I was not able to repeat your success from a fresh image flashed to the wiped new 128GB sdcard. I don’t say this lightly either. I tried 3 times with the same results starting with a fresh image of starfive-jh7110-VF2-SD-wayland.img that was booting with the pink desktop.
I’ve tried your steps 1 to 5 and the boot process seems to freeze. My vf2 debian desktop from the march 2023 image doesn’t display the pink login after power up. I’ve tried it just with the SBC to the hd monitor. I’ve tried using 2 hdmi cables to one hd monitor. One for the SBC and the other for my fedora silverblue x86_64 session during VF2 power on. Same result with the same output as given below with last lines I see as “deferred probe pending”.
sudo minicom -D /dev/ttyUSB0 -b 115200
[sudo] password for davidm:
Welcome to minicom 2.8
OPTIONS: I18n
Compiled on Jan 19 2023, 00:00:00.
Port /dev/ttyUSB0, 20:38:53
Press CTRL-A Z for help on special keys
U-Boot SPL 2021.10 (Mar 24 2023 - 01:42:56 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Mar 24 2023 - 01:42:56 +0800), Build: jenkins-github_visionfive2-13
CPU: rv64imacu
Model: StarFive VisionFive V2
DRAM: 8 GiB
Product full SN: VF7110B1-2253-D008E000-00002621
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:36:43
Ethernet MAC1 address: 6c:cf:39:00:36:44
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
385 bytes read in 4 ms (93.8 KiB/s)
Can't set block device
48366 bytes read in 10 ms (4.6 MiB/s)
48366 bytes written in 10 ms (4.6 MiB/s)
1385 bytes read in 7 ms (192.4 KiB/s)
U-Boot menu
1: Debian GNU/Linux bookworm/sid 6.3.0+
2: Debian GNU/Linux bookworm/sid 6.3.0+ (rescue target)
3: Debian GNU/Linux bookworm/sid 5.15.0-starfive
4: Debian GNU/Linux bookworm/sid 5.15.0-starfive (rescue target)
Enter choice: 1: Debian GNU/Linux bookworm/sid 6.3.0+
Retrieving file: /initrd.img-6.3.0+
10459640 bytes read in 457 ms (21.8 MiB/s)
Retrieving file: /vmlinuz-6.3.0+
9409550 bytes read in 412 ms (21.8 MiB/s)
append: root=/dev/mmcblk1p4 root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
48366 bytes read in 9 ms (5.1 MiB/s)
Uncompressing Kernel Image
Moving Image from 0x44000000 to 0x40200000, end=4198e000
Using Device Tree in place at 0000000048000000, end 000000004800eced
Starting kernel ...
clk u2_dw_i2c_clk_core already disabled
clk u2_dw_i2c_clk_apb already disabled
[ 0.000000] Linux version 6.3.0+ (root@9164ec80e2e5) (riscv64-linux-gnu-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #36 SMP Sat May 6 21:03:11 UTC 2023
[ 0.000000] earlycon: uart0 at MMIO32 0x0000000010000000 (options '115200')
[ 0.000000] printk: bootconsole [uart0] enabled
[ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000009fffffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable opensbi@40000000
[ 0.000000] OF: reserved mem: 0x00000000c0110000..0x00000000c01fffff (960 KiB) nomap non-reusable e24@c0000000
[ 0.000000] OF: reserved mem: 0x00000000f0000000..0x00000000f1fffffe (32767 KiB) map non-reusable xrpbuffer@f0000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff]
[ 0.000000] node 0: [mem 0x0000000040080000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
[ 0.000000] SBI specification v1.0 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10002
[ 0.000000] SBI SRST extension detected
[ 0.000000] SBI HSM extension detected
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] percpu: Embedded 19 pages/cpu s38776 r8192 d30856 u77824
[ 0.000000] Kernel command line: root=/dev/mmcblk1p4 root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Unknown kernel command line parameters "selinux=0", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] Memory: 7568604K/8388608K available (11762K kernel code, 5034K rwdata, 4096K rodata, 2199K init, 498K bss, 295716K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] riscv: providing IPIs using SBI IPI extension
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] riscv-timer: riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.009041] Console: colour dummy device 80x25
[ 0.013920] printk: console [tty0] enabled
[ 0.019059] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=40000)
[ 0.030255] pid_max: default: 32768 minimum: 301
[ 0.035414] LSM: initializing lsm=capability,apparmor,integrity
[ 0.042028] AppArmor: AppArmor initialized
[ 0.046734] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.055232] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.066377] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.074327] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.081150] riscv: ELF compat mode unsupported
[ 0.081159] ASID allocator disabled (0 bits)
[ 0.090867] rcu: Hierarchical SRCU implementation.
