vf2上用python脚本能否在spi lcd上显示中文?
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/PIL/ImageDraw.py", line 463, in draw_text
    mask, offset = font.getmask2(
AttributeError: 'ImageFont' object has no attribute 'getmask2'. Did you mean: 'getmask'?
During handling of the above exception, another exception occurred:
  File "/home/user/01_LCD_ok/LCD_demo.py", line 352, in <module>
    main_lcd3()
  File "/home/user/01_LCD_ok/LCD_demo.py", line 260, in main_lcd3
    show_img_exif(file_path_tmp)
  File "/home/user/01_LCD_ok/LCD_demo.py", line 123, in show_img_exif
    disp.display_text_exif(str)
  File "/home/user/01_LCD_ok/lib/LCD_ILI9488_lib.py", line 354, in display_text_exif
    draw.text((x, y), text, font=font, fill=color)
  File "/usr/lib/python3/dist-packages/PIL/ImageDraw.py", line 520, in text
    draw_text(ink)
  File "/usr/lib/python3/dist-packages/PIL/ImageDraw.py", line 479, in draw_text
    mask = font.getmask(
  File "/usr/lib/python3/dist-packages/PIL/ImageFont.py", line 179, in getmask
    return self.font.getmask(text, mode)
UnicodeEncodeError: 'latin-1' codec can't encode characters in position 0-1: ordinal not in range(256)
尝试通过draw.text((x, y), text, font=font, fill=color),显示text = “你好“,但是发现缺少getmask2。
pip install --upgrade pillow
升级pillow,却被提示无法安装
user@starfive:~/01_LCD_ok$ pip install --upgrade pillow
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
    python3-xyz, where xyz is the package you are trying to
    install.
    If you wish to install a non-Debian-packaged Python package,
    create a virtual environment using python3 -m venv path/to/venv.
    Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    sure you have python3-full installed.
    If you wish to install a non-Debian packaged Python application,
    it may be easiest to use pipx install xyz, which will manage a
    virtual environment for you. Make sure you have pipx installed.
    See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
请问有没有人尝试过通过lcd显示中文?
我之前在这个上面是可以显示的:星光派系统信息显示OLED小面板 - 昉·星光 2(CN) - RVspace Forum,注意字体
