hello,
Is there advices regarding the antenna connector present on the board for WIFI/BLuetooth use ? I just wonder what is the recommended antenna type to use (for instance the model on the antenna mentionned in the enhanced VisionFive package) ? Thanks a lot for any feedback or advice on this.
Note : from first tests (Fedora , 5.16rc6), the board is seeing/listing my access point in the distant room, with no connected antenna, so maybe no need to add one.
Now working to access that network (more used to Ubuntu setup and tools).
and connected using nmcli commands (really easy compared to last time on Hifive Unmatched where i had to install extra packages first to setup netplan ). Really nice Fedora image.
The specifications of the antenna socket are IPEX1, and the working frequency range : 2.400 GHz ~ 2.4835 GHz (2.4 GHz ISM Band), the antenna meets this specification, it can be used.
thank you ,-)
