Wireless USB
anyone any success with this?
What brand is most suitable?
I’m using rtl8822bu (USB D-Link Corp. DWA-181 AC1300 802.11ac) without problems.
I’ll point you to this thread, but @nugu53 has already pointed you to most important thing covered in the thread.
I’m using the USB WiFi dongle that I ordered at the same time as the VF2 board:
$ lsusb | grep -i win
Bus 001 Device 003: ID 3452:6600 ESWIN 6600U
Wireless USB ?
USB WIFI Network Adapter ?
OR,USB Port Without USB-line ?
If USB Wifi , there are some choosen with in kernel driver. But you need build your self kernel.
If USB without line, the better choose is use USB over Ethernet.
its a generic wifi USB dongle from the PiHut.
802.11n
Will look into seeing if i can build but haven’t had luck in previous attempt to ā€˜build’ a common lisp - sbcl.
Thanks
What is the USB VID:PID (VendorID:ProductID) shown by lsusb (you may require sudo apt install usbutils first before you can execute lsusb) for your ā€œgenericā€ WiFi USB dongle.
See my post above for an example USB VID(4-digit hexadecimal):PID(4-digit hexadecimal)
Bus 001 Device 006: ID 148f:5370 Ralink technology, Corp. RT5370 Wireless Adaptor
A quick check in /var/lib/usbutils/usb.ids
VID: 148f Ralink Technology, Corp.
PID: 5370 RT5370 Wireless Adapter
After a quick check the StarFive linux kernel I would say that if you re-compile the kernel with ā€œRT2800USB=mā€ and ā€œRT2800USB_RT53XX=mā€ in your .config file it will probably work.
I checked and no module is currently created by default in the StarFive ā€œengineeringā€ Debian distribution for a RT5370.
$ zgrep -i RT2800USB /proc/config.gz
$ zgrep -i RT2800USB_RT53XX /proc/config.gz
As for howto recompile the kernel search the forum for ā€œscmversionā€ and you will find something useful. Or there is a document for cross-compiling a kernel and modules on an x64 machine. https://doc-en.rvspace.org/VisionFive2/SDK_Quick_Start_Guide/index.html.
thanks. i’ll give it a try over the weekend hopefully
