy registered
[ 0.467094] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.473744] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.481272] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.485873] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.492369] fuse: init (API version 7.34)
[ 0.535126] NET: Registered PF_ALG protocol family
[ 0.539892] Key type asymmetric registered
[ 0.544015] Asymmetric key parser 'x509' registered
[ 0.549068] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.556409] io scheduler mq-deadline registered
[ 0.561027] io scheduler kyber registered
[ 0.565994] start plist test
[ 0.573354] end plist test
[ 0.671362] clk-starfive-jh7110 13020000.clock-controller: starfive JH7110 clkgen init successfully.
[ 0.681586] L2CACHE: DataError @ 0x00000000.08040140
[ 0.686534] L2CACHE: DataFail @ 0x00000000.0804006C
[ 0.691530] L2CACHE: No. of Banks in the cache: 8
[ 0.696190] L2CACHE: No. of ways per bank: 16
[ 0.700627] L2CACHE: Sets per bank: 256
[ 0.704509] L2CACHE: Bytes per cache block: 64
[ 0.709031] L2CACHE: Index of the largest way enabled: 15
[ 0.714791] jh7110-pmu 17030000.power-controller: registered 8 power domains
[ 0.782561] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.791699] @@#########################@@
[ 0.833871] @@ dev ptr:ffffffe0bff00000/1500/1
[ 0.838511] PVR_K: 1: Read BVNC 36.50.54.182 from HW device registers
[ 0.845038] PVR_K: 1: RGX Device registered BVNC 36.50.54.182 with 1 core in the system
[ 0.854402] [drm] Initialized pvr 1.17.6210866 20170530 for 18000000.gpu on minor 0
[ 0.871601] loop: module loaded
[ 0.877142] spi-nor spi0.0: gd25lq128d (16384 Kbytes)
[ 6.213317] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 6.387623] Freeing initrd memory: 122788K
[ 6.403208] 3 fixed-partitions partitions found on MTD device 13010000.spi.0
[ 6.410233] Creating 3 MTD partitions on "13010000.spi.0":
[ 6.415750] 0x000000000000-0x000000020000 : "spl"
[ 6.422334] 0x000000100000-0x000000400000 : "uboot"
[ 6.428753] 0x000000f00000-0x000001000000 : "data"
[ 6.436126] libphy: Fixed MDIO Bus: probed
[ 6.441667] CAN device driver interface
[ 6.446010] starfive-eth-plat 16030000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 6.456337] starfive-eth-plat 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 6.463764] starfive-eth-plat 16030000.ethernet: DWMAC4/5
[ 6.469304] starfive-eth-plat 16030000.ethernet: DMA HW capability register supported
[ 6.477187] starfive-eth-plat 16030000.ethernet: RX Checksum Offload Engine supported
[ 6.485062] starfive-eth-plat 16030000.ethernet: Wake-Up On Lan supported
[ 6.491921] starfive-eth-plat 16030000.ethernet: TSO supported
[ 6.497813] starfive-eth-plat 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 6.506210] starfive-eth-plat 16030000.ethernet: Enabled Flow TC (entries=1)
[ 6.513328] starfive-eth-plat 16030000.ethernet: TSO feature enabled
[ 6.519740] starfive-eth-plat 16030000.ethernet: Using 40 bits DMA width
[ 6.768950] libphy: stmmac: probed
[ 6.772291] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 6.782284] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 6.793435] starfive-eth-plat 16040000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 6.803751] starfive-eth-plat 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 6.811182] starfive-eth-plat 16040000.ethernet: DWMAC4/5
[ 6.816719] starfive-eth-plat 16040000.ethernet: DMA HW capability register supported
[ 6.824590] starfive-eth-plat 16040000.ethernet: RX Checksum Offload Engine supported
[ 6.832489] starfive-eth-plat 16040000.ethernet: Wake-Up On Lan supported
[ 6.839336] starfive-eth-plat 16040000.ethernet: TSO supported
[ 6.845216] starfive-eth-plat 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 6.853642] starfive-eth-plat 16040000.ethernet: Enabled Flow TC (entries=1)
[ 6.860745] starfive-eth-plat 16040000.ethernet: TSO feature enabled
[ 6.867157] starfive-eth-plat 16040000.ethernet: Using 40 bits DMA width
[ 7.115052] libphy: stmmac: probed
[ 7.118420] YT8512B Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 7.127762] YT8512B Ethernet stmmac-1:03: attached PHY driver (mii_bus:phy_addr=stmmac-1:03, irq=POLL)
[ 7.138621] Intel(R) Wireless WiFi driver for Linux
[ 7.145325] cdns3-starfive 10210000.usbdrd: usb mode 2 2.0 probe success
[ 7.152745] usbcore: registered new interface driver uas
[ 7.158058] usbcore: registered new interface driver usb-storage
[ 7.176911] starfive-rtc 17040000.rtc: registered as rtc0
[ 7.182247] starfive-rtc 17040000.rtc: setting system clock to 2001-01-01T00:00:00 UTC (978307200)
[ 7.191405] i2c_dev: i2c /dev entries driver
[ 7.195848] usbcore: registered new interface driver uvcvideo
[ 7.202698] starfive-wdt 13070000.wdog: Heartbeat: timeout=15, count/2=180000000 (0aba9500)
[ 7.211511] Bluetooth: HCI UART driver ver 2.3
[ 7.215886] Bluetooth: HCI UART protocol H4 registered
[ 7.221317] starfive-cpufreq soc:starfive,jh7110-cpufreq: Failed to get regulator for cpu!
