VF2 v3.0.4 crashes on boot
Hello i´m using the debian image and i compile the new kernel tag, but its crashes on boot… any help?
[ 0.000000] Linux version 5.15.0+ (user@starfive) (gcc (Debian 12.2.0-10) 12.2.0, GNU ld (GNU Binutils for Debian) 2.39.50.20221224) #2 SMP Mon Jun 5 20:22:46 UTC 2023
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] earlycon: uart0 at MMIO32 0x0000000010000000 (options ‘115200’)
[ 0.000000] printk: bootconsole [uart0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000023fffffff]
[ 0.000000] SBI specification v1.0 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10002
[ 0.000000] SBI SRST extension detected
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] percpu: Embedded 18 pages/cpu s34024 r8192 d31512 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975
[ 0.000000] Kernel command line: root=/dev/mmcblk1p4 root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Unknown command line parameters: stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:all(pattern), heap alloc:off, heap free:off
[ 0.000000] Memory: 7580644K/8386560K available (10050K kernel code, 4991K rwdata, 4096K rodata, 2197K init, 619K bss, 281628K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] random: get_random_bytes called from start_kernel+0x4d6/0x6f2 with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.008999] clocksource: timer@13050000.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.020322] clocksource: timer@13050000.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.031644] clocksource: timer@13050000.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.042966] clocksource: timer@13050000.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.054500] Console: colour dummy device 80x25
[ 0.060766] printk: console [tty0] enabled
[ 0.065321] Calibrating delay loop (skipped), value calculated using timer frequency… 8.00 BogoMIPS (lpj=40000)
[ 0.076546] pid_max: default: 32768 minimum: 301
[ 0.081895] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.090386] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.100710] ASID allocator disabled
[ 0.104647] rcu: Hierarchical SRCU implementation.
[ 0.110099] EFI services will not be available.
[ 0.115491] smp: Bringing up secondary CPUs …
[ 0.122164] smp: Brought up 1 node, 4 CPUs
[ 0.128675] devtmpfs: initialized
[ 0.140554] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.151421] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.172156] pinctrl core: initialized pinctrl subsystem
[ 0.178825] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.186062] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.186410] cpuidle: using governor menu
[ 0.221692] platform soc:dsi-output: Fixing up cyclic dependency with 29400000.dc8200
[ 0.230885] platform 295d0000.mipi: Fixing up cyclic dependency with soc:dsi-output
[ 0.239739] platform 29590000.hdmi: Fixing up cyclic dependency with 29400000.dc8200
[ 0.260173] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.267558] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.278652] vgaarb: loaded
[ 0.281885] SCSI subsystem initialized
[ 0.286380] usbcore: registered new interface driver usbfs
[ 0.292458] usbcore: registered new interface driver hub
[ 0.298413] usbcore: registered new device driver usb
[ 0.304215] mc: Linux media interface: v0.10
[ 0.308948] videodev: Linux video capture interface: v2.00
[ 0.315198] Advanced Linux Sound Architecture Driver Initialized.
[ 0.322316] Bluetooth: Core ver 2.22
[ 0.326276] NET: Registered PF_BLUETOOTH protocol family
[ 0.332132] Bluetooth: HCI device and connection manager initialized
[ 0.339130] Bluetooth: HCI socket layer initialized
[ 0.344523] Bluetooth: L2CAP socket layer initialized
[ 0.350093] Bluetooth: SCO socket layer initialized
[ 0.355794] clocksource: Switched to clocksource riscv_clocksource
[ 0.362842] FS-Cache: Loaded
[ 0.373444] NET: Registered PF_INET protocol family
[ 0.379787] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.395751] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 0.405505] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.415075] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.425754] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.433238] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.441300] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.450019] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.456826] RPC: Registered named UNIX socket transport module.
[ 0.463352] RPC: Registered udp transport module.
[ 0.468549] RPC: Registered tcp transport module.
[ 0.473725] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.481693] PCI: CLS 0 bytes, default 64
[ 0.486425] Unpacking initramfs…
[ 0.487015] Initialise system trusted keyrings
[ 0.495255] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[ 0.508711] NFS: Registering the id_resolver key type
[ 0.514308] Key type id_resolver registered
[ 0.518953] Key type id_legacy registered
[ 0.523486] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.530905] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.539159] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.544246] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.551506] fuse: init (API version 7.34)
[ 0.595623] NET: Registered PF_ALG protocol family
[ 0.600961] Key type asymmetric registered
[ 0.605481] Asymmetric key parser ‘x509’ registered
[ 0.610996] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.619185] io scheduler mq-deadline registered
[ 0.624189] io scheduler kyber registered
[ 0.732482] clk-starfive-jh7110 13020000.clock-controller: starfive JH7110 clkgen init successfully.