[ 0.096143] rcu: Max phase no-delay instances is 1000.
[ 0.102139] EFI services will not be available.
[ 0.107523] smp: Bringing up secondary CPUs ...
[ 0.114744] smp: Brought up 1 node, 4 CPUs
[ 0.121397] devtmpfs: initialized
[ 0.134327] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.145164] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.167164] pinctrl core: initialized pinctrl subsystem
[ 0.174068] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.181310] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.189250] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.198118] audit: initializing netlink subsys (disabled)
[ 0.204229] audit: type=2000 audit(0.150:1): state=initialized audit_enabled=0 res=1
[ 0.204548] thermal_sys: Registered thermal governor 'step_wise'
[ 0.212802] cpuidle: using governor menu
[ 0.230705] platform soc: Fixed dependency cycle(s) with /soc/plic@c000000
[ 0.248703] platform soc:dsi-output: Fixed dependency cycle(s) with /soc/dc8200@29400000/port/endpoint@2
[ 0.259470] platform 295d0000.mipi: Fixed dependency cycle(s) with /soc/dsi-output/ports/port@1/endpoint
[ 0.270214] platform 29590000.hdmi: Fixed dependency cycle(s) with /soc/dc8200@29400000/port/endpoint@1
[ 0.283036] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.290498] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.297398] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.304853] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.481898] raid6: int64x8 gen() 588 MB/s
[ 0.652014] raid6: int64x4 gen() 957 MB/s
[ 0.822127] raid6: int64x2 gen() 927 MB/s
[ 0.992279] raid6: int64x1 gen() 743 MB/s
[ 0.996971] raid6: using algorithm int64x4 gen() 957 MB/s
[ 1.173016] raid6: .... xor() 536 MB/s, rmw enabled
[ 1.178374] raid6: using intx1 recovery algorithm
[ 1.184013] SCSI subsystem initialized
[ 1.188467] usbcore: registered new interface driver usbfs
[ 1.194553] usbcore: registered new interface driver hub
[ 1.200418] usbcore: registered new device driver usb
[ 1.206318] mc: Linux media interface: v0.10
[ 1.211042] videodev: Linux video capture interface: v2.00
[ 1.217302] Advanced Linux Sound Architecture Driver Initialized.
[ 1.224541] Bluetooth: Core ver 2.22
[ 1.228515] NET: Registered PF_BLUETOOTH protocol family
[ 1.234349] Bluetooth: HCI device and connection manager initialized
[ 1.241342] Bluetooth: HCI socket layer initialized
[ 1.246702] Bluetooth: L2CAP socket layer initialized
[ 1.252271] Bluetooth: SCO socket layer initialized
[ 1.257945] vgaarb: loaded
[ 1.261242] clocksource: Switched to clocksource riscv_clocksource
[ 1.268892] AppArmor: AppArmor Filesystem Enabled
[ 1.282135] NET: Registered PF_INET protocol family
[ 1.288483] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.308252] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.317918] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.326460] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.336045] TCP bind hash table entries: 65536 (order: 10, 4194304 bytes, linear)
[ 1.351519] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.358989] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 1.367018] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 1.375751] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.382618] RPC: Registered named UNIX socket transport module.
[ 1.389125] RPC: Registered udp transport module.
[ 1.394314] RPC: Registered tcp transport module.
[ 1.399479] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.407845] PCI: CLS 0 bytes, default 64
[ 1.412388] Unpacking initramfs...