[ 7.229536] starfive-cpufreq soc:starfive,jh7110-cpufreq: Failed to init starfive cpu dvfs info
[ 7.238815] sdhci: Secure Digital Host Controller Interface driver
[ 7.244929] sdhci: Copyright(c) Pierre Ossman
[ 7.249397] Synopsys Designware Multimedia Card Interface Driver
[ 7.255721] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.262116] jh7110-sec 16000000.crypto: Unable to request sec_m dma channel in DMA channel
[ 7.270336] jh7110-sec 16000000.crypto: Cannot initial dma chan
[ 7.276608] usbcore: registered new interface driver usbhid
[ 7.282112] usbhid: USB HID core driver
[ 7.286256] usbcore: registered new interface driver snd-usb-audio
[ 7.300156] NET: Registered PF_PACKET protocol family
[ 7.305157] can: controller area network core
[ 7.309696] NET: Registered PF_CAN protocol family
[ 7.314421] can: raw protocol
[ 7.317472] can: broadcast manager protocol
[ 7.321706] can: netlink gateway - max_hops=1
[ 7.326465] Bluetooth: RFCOMM TTY layer initialized
[ 7.331324] Bluetooth: RFCOMM socket layer initialized
[ 7.336498] Bluetooth: RFCOMM ver 1.11
[ 7.340342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.345662] Bluetooth: BNEP filters: protocol multicast
[ 7.350972] Bluetooth: BNEP socket layer initialized
[ 7.356181] 9pnet: Installing 9P2000 support
[ 7.360463] Key type dns_resolver registered
[ 7.365475] Loading compiled-in X.509 certificates
[ 7.406175] starfive_jh7110-pinctrl 13040000.gpio: SiFive GPIO chip registered 64 GPIOs
[ 7.414915] starfive_jh7110-pinctrl 17020000.gpio: SiFive GPIO chip registered 4 GPIOs
[ 7.423004] pl08xdmac 16008000.sec_dma: initialized 8 virtual memcpy channels
[ 7.430104] pl08xdmac 16008000.sec_dma: initialized 16 virtual slave channels
[ 7.438960] debugfs: Directory '16008000.sec_dma' with parent 'dmaengine' already present!
