Does the VisionFive2 have support for the H (Hypervisor) extension?
And if it does support the H extension, any tricks to get KVM to work on kernel 5.15?
No, it does not. The U74 is RV64GFC due to the data sheet. This means you cannot run a hypervisor, but nevertheless containers.
Itās JH7110, not JH7100, but sure itās the same core. The G implies F, but it has B, so maybe you meant RV64GCB?
not all B are in this core though, just zba and zbb
Hmm, the specs have CSR āmisaā which spells all the extensions. But unfortunately, this is on machine level. I wonder if this can be accessed some way.
It is a privileged operation, that can only be read in machine mode. Looking at the boot up sequence:
ZSBL ROM (Machine mode)
SPL+U-Boot (Machine mode)
U-Boot+OpenSBI(Machine mode ā Supervisor mode)
Linux kernel (Supervisor mode)
Linux services/applications (User mode)
There exists a function in Das U-Boot to read any RISC-V CSR:
So I wonder would the simplest way be to add a new U-Boot riscv command (possibly just called ācsrā) that can read any CSR, including the MISA (0x301), and just prints hex values or expands it with the information contained in the āMachine-Level CSRsā section of the RISC-V ISA Privileged Specification (riscv-privileged.pdf) to display a more human readable format.
That has long been essentially deprecated as it canāt cover the full gamut of extensions. The device tree is where you are supposed to specify this.
This conversation is a little off in the weeds, but doesnāt /proc/cpuinfo give you the full alphabet soup of extensions?
To the original question, this core definitely predates āHā. I donāt think SiFive does H until 650.
The gap between specifications being ratified and being able to get them in a real chip on a real board is pretty long. JH-7110 is the first really high-volume, low-cost version of the U7 family which was announced in 2018 or so. Also, Hypervisor was a particularly contentious extension; it wasnāt frozen until December of '21.
No, /proc/cpuinfo doesnāt show zba zbb.
What are all the RISC-V extensions, and versions, in the JH7110 SoC ?
U74-MC:
4x U74:
RV64IMAFDC_Zicsr_Zifencei_Zba_Zbb_Sscofpmf
or
rv64imafdczbb0p93_zba0p93_zicsr_zifencei_sscofpmf
1xS7:
RV64IMAC_Zicsr_Zifencei_Zba_Zbb_Sscofpmf
or
rv64imaczbb0p93_zba0p93_zicsr_zifencei_sscofpmf
1xE24:
RV32IMFC_???
Ah, yes, thatās familiar now. That seems to be regarded as an unimplemented feature the official kernel is sure to do Someday. Itās come and gone a few times in various branches, it seems.
Relevant (to this, not the OP) discussion:
But this would mean, the device tree has glitches in jh7110.dtsi:
cpu0: cpu@0 {
compatible = "sifive,u74-mc", "riscv";
riscv,isa = "rv64imac"; // << fd? extensions?
cpu1: cpu@1 {
riscv,isa = "rv64imafdc"; // << extensions?
U74-MC consists of:
cpu0 a S7 RV64IMAC
cpu1 a U74 RV64IMAFDC
cpu2 a U74 RV64IMAFDC
cpu3 a U74 RV64IMAFDC
cpu4 a U74 RV64IMAFDC
EDIT: The JH7110 has (S7->S76):
cpu0 a S76 RV64IMAFDC ???!!! instead of RV64IMAC ???!?!?!?
And accessed from the U74MC4+U76 across frontport0 axi4 @ 128bit 750MHz bus is a E24 RV32IMFC.
starfive:/home # uname -a
Linux starfive.lan 6.3.0-rc4-26-default #1 SMP Sun Mar 26 22:01:16 UTC 2023 (f77c350) riscv64 riscv64 riscv64 GNU/Linux
starfive:/home # cat /proc/cpuinfo
processor : 0
hart : 1
isa : rv64imafdc_zbb
mmu : sv39
uarch : sifive,u74-mc
mvendorid : 0x489
marchid : 0x8000000000000007
mimpid : 0x4210427
processor : 1
hart : 2
mmu : sv39
mvendorid : 0x489
mimpid : 0x4210427
processor : 2
hart : 3
mmu : sv39
mvendorid : 0x489
mimpid : 0x4210427
processor : 3
hart : 4
mmu : sv39
mvendorid : 0x489
mimpid : 0x4210427
starfive:/home # dmesg | grep kvm
[ 182.600501] kvm [1718]: hypervisor extension not available
No zba, Just zbb? Or that means just zbb that is [currently] enabled in kernel 6.3?
Is this stock (ie. Linusā upstream tree) or did you apply additional patches?
I really need this for perf, but the biggest problem is that OpenSBI needs the PMU entries in the device tree it sees (which isnāt the same that Linux gets alas)
I would have expected a kernel to report back exactly whatever it was told to report back from the dts files (regardless if it is accurate or wrong).