[ 1.412942] Initialise system trusted keyrings
[ 1.421591] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.429039] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.435917] NFS: Registering the id_resolver key type
[ 1.441542] Key type id_resolver registered
[ 1.446147] Key type id_legacy registered
[ 1.450599] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.458012] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.466229] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.471102] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.478196] fuse: init (API version 7.38)
[ 1.521387] NET: Registered PF_ALG protocol family
[ 1.526706] xor: measuring software checksum speed
[ 1.536227] 8regs : 2344 MB/sec
[ 1.545262] 8regs_prefetch : 2335 MB/sec
[ 1.554288] 32regs : 2344 MB/sec
[ 1.563331] 32regs_prefetch : 2335 MB/sec
[ 1.568130] xor: using function: 32regs (2344 MB/sec)
[ 1.573723] Key type asymmetric registered
[ 1.578232] Asymmetric key parser 'x509' registered
[ 1.583716] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.592141] io scheduler mq-deadline registered
[ 1.597135] io scheduler kyber registered
[ 1.607835] CCACHE: DataError @ 0x00000000.08040140
[ 1.613347] CCACHE: DataFail @ 0x00000000.0804005B
[ 1.618723] CCACHE: 8 banks, 16 ways, sets/bank=256, bytes/block=64
[ 1.625661] CCACHE: Index of the largest way enabled: 15
[ 1.674636] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.691383] loop: module loaded
[ 1.698390] CAN device driver interface
[ 1.703863] usbcore: registered new interface driver uas
[ 1.709745] usbcore: registered new interface driver usb-storage
[ 1.716750] usbcore: registered new interface driver uvcvideo
[ 1.724223] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.733533] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 1.742076] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 1.751686] Bluetooth: HCI UART driver ver 2.3
[ 1.756584] Bluetooth: HCI UART protocol H4 registered
[ 1.763019] sdhci: Secure Digital Host Controller Interface driver
[ 1.769819] sdhci: Copyright(c) Pierre Ossman
[ 1.774677] Synopsys Designware Multimedia Card Interface Driver
[ 1.781643] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.788387] usbcore: registered new interface driver usbhid
[ 1.794538] usbhid: USB HID core driver
[ 1.798979] riscv-pmu-sbi: SBI PMU extension is available
[ 1.804968] riscv-pmu-sbi: 16 firmware and 4 hardware counters
[ 1.811411] riscv-pmu-sbi: Perf sampling/filtering is not supported as sscof extension is not available
[ 1.825551] usbcore: registered new interface driver snd-usb-audio
[ 1.839531] xt_time: kernel timezone is -0000
[ 1.844384] IPVS: Registered protocols (TCP, UDP)
[ 1.849602] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 1.857908] IPVS: ipvs loaded.
[ 1.861306] IPVS: [rr] scheduler registered.
[ 1.866339] NET: Registered PF_INET6 protocol family
[ 1.873132] Segment Routing with IPv6
[ 1.877236] In-situ OAM (IOAM) with IPv6
[ 1.881747] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.888896] NET: Registered PF_PACKET protocol family
[ 1.894553] Bridge firewalling registered
[ 1.898963] can: controller area network core
[ 1.903887] NET: Registered PF_CAN protocol family
[ 1.909164] can: raw protocol
[ 1.912460] can: broadcast manager protocol
[ 1.917075] can: netlink gateway - max_hops=1
[ 1.922178] Bluetooth: RFCOMM TTY layer initialized
[ 1.927561] Bluetooth: RFCOMM socket layer initialized
[ 1.933257] Bluetooth: RFCOMM ver 1.11
[ 1.937397] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.943259] Bluetooth: BNEP filters: protocol multicast
[ 1.949018] Bluetooth: BNEP socket layer initialized
[ 1.954587] 8021q: 802.1Q VLAN Support v1.8
[ 1.959224] lib80211: common routines for IEEE802.11 drivers
[ 1.965574] 9pnet: Installing 9P2000 support
[ 1.970368] Key type dns_resolver registered
[ 1.990970] Loading compiled-in X.509 certificates
[ 2.006402] Btrfs loaded, zoned=no, fsverity=no
[ 2.011568] AppArmor: AppArmor sha1 policy hashing enabled
[ 2.022143] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.305914] Freeing initrd memory: 10212K
[ 2.337253] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.343524] clk: Disabling unused clocks
[ 2.347851] ALSA device list:
[ 2.351110] No soundcards found.
[ 2.357202] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 2.363230] Freeing unused kernel image (initmem) memory: 2196K
[ 2.421297] Run /init as init process
[ 13.363165] platform 10030000.i2c: deferred probe pending
[ 13.369108] platform 10050000.i2c: deferred probe pending
[ 13.375057] platform 12050000.i2c: deferred probe pending
[ 13.380986] platform 12060000.i2c: deferred probe pending
[ 13.386923] platform 13040000.gpio: deferred probe pending
[ 13.392956] platform 17020000.gpio: deferred probe pending
[ 13.398979] platform 16050000.dma-controller: deferred probe pending
[ 13.405966] platform 10000000.serial: deferred probe pending
[ 13.412188] platform gpio-restart: deferred probe pending
[ 13.418117] platform 120e0000.tmon: deferred probe pending
[ 13.424149] platform cpufreq-dt: deferred probe pending
[ 13.429886] platform leds: deferred probe pending
[ 13.435064] platform soc:snd-card1: deferred probe pending
[ 13.441091] platform soc:snd-card3: deferred probe pending
[ 13.447126] platform 120b0000.i2stx_4ch0: deferred probe pending
[ 13.453734] platform 2b000000.pcie: deferred probe pending
[ 13.459761] platform 2c000000.pcie: deferred probe pending