[ 7.447203] pl08xdmac 16008000.sec_dma: DMA: PL080 rev0 at 0x16008000 irq 23
[ 7.454531] ssp-pl022 10060000.spi: ARM PL022 driver for StarFive SoC platform, device ID: 0x00041022
[ 7.463715] ssp-pl022 10060000.spi: mapped registers from 0x0000000010060000 to (____ptrval____)
[ 7.472998] ssp-pl022 10060000.spi: Requested frequency: 10000000 Hz is unsupported,select by default 8250000 Hz
[ 7.483507] ssp-pl022 10060000.spi: will use autosuspend for runtime pm, delay 100ms
[ 7.492552] i2c 2-0045: Fixing up cyclic dependency with 295d0000.mipi
[ 7.499303] seeed_panel 2-0045: Unknown Atmel firmware revision: 0x00
[ 7.505870] i2c 2-0019: Fixing up cyclic dependency with 295d0000.mipi
[ 7.513767] at24 5-0050: supply vcc not found, using dummy regulator
[ 7.520886] at24 5-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 7.529441] axp15060-regulator 5-0036: Register mipi_0p9 done! vol range:900 ~ 900 mV
[ 7.538711] axp15060-regulator 5-0036: Register hdmi_1p8 done! vol range:1800 ~ 1800 mV
[ 7.548153] axp15060-regulator 5-0036: Register hdmi_0p9 done! vol range:900 ~ 900 mV
[ 7.557436] axp15060-regulator 5-0036: Register cpu_vdd done! vol range:500 ~ 1540 mV
[ 7.565969] i2c 6-0010: Fixing up cyclic dependency with 19800000.vin_sysctl
[ 7.573370] imx219 6-0010: supply VANA not found, using dummy regulator
[ 7.580067] imx219 6-0010: supply VDIG not found, using dummy regulator
[ 7.586688] imx219 6-0010: supply VDDL not found, using dummy regulator
[ 7.600772] imx219 6-0010: failed to read chip id 219
[ 7.605963] imx219: probe of 6-0010 failed with error -5
[ 7.613776] pcie_plda 2b000000.pcie: host bridge /soc/pcie@2B000000 ranges:
[ 7.620753] pcie_plda 2b000000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 7.628868] pcie_plda 2b000000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000
[ 7.637041] ATR entry: 0x0940000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 7.644776] ATR entry: 0x0030000000 -> 0x0030000000 [0x0008000000] (param: 0x000000)
[ 7.652592] ATR entry: 0x0900000000 -> 0x0900000000 [0x0040000000] (param: 0x000000)
[ 8.006677] pcie_plda 2b000000.pcie: Port link up.
[ 8.011555] pcie_plda 2b000000.pcie: PCI host bridge to bus 0000:00
[ 8.017773] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 8.023296] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff]
[ 8.030248] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref]
[ 8.037812] pci 0000:00:00.0: [1556:1111] type 01 class 0x060400
[ 8.043847] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xffffffff 64bit pref]
[ 8.051184] pci 0000:00:00.0: supports D1 D2
[ 8.055449] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.065614] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.073702] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 8.079665] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 8.086564] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 8.095414] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 8.102020] pci 0000:00:00.0: BAR 0: no space for [mem size 0x100000000 64bit pref]
[ 8.109694] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x100000000 64bit pref]
[ 8.117753] pci 0000:00:00.0: BAR 8: assigned [mem 0x30000000-0x300fffff]
[ 8.124585] pci 0000:01:00.0: BAR 0: assigned [mem 0x30000000-0x30000fff 64bit]
[ 8.131976] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 8.136991] pci 0000:00:00.0: bridge window [mem 0x30000000-0x300fffff]
[ 8.143924] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 8.149574] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.155321] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x9d4 took 11139 usecs
[ 8.162935] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 8.168121] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 8.175982] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000040000000890
[ 8.185122] pcie_plda 2b000000.pcie: msi#0 address_hi 0x0 address_lo 0x190
[ 8.192361] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 8.197547] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 8.204975] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 8.212037] hub 1-0:1.0: USB hub found
[ 8.215745] hub 1-0:1.0: 1 port detected
[ 8.220764] hub 2-0:1.0: USB hub found
[ 8.224473] hub 2-0:1.0: 4 ports detected
[ 8.231296] pcie_plda 2c000000.pcie: host bridge /soc/pcie@2C000000 ranges:
[ 8.238254] pcie_plda 2c000000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 8.246362] pcie_plda 2c000000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000
[ 8.254562] ATR entry: 0x09c0000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 8.262319] ATR entry: 0x0038000000 -> 0x0038000000 [0x0008000000] (param: 0x000000)
[ 8.270110] ATR entry: 0x0980000000 -> 0x0980000000 [0x0040000000] (param: 0x000000)
[ 8.436627] usb usb2-port2: over-current condition
[ 8.536634] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 8.596659] usb usb2-port4: over-current condition
[ 8.706847] pcie_plda 2c000000.pcie: Port link down, exit.
[ 8.725998] clk-starfive-jh7110-vout 295c0000.clock-controller: starfive JH7110 clk_vout init successfully.
[ 8.747368] clk-starfive-jh7110-isp 19810000.clock-controller: starfive JH7110 clk_isp init successfully.
[ 8.747836] hub 1-1:1.0: USB hub found
[ 8.757515] dw_axi_dmac_platform 16050000.dma-controller: DesignWare AXI DMA Controller, 4 channels
[ 8.761091] hub 1-1:1.0: 4 ports detected
[ 8.770818] printk: console [ttyS0] disabled
[ 8.807421] printk: console [ttyS0] enabled0x10000000 (irq = 17, base_baud = 1500000) is a 16550A
[ 8.815704] printk: bootconsole [sbi0] disabled
[ 8.825322] jh7110-vin 19800000.vin_sysctl: stfcamss probe enter!
