I’ve installed Image-69 and can login through SSH or the serial command, but I get a black screen on the HDMI display without mouse cursor.
It looks like HDMI is working, but lightdm is crashing:
[ 1757.314013] lightdm-gtk-gre[3188]: unhandled signal 11 code 0x1 at 0x000000405ec2fcc0 in libgtk-3.so.0.2404.30[3fb0526000+6a3000]
[ 1757.325742] CPU: 1 PID: 3188 Comm: lightdm-gtk-gre Tainted: G O 5.15.0-starfive #1
[ 1757.334628] Hardware name: StarFive VisionFive V2 (DT)
[ 1757.339781] epc : 0000003fb06eb502 ra : 0000003fb06f0528 sp : 0000003fdafc9860
[ 1757.347022] gp : 0000002aad925a10 tp : 0000003fad07a7b0 t0 : 0000003fdafc9208
[ 1757.354250] t1 : 000000000000006c t2 : 0000000000000000 s0 : 0000002aadacc8c0
[ 1757.361489] s1 : 0000002aadcfabd0 a0 : 0000000000000000 a1 : 0000000046cc7680
[ 1757.368730] a2 : 0000002aadcfabef a3 : 0000000000000000 a4 : 0000000000000004
[ 1757.375957] a5 : 000000405ec2fcc0 a6 : 0000000000000000 a7 : 0000000000000000
[ 1757.383196] s2 : 0000002aad9b4f00 s3 : 0000003fac6ab000 s4 : 0000002aad925fe8
[ 1757.390437] s5 : 0000002aada72cb0 s6 : 0000002aad9b4f70 s7 : 0000000000000000
[ 1757.397677] s8 : 0000002aadc7c6a0 s9 : 0000003fdafc9968 s10: 0000002aad91cc08
[ 1757.404905] s11: 0000002aad98da40 t3 : 0000000000000000 t4 : 0000000000000000
[ 1757.412144] t5 : 000e394322885b2e t6 : 00000001a640f1a1
[ 1757.417468] status: 8000000200006020 badaddr: 000000405ec2fcc0 cause: 000000000000000d
Here’s the output from modetest:
root@starfive:~# modetest -M starfive -c
Connectors:
id encoder status name size (mm) modes encoders
116 115 connected HDMI-A-1 220x130 10 115
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
#0 1920x1080 60.00 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
#1 1920x1080 59.94 1920 2008 2052 2200 1080 1084 1089 1125 148352 flags: phsync, pvsync; type: driver
#2 1920x1080 50.00 1920 2448 2492 2640 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
#3 1280x720 60.00 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver
#4 1280x720 59.94 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver
#5 1280x720 50.00 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type: driver
#6 720x480 60.00 720 736 798 858 480 489 495 525 27027 flags: nhsync, nvsync; type: driver
#7 720x480 59.94 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type: driver
#8 640x480 60.00 640 656 752 800 480 490 492 525 25200 flags: nhsync, nvsync; type: driver
#9 640x480 59.94 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
00ffffffffffff000cb8101001000000
0a1f010380160d780a6755a55b479c25
1e4f54210800d1c081408180810081c0
0101010101014e200090512015302a80
3600965e0000001e0e1f008051001e30
40803700965e0000001e000000fc0043
583130310a20202020202020000000fd
00304c1e561e000a2020202020200122
02031b7746818284939f10230f170783
4f000067030c0010003842023a801871
382d40582c4500c48e2100001e000000
00000000000000000000000000000000
000000000000000000000000000000f4
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
I’ve tried two displays, none of which are 4K, One is Full HD and the other is 1280x800.
I’ve checked the thread: How do I set up a GUI on Debian? too.
Here’s the full log: PrivateBin
The U-boot part does not show up because it’s cleared during boot in my terminal program.
I have recorded it with the sdcard.img file too:
U-Boot 2021.10 (Dec 25 2022 - 20:59:18 +0800), Build: jenkins-github_visionfive2-4
CPU: rv64imacu
Model: StarFive VisionFive V2
DRAM: 8 GiB
Product full SN: VF7110B1-2253-D008E000-00001654
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:2a:f1
Ethernet MAC1 address: 6c:cf:39:00:2a:f2
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
switch to partitions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
Failed to load 'uEnv.txt'
I can not share the link for that one, since I’m only allowed to add one link.
