Docker is an open-source application container engine. Developers can use it to package applications and dependency packages into a light and portable container, and then publish them to any version of Linux devices. It will make the devices to utilize system resources more efficiently and ensure a consistent operating environment. It not only enables continuous delivery and deployment, but also enables easier migration, maintenance and expansion in the later stage.
Introduction to Docker Usage
StarFive provides the following application note, which details how to use Docker container solutions on VisionFive 2. Running Docker on VisionFive 2.
For more information, please refer to the contact information at the end of this post.
About VisionFive 2
VisionFive 2 is the worldās first high-performance RISC-V single board computer (SBC) with an integrated GPU. Compared with its last generation, VisionFive 2 has been fully upgraded with significant improvements in the processor work frequency, multimedia processing capabilities, scalability, etc. Its superior performance and reasonable price make VisionFive 2 the best affordable RISC-V development board ever.
VisionFive 2 boasts a quad-core 64-bit SoC with RV64GC ISA, running up to 1.5 GHz, and integrated with IMG BXE-4-32 MC1, supporting OpenCL 3.0, OpenGL ES 3.2, and Vulkan 1.2. Available with 2/4/8 GB LPDDR4 RAM options, VisionFive 2 provides rich I/O peripherals such as M.2 connector, eMMC socket, USB 3.0 ports, a 40-pin GPIO header, Gigabit Ethernet ports, a TF card slot, and many more. It has onboard audio and video processing capabilities and has MIPI-CSI and MIPI-DSI connectors as multimedia peripherals. The open source SBC also provides wide software compatibility including support for Debian.
Does the resulting kernel work for Docker using NFTables or just IPTables? The custom kernel Iāve compiled in another thread supports Docker, but only when using IPTables and I havenāt found a way to make it work with NFTables, so if this one works with both Iād love to incorporate the changes into my build.
This config works for me using podman and nftables, not sure about docker:
CONFIG_DEFAULT_HOSTNAME="StarFive"
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_USELIB=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_BPF_SYSCALL=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_RDMA=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
# CONFIG_PROC_PID_CPUSET is not set
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_BPF=y
CONFIG_CGROUP_MISC=y
CONFIG_NAMESPACES=y
CONFIG_USER_NS=y
CONFIG_CHECKPOINT_RESTORE=y
CONFIG_SCHED_AUTOGROUP=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_EXPERT=y
CONFIG_SOC_STARFIVE=y
CONFIG_SOC_STARFIVE_JH7110=y
CONFIG_SMP=y
CONFIG_HZ_100=y
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
CONFIG_CPU_IDLE=y
CONFIG_RISCV_SBI_CPUIDLE=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_PAGE_REPORTING=y
CONFIG_CMA=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_TLS=m
CONFIG_XFRM_USER=m
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
CONFIG_XFRM_STATISTICS=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=m
CONFIG_IP_MROUTE=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_IPV6=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_ILA=m
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_SEG6_LWTUNNEL=y
CONFIG_IPV6_SEG6_HMAC=y
CONFIG_NETFILTER=y
CONFIG_BRIDGE_NETFILTER=m
CONFIG_NETFILTER_NETLINK_ACCT=y
CONFIG_NETFILTER_NETLINK_QUEUE=y
CONFIG_NF_CONNTRACK=y
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NF_TABLES=y
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=y
