I’m using the latest official Debian Wayland image with kernel 6.6.20.
vkcube fails because it can’t find the VK_KHR_swapchain_extension :
Selected GPU 0: PowerVR B-Series BXE-4-32, type: IntegratedGpu
vkEnumerateDeviceExtensionProperties failed to find the VK_KHR_swapchain extension.
Do you have a compatible Vulkan installable client driver (ICD) installed?
Please look at the Getting Started guide for additional information.
Here is the beginning of the vulkaninfo output:
VULKANINFO
Vulkan Instance Version: 1.0.231
Instance Extensions: count = 7
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_KHR_device_group_creation : extension revision 1
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
Layers:
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
PowerVR B-Series BXE-4-32 (ID: 0)
subsetAllocation = 0
Present Capabilities = Group does not support VK_KHR_device_group, skipping printing present capabilities
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4206817 (1.3.225)
driverVersion = 6345021 (0x60d13d)
vendorID = 0x1010
deviceID = 0x36054182
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = PowerVR B-Series BXE-4-32
pipelineCacheUUID = 3dd16000-2432-0036-00b6-00b601b66400
I have tried installing all the extra packages from the setup guide, as well as a fresh install with no changes/tweaks. The same thing happens in either case.
Firefox registers the GPU with GLES, and OpenCL also seems to be working as expected.
Any ideas?
