Hello,
I flashed the new image on my visionfive v2, and then the board died randomly. I tried recovery tools for bootloader and flash new bootloader and new uboot but nothing works on the board anymore. I’m getting on uart the following error:
�dwmci_s: Response Timeout.
BOOT fail,Error is 0xffffffff
I’m pretty sure you didn’t brick the board. You just need to configure the dip switches into recovery mode and then upload the latest official starfive debian spl.out and fw payload back onto the board and then you’ll be ok to boot the latest official starfive debian image again.
Hi, thanks for your reply. I already did that. I changed the dip switches to recovery and flashed both files one after the other by selecting in the menu after for the fw payload. But after setting dip switches to default same thing happens, same error.
Then follow the instructions here. I found them very clear:
OK. I did this on Sunday 9 June 2024.
This worked for me.
PHYSICALLY CHANGE DIP SWITCHES BOTH SET TO HIGH 1
This sets the board in UART FIRMWARE RECOVERY MODE
sudo minicom -b 115200 -D /dev/ttyUSB0
###HELP
ctrl a z
###CONFIG
o
###file transfer protocols
So all this stuff is ok.
Serial port setup--->>>Software Flow Control--->>>YES
Serial port setup--->>>Hardware Flow Control--->>>NO
Save config
###get the minicom help menu
Ctrl a z
###send file
s
###choose the xmodem protocol
xmodem
###select the file to upload
jh7110-recovery-20230918.bin
press space to tag it
press enter to start the send
NOTE: it will beep to say it sent it successfully then please wait until you get the menu back. It takes time.
###To send the spl file, we want to use the menu item "Update SPL in FLASH"
0
ctrl a z
s
xmodem
u-boot-spl.bin.normal.out
press space
###To send the fw payload, we want to use "Update UBOOT in FLASH"
2
ctrl a z
s
xmodem
visionfive2_fw_payload.img
press space
PHYSICALLY CHANGE DIP SWITCHES BOTH SET TO LOW 0
This sets the board in DEFAULT MANUFACTURER BOOT MODE
Done. This worked for me. I hope it works for you too.
After all this however, when I insert any sdcard, any distro, none boot up.
I get this:
U-Boot 2021.10 (May 09 2024 - 22:45:24 +0800), Build: jenkins-github_visionfive2_6.6-1
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
OK
Product full SN: VF7110B1-2253-D008E000-00002621
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:36:43
Ethernet MAC1 address: 6c:cf:39:00:36:44
In: serial
Out: serial
Err: serial
starting USB...
No working controllers found
Unknown command 'bootflow' - try 'help'
StarFive #
One very crucial step I forgot to do after all this:
env default -f -a
env save
This helped get rid of the uboot environment customizations I did for the fedora 40 image. This brought it back to the default uboot debian engineering starfive environment.
