I just wanted to know if any generic USB Wifi module would be compatible with the visionfive2. I was thinking of getting one off this list: here .
Chloe
July 18, 2023, 5:58am
2
Hi realDelta2, have you ever see this doc before?
Here includes the USB WiFi module that the StarFive have tested.
conor
July 18, 2023, 7:28am
3
@Chloe I can’t see any WiFi modules listed there?
I don’t know if this is what you’re looking for, but I do see one entry that may apply, under the category PCIe:
PCIe to WiFi AX210 Intel® Wi-Fi 6E (Gig+) √
I hope that’s useful.
mzs
July 18, 2023, 7:34am
5
I saw this a while back:
I have five wireless dongles:
[image]
[WechatIMG3248]
They are:
RTL8192CU:“EDUP” in the first picture
MT7601U:one is “Mi” in the first picture,second is “du” in the first picture
ECR6600U:the green dongle in the first picture, Officially provided.
RTL8832AU:“EDUP” in the second picture
In these wireless dongles, both ECR6600U and RTL8832AU support WiFi6.
ECR6600U supports 2.4GHz. RTL8832AU supports 2.4GHz and 5GHz.
I successfully use these five wireless dongles on VisionFive 2.
My syst…
The Chinese version of has more technical details than the shorter English version. Use something like google translate to read: https://forum.rvspace.org/t/2-usb-rtl8832au-wifi6/1595
Also might be worthwhile searching for “RISC-V USB WiFi” in a search engine of your choosing. Because if a WiFi USB dongle can be got to work with one RISC-V board, the odds are high that with a bit of effort it can probably work with a different RISC-V board.
I already have my m.2 key taken up by an Nvme ssd so that won’t work for me.
Chloe
July 19, 2023, 1:15am
7
This topic may help you. Here list some wifi module that compatible with VisionFive 2
星光板2(VisionFive 2)开发板没有自带WiFi模块,所以要连上WiFi,可以使用USB无线网卡。
要使用USB无线网卡,和通用Linux中加载USB无线网卡一样,只要驱动对了,通常就能用了。
一、测试过的USB无线网卡
我手头除了官方提供的 WiFi dongle,还有4种以前用过的,具体如下:
[image]
【新增的RTL8832AU WiFi6双频无线网卡,请查看第七节】
在上图中:
绿色板子的,就是官方提供的 WiFi dongle,奕斯伟ESWIN的ECR6600U,其具体参数如下:
[ECR6600U]
其中,802.11ax就是第六代WiFi标准,简称WiFi 6,虽然不是双频的,但货真价实的WiFi6。
左边黑色和右边白的色,分别是小米和小度随身WiFi,芯片用的都是MTU7601,大致参数如下:
[MT7601]
中间黑色EDUP的,是EDUP EP-N1572,参数如下:
[image]
这三种芯片四个无线网卡,我都官方提供的Debian 69镜像版本一一测试,都可以正常使用,下面将各网卡的具体使用方式…
I think I saw that before, but I have not really dug into it, Ill look into it later and see what I can do. Thank you @Chloe @mzs
