dwmci_d: DATA ERROR!
mmc_bre: Failed to read blocks
dwmci_s: Timeout.
mmc_bre: Failed to set blocklen
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
BOOT fail,Error is 0xffffffff
UART下,执行mmc info
TF卡是SanDisk Ultra 64GB Class 10 UHS Class A-1。
是否应该考虑换一个卡?
更新:
换了一个maxell的class 10 HC卡,同样还是无法找到SD卡。
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
Model: StarFive VisionFive V2
unable to select a mode
bootmode flash device 0
Couldn't find partition mmc 0:3
Can't set block device
Importing environment from mmc0 ...
## Error: "boot2" not defined
产品信息:
Product full SN: VF7110A1-2250-D008E000-00001054
PCB revision: 0xa1
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
dwmci_s: Timeout.