[ 0.743970] L2CACHE: DataError @ 0x00000000.08040110
[ 0.749558] L2CACHE: DataFail @ 0x00000000.0804005B
[ 0.755037] L2CACHE: No. of Banks in the cache: 8
[ 0.760259] L2CACHE: No. of ways per bank: 16
[ 0.765075] L2CACHE: Sets per bank: 256
[ 0.769333] L2CACHE: Bytes per cache block: 64
[ 0.774248] L2CACHE: Index of the largest way enabled: 15
[ 0.780581] jh7110-pmu 17030000.power-controller: registered 8 power domains
[ 0.853955] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.877923] loop: module loaded
[ 0.883406] cadence-qspi 13010000.spi: Failed to get clk ‘clk_src’: -2
[ 0.890677] cadence-qspi 13010000.spi: cadence_quadspi_clk_init: failed to get qspi clocks
[ 0.899856] cadence-qspi: probe of 13010000.spi failed with error -2
[ 0.908060] libphy: Fixed MDIO Bus: probed
[ 0.914161] CAN device driver interface
[ 0.919104] starfive-eth-plat 16030000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.930634] starfive-eth-plat 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 0.938967] starfive-eth-plat 16030000.ethernet: DWMAC4/5
[ 0.945041] starfive-eth-plat 16030000.ethernet: DMA HW capability register supported
[ 0.953728] starfive-eth-plat 16030000.ethernet: RX Checksum Offload Engine supported
[ 0.962408] starfive-eth-plat 16030000.ethernet: Wake-Up On Lan supported
[ 0.970029] starfive-eth-plat 16030000.ethernet: TSO supported
[ 0.976499] starfive-eth-plat 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.985752] starfive-eth-plat 16030000.ethernet: Enabled Flow TC (entries=1)
[ 0.993563] starfive-eth-plat 16030000.ethernet: TSO feature enabled
[ 1.000601] starfive-eth-plat 16030000.ethernet: Using 40 bits DMA width
[ 1.341315] Freeing initrd memory: 10960K
[ 1.604178] libphy: stmmac: probed
[ 1.607998] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.618959] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.631178] starfive-eth-plat 16040000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.642623] starfive-eth-plat 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 1.650913] starfive-eth-plat 16040000.ethernet: DWMAC4/5
[ 1.656995] starfive-eth-plat 16040000.ethernet: DMA HW capability register supported
[ 1.665640] starfive-eth-plat 16040000.ethernet: RX Checksum Offload Engine supported
[ 1.674298] starfive-eth-plat 16040000.ethernet: Wake-Up On Lan supported
[ 1.681865] starfive-eth-plat 16040000.ethernet: TSO supported
[ 1.688330] starfive-eth-plat 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.697582] starfive-eth-plat 16040000.ethernet: Enabled Flow TC (entries=1)
[ 1.705365] starfive-eth-plat 16040000.ethernet: TSO feature enabled
[ 1.712388] starfive-eth-plat 16040000.ethernet: Using 40 bits DMA width
[ 1.974393] libphy: stmmac: probed
[ 1.978209] YT8531 Gigabit Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 1.989180] YT8531 Gigabit Ethernet stmmac-1:01: attached PHY driver (mii_bus:phy_addr=stmmac-1:01, irq=POLL)
[ 2.001777] Intel(R) Wireless WiFi driver for Linux
[ 2.009589] cdns3-starfive 10210000.usbdrd: usb mode 2 2.0 probe success
[ 2.017890] usbcore: registered new interface driver uas
[ 2.023811] usbcore: registered new interface driver usb-storage
[ 2.046255] starfive-rtc 17040000.rtc: registered as rtc0
[ 2.052242] starfive-rtc 17040000.rtc: setting system clock to 2001-01-01T00:00:00 UTC (978307200)
[ 2.062315] i2c_dev: i2c /dev entries driver
[ 2.067597] usbcore: registered new interface driver uvcvideo
[ 2.085825] thermal thermal_zone0: failed to read out thermal zone (-110)
[ 2.093976] starfive-wdt 13070000.wdog: Heartbeat: timeout=15, count/2=180000000 (0aba9500)
[ 2.103774] Bluetooth: HCI UART driver ver 2.3
[ 2.108711] Bluetooth: HCI UART protocol H4 registered
[ 2.115110] sdhci: Secure Digital Host Controller Interface driver
[ 2.121974] sdhci: Copyright(c) Pierre Ossman
[ 2.126830] Synopsys Designware Multimedia Card Interface Driver
[ 2.133784] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.141249] jh7110-sec 16000000.crypto: Unable to request sec_m dma channel in DMA channel
[ 2.150420] jh7110-sec 16000000.crypto: Cannot initial dma chan
[ 2.157267] usbcore: registered new interface driver usbhid
[ 2.163435] usbhid: USB HID core driver