[ 8.833416] jh7110-vin 19800000.vin_sysctl: stfcamss probe success!
[ 8.842160] dwmmc_starfive 16010000.sdio0: IDMAC supports 32-bit address mode.
[ 8.842628] dwmmc_starfive 16020000.sdio1: IDMAC supports 32-bit address mode.
[ 8.849477] dwmmc_starfive 16010000.sdio0: Using internal DMA controller.
[ 8.856711] dwmmc_starfive 16020000.sdio1: Using internal DMA controller.
[ 8.863472] dwmmc_starfive 16010000.sdio0: Version ID is 290a
[ 8.870274] dwmmc_starfive 16020000.sdio1: Version ID is 290a
[ 8.876046] dwmmc_starfive 16010000.sdio0: DW MMC controller at irq 29,32 bit host data width,32 deep fifo
[ 8.881803] dwmmc_starfive 16020000.sdio1: DW MMC controller at irq 30,32 bit host data width,32 deep fifo
[ 8.891553] mmc_host mmc0: card is non-removable.
[ 8.901264] mmc_host mmc1: card is polling.
[ 8.906175] jh7110-sec 16000000.crypto: will run requests pump with realtime priority
[ 8.919718] jh7110-sec 16000000.crypto: Initialized
[ 8.925241] starfive-i2s 120b0000.i2stx_4ch0: designware: play supported
[ 8.932045] starfive-i2s 120b0000.i2stx_4ch0: designware: i2s master mode supported
[ 8.939807] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe begin
[ 8.946077] sf-mipi-dphy-tx 295e0000.mipi-dphy: ===> sf_dphy_probe enter, 445
[ 8.953374] sf-mipi-dphy-tx 295e0000.mipi-dphy: control ECO
[ 8.958967] sf-mipi-dphy-tx 295e0000.mipi-dphy: supply mipi_1p8 not found, using dummy regulator
[ 8.967920] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe end
[ 8.974106] cdns-dsi 295d0000.mipi: dsi_sys_clk = 297000000
[ 8.979847] cdns-dsi 295d0000.mipi: starfive dsi bind end
[ 8.986465] of_cfs_init
[ 8.988991] of_cfs_init: OK
[ 8.992103] starfive-pwmdac 100b0000.pwmdac: clk_apb0 = 49500000, clk_pwmdac_apb = 49500000, clk_pwmdac_core = 4068493
[ 9.003081] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.117701] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.126634] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 9.128345] starfive soc:display-subsystem: bound 29400000.dc8200 (ops 0xffffffff80e75b38)
[ 9.136629] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 9.144635] innohdmi-starfive 29590000.hdmi: inno hdmi bind begin
[ 9.161428] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 9.170134] cfg80211: failed to load regulatory.db
[ 9.175971] innohdmi-starfive 29590000.hdmi: [drm:inno_hdmi_bind] registered Inno HDMI I2C bus driver success
[ 9.186185] innohdmi-starfive 29590000.hdmi: HDMI&AUDIO register done.
[ 9.192800] innohdmi-starfive 29590000.hdmi: inno hdmi bind end
[ 9.198754] starfive soc:display-subsystem: bound 29590000.hdmi (ops 0xffffffff80e768e8)
[ 9.206874] vs-simple-encoder soc:dsi-output: encoder_bind begin
[ 9.212923] no panel, -517
[ 9.215638] vs-simple-encoder soc:dsi-output: encoder_bind error
[ 9.221673] starfive soc:display-subsystem: bound soc:dsi-output (ops 0xffffffff80e76530)
[ 9.230317] [drm] Initialized starfive 1.0.0 20191101 for soc:display-subsystem on minor 1
[ 9.366818] random: fast init done
[ 9.394589] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 50000000Hz, actual 49500000HZ div = 2)
[ 9.404657] mmc1: new high speed SDHC card at address 0007
[ 9.412001] mmcblk1: mmc1:0007 SD04G 3.71 GiB
[ 9.427155] mmcblk1: p1 p2 p3 p4
[ 9.576695] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 300000Hz, actual 300000HZ div = 330)
[ 10.016714] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000Hz, actual 200000HZ div = 495)
[ 10.466690] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 100000Hz, actual 100000HZ div = 990)
[ 11.296664] ALSA device list:
[ 11.299660] #0: Starfive-PWMDAC-Sound-Card
[ 11.303960] #1: Starfive-HDMI-Sound-Card
[ 11.313279] Freeing unused kernel image (initmem) memory: 2188K
[ 11.319528] Run /init as init process
[ 11.323216] with arguments:
[ 11.326201] /init
[ 11.328529] earlyprintk
[ 11.331345] with environment:
[ 11.334508] HOME=/
[ 11.336917] TERM=linux
find /dev/mmcblk1p4: 0
[ 12.957388] EXT4-fs (mmcblk1p4): recovery complete
[ 12.966854] EXT4-fs (mmcblk1p4): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
mount: /rootfs/dev/shm: special device /dev/shm does not exist.