CONFIG_NFT_COUNTER=m
CONFIG_NFT_CONNLIMIT=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
CONFIG_NFT_TUNNEL=m
CONFIG_NFT_OBJREF=m
CONFIG_NFT_QUEUE=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_COMPAT=y
CONFIG_NFT_HASH=m
CONFIG_NFT_XFRM=m
CONFIG_NFT_SOCKET=m
CONFIG_NFT_OSF=m
CONFIG_NFT_TPROXY=m
CONFIG_NFT_SYNPROXY=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NETFILTER_XT_SET=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
CONFIG_NETFILTER_XT_MATCH_CGROUP=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPCOMP=y
CONFIG_NETFILTER_XT_MATCH_IPRANGE=y
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=y
CONFIG_NETFILTER_XT_MATCH_MARK=y
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=y
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=y
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=y
CONFIG_IP_SET=m
CONFIG_IP_VS=m
CONFIG_IP_VS_IPV6=y
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_FTP=m
CONFIG_NF_SOCKET_IPV4=y
CONFIG_NF_TABLES_IPV4=y
CONFIG_NFT_DUP_IPV4=y
CONFIG_NFT_FIB_IPV4=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_NETMAP=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_NF_TABLES_BRIDGE=m
CONFIG_NFT_BRIDGE_META=m
CONFIG_NF_CONNTRACK_BRIDGE=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_VLAN_8021Q=m
CONFIG_VSOCKETS=m
CONFIG_NETLINK_DIAG=y
CONFIG_CGROUP_NET_PRIO=y
CONFIG_CAN=y
CONFIG_IPMS_CAN=y
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_CFG80211=y
CONFIG_MAC80211=y
CONFIG_NET_9P=y
CONFIG_NET_9P_VIRTIO=y
CONFIG_PCI=y
# CONFIG_PCIEASPM is not set
CONFIG_PCIE_PLDA=y
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_MTD=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_SPI_NOR=y
CONFIG_OF_CONFIGFS=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=y
CONFIG_EEPROM_AT24=y
CONFIG_BLK_DEV_SD=y
CONFIG_BLK_DEV_SR=y
CONFIG_SCSI_VIRTIO=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_NETDEVICES=y
CONFIG_WIREGUARD=m
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN=m
CONFIG_IPVTAP=m
CONFIG_VXLAN=m
CONFIG_TUN=m
CONFIG_VETH=y
CONFIG_VIRTIO_NET=y
# CONFIG_NET_VENDOR_ALACRITECH is not set
# CONFIG_NET_VENDOR_AMAZON is not set
# CONFIG_NET_VENDOR_AQUANTIA is not set
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CADENCE is not set
# CONFIG_NET_VENDOR_CAVIUM is not set
# CONFIG_NET_VENDOR_CORTINA is not set
# CONFIG_NET_VENDOR_EZCHIP is not set
# CONFIG_NET_VENDOR_GOOGLE is not set
# CONFIG_NET_VENDOR_HUAWEI is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
# CONFIG_NET_VENDOR_MELLANOX is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_MICROSEMI is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_NETRONOME is not set
# CONFIG_NET_VENDOR_NI is not set
# CONFIG_NET_VENDOR_PENSANDO is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
CONFIG_R8169=y
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_NET_VENDOR_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
# CONFIG_NET_VENDOR_SOLARFLARE is not set
# CONFIG_NET_VENDOR_SOCIONEXT is not set
CONFIG_STMMAC_ETH=y
CONFIG_STMMAC_SELFTESTS=y
CONFIG_DWMAC_DWC_QOS_ETH=y
CONFIG_DWMAC_STARFIVE_PLAT=y
# CONFIG_NET_VENDOR_SYNOPSYS is not set
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
# CONFIG_NET_VENDOR_XILINX is not set
CONFIG_MARVELL_PHY=y
CONFIG_MICREL_PHY=y
CONFIG_MOTORCOMM_PHY=y
CONFIG_IWLWIFI=y
CONFIG_IWLDVM=y
CONFIG_IWLMVM=y
# CONFIG_RTL_CARDS is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_KEYBOARD is not set
# CONFIG_INPUT_MOUSE is not set
CONFIG_SERIO_LIBPS2=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=6
CONFIG_SERIAL_8250_RUNTIME_UARTS=6
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_EARLYCON_RISCV_SBI=y