[ 2.167931] riscv-pmu-sbi: SBI PMU extension is available
[ 2.173920] riscv-pmu-sbi: 16 firmware and 4 hardware counters
[ 2.180398] riscv-pmu-sbi: Perf sampling/filtering is not supported as sscof extension is not available
[ 2.191175] usbcore: registered new interface driver snd-usb-audio
[ 2.206853] NET: Registered PF_INET6 protocol family
[ 2.213672] Segment Routing with IPv6
[ 2.217779] In-situ OAM (IOAM) with IPv6
[ 2.222239] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.229425] NET: Registered PF_PACKET protocol family
[ 2.235017] can: controller area network core
[ 2.239939] NET: Registered PF_CAN protocol family
[ 2.245242] can: raw protocol
[ 2.248536] can: broadcast manager protocol
[ 2.253173] can: netlink gateway - max_hops=1
[ 2.258267] Bluetooth: RFCOMM TTY layer initialized
[ 2.263670] Bluetooth: RFCOMM socket layer initialized
[ 2.269401] Bluetooth: RFCOMM ver 1.11
[ 2.273559] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.279438] Bluetooth: BNEP filters: protocol multicast
[ 2.285219] Bluetooth: BNEP socket layer initialized
[ 2.290771] lib80211: common routines for IEEE802.11 drivers
[ 2.297220] 9pnet: Installing 9P2000 support
[ 2.302001] Key type dns_resolver registered
[ 2.307588] Loading compiled-in X.509 certificates
[ 2.350736] starfive_jh7110-pinctrl 13040000.gpio: SiFive GPIO chip registered 64 GPIOs
[ 2.360374] starfive_jh7110-pinctrl 17020000.gpio: SiFive GPIO chip registered 4 GPIOs
[ 2.369381] pl08xdmac 16008000.sec_dma: initialized 8 virtual memcpy channels
[ 2.377302] pl08xdmac 16008000.sec_dma: initialized 16 virtual slave channels
[ 2.387000] debugfs: Directory ‘16008000.sec_dma’ with parent ‘dmaengine’ already present!
[ 2.396196] pl08xdmac 16008000.sec_dma: DMA: PL080 rev0 at 0x16008000 irq 23
[ 2.404238] ssp-pl022 10060000.spi: ARM PL022 driver for StarFive SoC platform, device ID: 0x00041022
[ 2.414470] ssp-pl022 10060000.spi: mapped registers from 0x0000000010060000 to (ptrval)
[ 2.424641] ssp-pl022 10060000.spi: Requested frequency: 10000000 Hz is unsupported,select by default 8250000 Hz
[ 2.436305] ssp-pl022 10060000.spi: will use autosuspend for runtime pm, delay 100ms
[ 2.446314] i2c 2-0045: Fixing up cyclic dependency with 295d0000.mipi
[ 2.453799] seeed_panel 2-0045: Unknown Atmel firmware revision: 0x00
[ 2.461148] tinker_ft5406 2-0038: Address = 0x38
[ 2.466264] tinker_ft5406 2-0038: width = 800, height = 480, reverse = 1
[ 2.473800] tinker_ft5406 2-0038: i2c read error, -121
[ 2.479496] tinker_ft5406 2-0038: Checking touch ic failed
[ 2.485556] tinker_ft5406: probe of 2-0038 failed with error -121
[ 2.492497] i2c 2-0019: Fixing up cyclic dependency with 295d0000.mipi
[ 2.500631] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator
[ 2.508579] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator
[ 2.635952] Goodix-TS 2-0014: i2c test failed attempt 1: -121
[ 2.675952] Goodix-TS 2-0014: i2c test failed attempt 2: -121
[ 2.715816] Goodix-TS 2-0014: I2C communication failure: -121
[ 2.722335] Goodix-TS: probe of 2-0014 failed with error -121
[ 2.729643] at24 5-0050: supply vcc not found, using dummy regulator
[ 2.737476] at24 5-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 2.746836] axp15060-regulator 5-0036: Register mipi_0p9 done! vol range:900 ~ 900 mV
[ 2.756980] axp15060-regulator 5-0036: Register hdmi_1p8 done! vol range:1800 ~ 1800 mV
[ 2.766440] axp15060-regulator 5-0036: Register sdio_vdd done! vol range:0 ~ 0 mV
[ 2.776198] axp15060-regulator 5-0036: Register hdmi_0p9 done! vol range:900 ~ 900 mV
[ 2.785416] axp15060-regulator 5-0036: Register vcc_3v3 done! vol range:0 ~ 0 mV
[ 2.795124] axp15060-regulator 5-0036: Register cpu_vdd done! vol range:500 ~ 1540 mV
[ 2.804630] i2c 6-0010: Fixing up cyclic dependency with 19800000.vin_sysctl
[ 2.812858] imx219 6-0010: supply VANA not found, using dummy regulator
[ 2.820338] imx219 6-0010: supply VDIG not found, using dummy regulator
[ 2.827752] imx219 6-0010: supply VDDL not found, using dummy regulator
[ 2.849769] imx219 6-0010: failed to read chip id 219
[ 2.855552] imx219: probe of 6-0010 failed with error -5
[ 2.864136] pcie_plda 2b000000.pcie: Failed to get reset-gpio.
