With this version nothing boots anymore, not even the own Debian images 202310 and 202311.
Here is the log:
U-Boot 2021.10 (Nov 29 2023 - 14:51:40 +0800), Build: jenkins-github_visionfive2-20
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 4 GiB
OK
Product full SN: VF7110B1-2310-D004E000-00001493
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:50:18
Ethernet MAC1 address: 6c:cf:39:00:50:19
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
Try booting from MMC1 ...
Can't set block device
## Error: "boot2" not defined
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link down.
Device 0: unknown device
Tring booting distro ...
fatwrite - write file into a dos filesystem
Usage:
fatwrite <interface> <dev[:part]> <addr> <filename> [<bytes> [<offset>]]
- write file 'filename' from the address 'addr' in RAM
to 'dev' on 'interface'
Error reading config file
StarFive #
I started with v2.10.4, this version could still boot other OS on the SD card.
I finally figured out what was wrong, I messed around with the U-Boot environment variables trying to make it boot to another distro. I already reset the environment variables several times but I forgot to save them.