mount: /rootfs/dev/pts: special device /dev/pts does not exist.
INIT: version booting
INIT: No inittab.d directory found
[ 13.527809] EXT4-fs (mmcblk1p4): re-mounted. Opts: (null). Quota mode: disabled.
INIT: Entering runlevel: 3
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [ 13.989691] udevd[220]: starting version 3.2.10
[ 14.007607] random: udevd: uninitialized urandom read (16 bytes read)
[ 14.015586] random: udevd: uninitialized urandom read (16 bytes read)
[ 14.022172] random: udevd: uninitialized urandom read (16 bytes read)
[ 14.054772] udevd[221]: starting eudev-3.2.10
[ 14.163853] jpu: loading out-of-tree module taints kernel.
[ 14.166450] vdec: loading out-of-tree module taints kernel.
[ 14.172150] cnm_jpu 13090000.jpu: init device.
[ 14.177329] SUCCESS alloc_chrdev_region
[ 14.181653] vdec 130a0000.vpu_dec: device init.
[ 14.187857] SUCCESS alloc_chrdev_region
done
Initializing random number generator: OK
Saving random seed: OK
Starting system message bus: dbus[266]: Unknown username "pulse" in message bus configuration file
done
Starting rpcbind: OK
Starting iptables: OK
Starting bluetoothd: OK
Starting network: OK
Starting Network Interface Plugging Daemon: eth0[ 14.765459] starfive-eth-plat 16030000.ethernet eth0: PHY [stmmac-0:00] driver [YT8531 Gigabit Ethernet] (irq=POLL)
eth1.
[ 14.777105] starfive-eth-plat 16030000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
Starting dropbear sshd: [ 14.795556] dwmac4: Master AXI performs fixed burst length
[ 14.801081] starfive-eth-plat 16030000.ethernet eth0: No Safety Features support found
[ 14.809036] starfive-eth-plat 16030000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 14.818284] starfive-eth-plat 16030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 14.829053] starfive-eth-plat 16040000.ethernet eth1: PHY [stmmac-1:00] driver [YT8512B Ethernet] (irq=POLL)
[ 14.839224] starfive-eth-plat 16040000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 14.847740] dwmac4: Master AXI performs fixed burst length
[ 14.853254] starfive-eth-plat 16040000.ethernet eth1: No Safety Features support found
[ 14.861217] starfive-eth-plat 16040000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 14.871786] starfive-eth-plat 16040000.ethernet eth1: configuring for phy/rgmii-id link mode
OK
Starting NFS statd: OK
Starting NFS services: OK
Starting NFS daemon: rpc.nfsd: Unable to access /proc/fs/nfsd errno 2 (No such file or directory).
Please try, as root, 'mount -t nfsd nfsd /proc/fs/nfsd' and then restart rpc.nfsd to correct the problem
FAIL
Starting NFS mountd: rpc.mountd: svc_tli_create: could not open connection for udp6
rpc.mountd: svc_tli_create: could not open connection for tcp6
OK
Starting isp_ctrl_daemon.sh: OK
Starting DHCP server: FAIL
Welcome to Buildroot
buildroot login:
Trying to recap my understanding: the “kickstarter” unit was released earlier and it has QSPI NOR FLASH partitioned in the wrong way (and possibly a different hardware revision? how can I check that?) and, ideally I should update its formatting through the procedure 1> linked by mzs which I’ll dig next.
And then there are the other possibilities in 2> and 3> which I admit don’t really understand due to a general lack of information (aka ignorance) in the field of embedded linux in general and on this system in particular (one should start learing somewhere), pointers on how tackle my ignorance are welcome.
Thank you both, guys!
