Hi @tunagenes and Others,
I have gone through the both repos but not able to map regarding calibration and r/w training.
https://github.com/starfive-tech/u-boot/tree/JH7110_VisionFive2_devel/drivers/ram/starfive
and
https://github.com/starfive-tech/JH7100_ddrinit/blob/starfive/ddrc_cfg/lpddr4_1600_cl28_bl16/orbit_boot_1600.c
In the following files, I’m not able to find out where the DRAM calibration and Read/write training take place in code.
ddrcsr_boot.c, ddrphy_start.c, ddrphy_train.c, ddrphy_utils.c, starfive_ddr.c starfive_ddr.h
I’m also not able to understand what the following while loop is doing in “ddrcsr_boot.c” file.
Is it doing training ?
while ((val & 0x2) != 0x0) {
val = in_le32(phyreg + 1);
if ((val & 0x20) == 0x20) {
switch (val & 0x0000001f) {
case 0: //ddrc_clock=12M
DDR_REG_SET(BUS, DDR_BUS_OSC_DIV2);
break;
case 1: //ddrc_clock=200M
DDR_REG_SET(BUS, DDR_BUS_PLL1_DIV8);
break;
case 2: //ddrc_clock=800M
DDR_REG_SET(BUS, DDR_BUS_PLL1_DIV2);
break;
default:
break;
out_le32((phyreg + 2), 0x1);
do {
udelay(2);
val = in_le32(phyreg + 2);
} while ((val & 0x00000001) != 0x00000000);
udelay(1);
val = in_le32(csrreg + REGOFFSET(0x518));
Thanks,
Novice
