Thank you all for replying to my questions!
I have the initial backer 8GB version and have never updated nor used.
Before I tried to follow the Debian wiki article, I did an update following Recovering the Bootloader
I used the u-boot-spl.bin.normal.out and visionfive2_fw_payload.img dated Oct 16, 2025 from GitHub release at Releases · starfive-tech/VisionFive2 · GitHub
Here is my boot screen from usb serial:
U-Boot SPL 2021.10 (Oct 10 2025 - 11:25:33 +0800)
Trying to boot from SPI
OpenSBI v1.2
/ __ \ / | _ _ |
| | | |** __ __ _ __ | (** | |) || |
| | | | '_ \ / _ \ '_ \ __ | _ < | |
_/| ./ _|| ||/|/___|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : —
Platform PMU Device : —
Platform Suspend Device : —
Firmware Base : 0x40000000
Firmware Size : 248 KB
Firmware RW Offset : 0x20000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region01 : 0x0000000040000000-0x000000004001ffff M: (R,X) S/U: ()
Domain0 Region02 : 0x0000000040020000-0x000000004003ffff M: (R,W) S/U: ()
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Oct 10 2025 - 11:25:33 +0800), Build: jenkins-github_visionfive2_6.12-16
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
Loading Environment from SPIFlash… SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Product full SN: VF7110B1-2253-D008E000-00002957
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:38:e3
Ethernet MAC1 address: 6c:cf:39:00:38:e4
In: serial
Out: serial
Err: serial