For the visionfive2_upstream kernel I would have expected rv64imac_zba_zbb for the S7 hart (which might be a S76 hart) and rv64imafdc_zba_zbb for the 4 U74 hartās.
And in the U-boot upstream patch it has rv64imacu for the S76(cpu@0) and rv64imafdcbsu for the U74 harts (cpu@1,cpu@2,cpu@3,cpu@4) all of which are part of the u74-mc.
Iām now wondering is it a cut S76 core with no floating point , i.e. with less features than a baseline S76 core (rv64imafdc_zba_zbb), with support for single and double precision floating point removed and bit Manipulation it would become rv64imac. A S76 core only has machine mode and by default a user mode, it has no supervisor mode, so it is different than the U74 cores anyhow.
I do not know if it is possible, but what would be fantastic is if the exact same features were listed in all the dts files for each of the six cores in the JH7110 SoC E24,U74-mc(S76+4xU74)
@mzs; Unfortunately I dont think we should expect anything more than a stock S7. ![]()
from this:
[v6,00/21] Basic clock, reset & device tree support for StarFive JH7110 RISC-V SoC - Patchwork
[Device tree]
Patch 6:
- Changed the label "S76_0" to "S7_0" and used compatible "sifive,s7"
for core 0.
- Updated ISA of each cores. (by Conor)
Also note these patches from Starfive; they do not refer to it as a S76
[v6,18/21] dt-bindings: riscv: Add SiFive S7 compatible - Patchwork
[v6,19/21] riscv: dts: starfive: Add initial StarFive JH7110 device tree - Patchwork
An S76 is technically a S7-series RISC-V core, just like a U74 is technically a U7-series core. And I see S76 mentioned in more and more places with regard to the U74-mc.
Travelling all the way back in time to 2018-08-22, there was no option to license a S7 Core from SiFive, but there was a S7 Series S76 Core.
So I do still think that it is really an S76 core, without any form of floating point support (FD), without support for Bit Manipulation specifically not Zba and not Zbb (B), with a smaller cache L1 I-Cache, with a smaller Data TIM instead of a Data cache and without a Instruction TIM (basically remove everything so that much less space on the silicon die, and less power, is required). And unlike the U74 (Machine,Supervisor,User mode) it does not have a Supervisory mode just like a S76 Core.
EDIT:
I found CSR MISA information about the 5 hartās here:
Info : hart 0: XLEN=64, misa=0x8000000000901107
Info : hart 1: XLEN=64, misa=0x800000000094112f
Info : hart 2: XLEN=64, misa=0x800000000094112f
Info : hart 3: XLEN=64, misa=0x800000000094112f
Info : hart 4: XLEN=64, misa=0x800000000094112f
Converting to binary and consulting the āEncoding of Extensions field in misaā table in the riscv-privileged-20211203.pdf gives the following
6666555555555544444444443333333333222222222211111111110000000000
3210987654321098765432109876543210987654321098765432109876543210
S76 1000000000000000000000000000000000000000100100000001000100000111
U74 1000000000000000000000000000000000000000100101000001000100101111
bit 63=1 ==> MXL (Machine XLEN) the native base integer ISA is 64-bit
bit 23=1 ==> X: Non-standard extensions present
bit 20=1 ==> U: User mode implemented
bit 18=1 ==> S: Supervisor mode implemented
bit 12=1 ==> M: Integer Multiply/Divide extension
bit 08=1 ==> I: RV32I/64I/128I base ISA
bit 05=1 ==> F: Single-precision floating-point extension
bit 03=1 ==> D: Double-precision floating-point extension
bit 02=1 ==> C: Compressed extension
bit 01=1 ==> B: Tentatively reserved for Bit-Manipulation extension
bit 00=1 ==> A: Atomic extension
From the above the letters are (but in a illegal format):
1x S76 is a RV64IABCMUX
4x U74 is a RV64IABCDFMSUX
So more precisely it is:
1x S76 rv64imacux_Zba_Zbb
4x U74 rv64imafdcsux_Zba_Zbb
And even more precisely:
F implies Zicsr, but it may be present even if F is not (e.g. The Core IP had optional F support)
G implies IMAFDZicsr_Zifencei
1x S76 rv64imacuxZba_Zbb_Zicsr
4x U74 rv64imafdcsuxZba_Zbb_Zifencei_Zicsr
EDIT: I now suspect this, but i could be wrong:
1x S76 rv64imacuxZicsr_Zifencei_Zba_Zbb_Sscofpmf
4Ć U74 rv64imafdcsuxZicsr_Zifencei_Zba_Zbb_Sscofpmf
and at a guess the E24 co-processor is probably:
1x E24 rv32imfcuxZicsr
I guess it is time to start trying to figure out how to get more details on the E24.
from the upstream tree.