CONFIG_HVC_RISCV_SBI=y
CONFIG_TTY_PRINTK=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_VIRTIO=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_SPI=y
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_SPI_PL022_STARFIVE=y
CONFIG_SPI_SIFIVE=y
CONFIG_SPI_SPIDEV=y
# CONFIG_PTP_1588_CLOCK is not set
CONFIG_PINCTRL=y
CONFIG_PINCTRL_STARFIVE=y
CONFIG_PINCTRL_STARFIVE_JH7110=y
CONFIG_GPIO_SYSFS=y
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_GPIO_RESTART=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_POWER_RESET_SYSCON_POWEROFF=y
CONFIG_SENSORS_SFCTEMP=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_SYSFS=y
CONFIG_STARFIVE_WATCHDOG=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_AXP15060=y
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_STF_VIN=y
CONFIG_VIN_SENSOR_IMX219=y
CONFIG_DRM_PANEL_JADARD_JD9365DA_H3=y
CONFIG_DRM_VERISILICON=y
CONFIG_STARFIVE_INNO_HDMI=y
CONFIG_STARFIVE_DSI=y
CONFIG_DRM_IMG_ROGUE=y
CONFIG_DRM_LEGACY=y
CONFIG_FB=y
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_USB_AUDIO=y
CONFIG_SND_SOC=y
CONFIG_SND_DESIGNWARE_I2S=y
CONFIG_SND_SOC_STARFIVE=y
CONFIG_SND_SOC_STARFIVE_PWMDAC=y
CONFIG_SND_SOC_STARFIVE_I2S=y
CONFIG_SND_SOC_AC108=y
CONFIG_SND_SOC_WM8960=y
CONFIG_SND_SIMPLE_CARD=y
CONFIG_USB=y
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_STORAGE=y
CONFIG_USB_UAS=y
CONFIG_USB_CDNS_SUPPORT=y
CONFIG_USB_CDNS3=y
CONFIG_USB_CDNS3_GADGET=y
CONFIG_USB_CDNS3_HOST=y
CONFIG_USB_CDNS3_STARFIVE=y
CONFIG_USB_GADGET=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_MMC=y
CONFIG_MMC_DEBUG=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_DWCMSHC=y
CONFIG_MMC_SPI=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_STARFIVE=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_STARFIVE=y
CONFIG_RTC_DRV_GOLDFISH=y
CONFIG_DMADEVICES=y
CONFIG_DW_AXI_DMAC=y
CONFIG_DMATEST=y
# CONFIG_VIRTIO_MENU is not set
# CONFIG_VHOST_MENU is not set
CONFIG_GOLDFISH=y
CONFIG_STARFIVE_TIMER=y
CONFIG_MAILBOX=y
CONFIG_STARFIVE_MBOX=m
CONFIG_STARFIVE_MBOX_TEST=m
# CONFIG_IOMMU_SUPPORT is not set
CONFIG_RPMSG_CHAR=y
CONFIG_RPMSG_VIRTIO=y
CONFIG_SIFIVE_L2_FLUSH_START=0x40000000
CONFIG_SIFIVE_L2_FLUSH_SIZE=0x400000000
CONFIG_STARFIVE_PMU=y
CONFIG_PWM=y
CONFIG_PWM_STARFIVE_PTC=y
CONFIG_PHY_M31_DPHY_RX0=y
CONFIG_RAS=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_CPUFREQ_DT=y
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=y
CONFIG_CUSE=y
CONFIG_VIRTIO_FS=y
CONFIG_OVERLAY_FS=y
CONFIG_OVERLAY_FS_INDEX=y
CONFIG_OVERLAY_FS_XINO_AUTO=y
CONFIG_OVERLAY_FS_METACOPY=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_UTF8=y
CONFIG_EXFAT_FS=y
CONFIG_NTFS_FS=y
CONFIG_NTFS_RW=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_HUGETLBFS=y
CONFIG_JFFS2_FS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK_XFRM=y
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_APPARMOR=y
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_CRYPTO_USER=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_USER_API_HASH=y
CONFIG_CRYPTO_USER_API_SKCIPHER=y
CONFIG_CRYPTO_USER_API_RNG=y
CONFIG_CRYPTO_USER_API_AEAD=y
CONFIG_CRYPTO_USER_API_AKCIPHER=y
CONFIG_CRYPTO_DEV_VIRTIO=y
CONFIG_CRYPTO_DEV_JH7110_ENCRYPT=y
CONFIG_DMA_CMA=y
CONFIG_PRINTK_TIME=y
CONFIG_DEBUG_FS=y
CONFIG_SOFTLOCKUP_DETECTOR=y
CONFIG_WQ_WATCHDOG=y
CONFIG_DEBUG_TIMEKEEPING=y
CONFIG_DEBUG_RT_MUTEXES=y
CONFIG_DEBUG_SPINLOCK=y
CONFIG_DEBUG_RWSEMS=y
CONFIG_DEBUG_ATOMIC_SLEEP=y
CONFIG_STACKTRACE=y
CONFIG_DEBUG_LIST=y
CONFIG_DEBUG_PLIST=y
CONFIG_DEBUG_SG=y
# CONFIG_RCU_TRACE is not set
CONFIG_RCU_EQS_DEBUG=y
# CONFIG_FTRACE is not set
# CONFIG_RUNTIME_TESTING_MENU is not set
CONFIG_MEMTEST=y
