sudo apt update
Hit:1 https://snapshot.debian.org/archive/debian-ports/20230612T050707Z unstable InRelease
Err:1 https://snapshot.debian.org/archive/debian-ports/20230612T050707Z unstable InRelease
The following signatures were invalid: EXPKEYSIG B523E5F3FC4E5F2C Debian Ports Archive Automatic Signing Key (2023) ftpmaster@ports-master.debian.org EXPKEYSIG 8D69674688B6CB36 Debian Ports Archive Automatic Signing Key (2024) ftpmaster@ports-master.debian.org
Hit:2 https://debianrepo.starfivetech.com starfive-debian InRelease
Get:3 https://debianrepo.starfivetech.com VisionFive2 InRelease [2,681 B]
Fetched 2,681 B in 2s (1,479 B/s)
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
4 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://snapshot.debian.org/archive/debian-ports/20230612T050707Z unstable InRelease: The following signatures were invalid: EXPKEYSIG B523E5F3FC4E5F2C Debian Ports Archive Automatic Signing Key (2023) ftpmaster@ports-master.debian.org EXPKEYSIG 8D69674688B6CB36 Debian Ports Archive Automatic Signing Key (2024) ftpmaster@ports-master.debian.org
W: Failed to fetch https://snapshot.debian.org/archive/debian-ports/20230612T050707Z/dists/unstable/InRelease The following signatures were invalid: EXPKEYSIG B523E5F3FC4E5F2C Debian Ports Archive Automatic Signing Key (2023) ftpmaster@ports-master.debian.org EXPKEYSIG 8D69674688B6CB36 Debian Ports Archive Automatic Signing Key (2024) ftpmaster@ports-master.debian.org
W: Some index files failed to download. They have been ignored, or old ones used instead
hi ,Asterix.
Try upgrading debian2409 to debian13. Please refer to here: Debian-13_test for VF2 image (Including GPU and VPU driver)
thx for response - is chinese language - unfortunately no translation available and the wetransfer link is expired
I see its running Linux 6.6.20-starfive
Where can I download that version of the Linux source code?
hi, andrew.
https://github.com/starfive-tech/
Have you searched here?
It may be this branch GitHub - starfive-tech/linux at JH7110_VisionFive2_6.6.y_devel
Nevermind that is the Kernel I am currently running
I don’t know where to download Linux source code either. I upgraded starfive_debian2409 directly to debian13. No need for Linux source code.
had another look. wetransfer link is now active again. could download image. big thanks. — though not yet applied
It’s an archived snapshot, it doesn’t update.
When you change to a ‘real’ Debian release you will loose custom packages developed especially for the Visionfive2, i.e. GPU/VPU.
It’s Starfivetech’s way of developing software, but it leaves you in a dead end.
Please try installing it first.
