I recently purchased a Starfive Visionfive 2 from a 3rd party seller. It was listed as, ‘for parts or not working.’ It was very inexpensive, so I figured, if it is broken, no big loss, if it isn’t and I can fix it / get it to work: great!
Anyway, it doesn’t seem to want to boot. I’ve tried several SDcard images, all the way back to the 55 early release. The board version is 1.2A.
Now, when UART is connected to minicom, when trying to boot (from SDcard), it will output the SPL version, but then, it quits, no more output.
So, I’ve been trying the recover the bootloader guide(s)?
I tried following the guide here → Board died randomly - #6 by omac777
after using minicom + xmodem and successfully sending the recovery image I get the following output after pressing enter
JH7110 secondboot version: 230322-c514da9
CPU freq: 1250MHz
idcode: 0x1860C8
[[[No more output at this point]]]
There is no more ouput after that, so I am unable to flash spl and firmware subsequently.
If I try booting from just an sd card, no matter the image (earliest 55) to later versions, I end up with the following UART output
U-Boot SPL 2021.10 (Jan 08 2023 - 18:04:54 +0800)
[or something of that nature depending on the image, nothing more]
it stops there (regardless of image)
I thought perhaps my AC-to-DC adapter wasn’t delivering enough power, so, bought a proper PD 2.0 45w usb-c power adapter, and gave all that a try again: still no luck. It doesn’t seem to be a power issue.
Other than that, my only guess is that the previous owner blew the OTP fuses in recovery mode? (Of which I don’t know much about, is that reversible if that is the case?)
I have no idea what that would do, what it means, etc…
It seems odd, in that, clearly something is working, I can get the CCCC from UART boot mode and transfer via xmodem the recovery image, but after that, no menu displays for further delivery of SPL and firmware.
I get at least one line of output in SDIO mode…
However, beyond that… This board won’t boot anything / boot at all.
I haven’t a clue at this point.
Perhaps it’s an irreversible hardware issue (damage or something)?
I also have an external chip flasher, that I could possibly use to hardware flash the (QSPI?), if that would possibly help. I wouldn’t know where to get a dump of a good image though, if there even are any.
Any ideas? Thnx!
