I see there is a new release of the VisionFive2 Software
What’s new
- Support JH7110 SDK v5.4.4;
- Support VisionFive2 v1.2A & 1.3B SBC;
- Support Linux Kernel 5.15.0;
- Add OV4689 sensor driver;
- Add auto flow control for UART;
- Add 2560x1080 and 1600x720 resolution for HDMI display;
- Add USB host function in U-Boot;
- Supported mirror mode / primary screen setting under Weston desktop;
- Add dynamically adjust the CMA size;
Note:
Please do not upgrade u-boot/spl for 8GB DDR VisionFive2 since CMA will not allocated successfully under Debian image 202306;
Fixed Issues
- Segmentation fault when running Khronos CTS Vulkan;
- HDMI hotplug issue when runing Weston desktop;
- Console white screen issue for HDMI display;
- Adjusted eMMC flash mode from
High-Speed@50MHz@1.8VtoHS200@50MHz@1.8Vfor eMMC boot issue;
Known Issues
Only 22.05K/44.1K audio through PWMDAC are obviously out of sync when playing video/audio file;
Camera image cannot be output to MIPI LCD via v4l2test command;
Some TF cards may have compatibility issues;
Segmentation fault when running unit tests in DDK 1.19;
OpenCL CTS segmentation fault in DDK 1.19;
