My newly received visonfive board doesn’t boot at all. I have tried two sandisk sdcards, and also tried Fedora and Debian images in the forum, and even reflashed the bootloader, but the issue remains there:
U-Boot 2022.01-rc4-VisionFive-g0c08d335c5 (Dec 30 2021 - 20:05:04 +0800)StarFive
CPU: rv64imafdc
Model: StarFive VisionFive V1
DRAM: 8 GiB
MMC: mmc@10000000: 0, mmc@10010000: 1
StarFive EEPROM format v1
Product full SN: VF7100A1-2206-D008E000-00000301
data version: 0x1
PCB revision: 0x1
Ethernet MAC address: 6c:cf:39:00:03:00
In: serial@12440000
Out: serial@12440000
Err: serial@12440000
Net: dwmac.10020000
MMC CD is 0x0, force to True.
Autoboot in 2 seconds
dwmac.10020000 Waiting for PHY auto negotiation to complete. done
Speed: 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.8.107 (5467 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.8.107 (5466 ms)
Futhermore, if I remove the sdcard from the board, and power it, I see the same errors above. So I guess maybe the board can not woek with my two sandisk sdcards?
It frustrates me a lot. Any help is appreciated. Thanks.