[ 2.870627] pcie_plda 2b000000.pcie: Init gpio failed
[ 2.876229] pcie_plda: probe of 2b000000.pcie failed with error -22
[ 2.885936] pcie_plda 2c000000.pcie: Failed to get reset-gpio.
[ 2.892388] pcie_plda 2c000000.pcie: Init gpio failed
[ 2.898003] pcie_plda: probe of 2c000000.pcie failed with error -22
[ 2.919513] clk-starfive-jh7110-vout 295c0000.clock-controller: starfive JH7110 clk_vout init successfully.
[ 2.942184] clk-starfive-jh7110-isp 19810000.clock-controller: starfive JH7110 clk_isp init successfully.
[ 2.953480] dw_axi_dmac_platform 16050000.dma-controller: DesignWare AXI DMA Controller, 4 channels
[ 2.964582] printk: console [ttyS0] disabled
[ 2.989558] 10000000.serial: ttyS0 at MMIO 0x10000000 (irq = 17, base_baud = 1500000) is a 16550A
[ 2.999434] printk: console [ttyS0] enabled
[ 3.008247] printk: bootconsole [uart0] disabled
[ 3.018650] jh7110-vin 19800000.vin_sysctl: stfcamss probe enter!
[ 3.026884] jh7110-vin 19800000.vin_sysctl: stfcamss probe success!
[ 3.044291] dwmmc_starfive 16010000.sdio0: IDMAC supports 32-bit address mode.
[ 3.044579] dwmmc_starfive 16020000.sdio1: IDMAC supports 32-bit address mode.
[ 3.051630] dwmmc_starfive 16010000.sdio0: Using internal DMA controller.
[ 3.051674] jh7110-sec 16000000.crypto: will run requests pump with realtime priority
[ 3.054017] jh7110-sec 16000000.crypto: Initialized
[ 3.054774] starfive-i2s 120b0000.i2stx_4ch0: designware: play supported
[ 3.054780] starfive-i2s 120b0000.i2stx_4ch0: designware: i2s master mode supported
[ 3.054893] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe begin
[ 3.054899] sf-mipi-dphy-tx 295e0000.mipi-dphy: ===> sf_dphy_probe enter, 445
[ 3.054979] sf-mipi-dphy-tx 295e0000.mipi-dphy: control ECO
[ 3.054991] sf-mipi-dphy-tx 295e0000.mipi-dphy: supply mipi_1p8 not found, using dummy regulator
[ 3.055184] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe end
[ 3.055302] cdns-dsi 295d0000.mipi: dsi_sys_clk = 297000000
[ 3.055437] cdns-dsi 295d0000.mipi: starfive dsi bind end
[ 3.056802] of_cfs_init
[ 3.056826] of_cfs_init: OK
[ 3.057148] starfive-pwmdac 100b0000.pwmdac: clk_apb0 = 49500000, clk_pwmdac_apb = 49500000, clk_pwmdac_core = 4068493
[ 3.057436] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.058834] dwmmc_starfive 16020000.sdio1: Using internal DMA controller.
[ 3.065623] dwmmc_starfive 16010000.sdio0: Version ID is 290a
[ 3.073480] dwmmc_starfive 16020000.sdio1: Version ID is 290a
[ 3.073521] dwmmc_starfive 16020000.sdio1: DW MMC controller at irq 30,32 bit host data width,32 deep fifo
[ 3.078407] dwmmc_starfive 16010000.sdio0: DW MMC controller at irq 29,32 bit host data width,32 deep fifo
[ 3.085299] mmc_host mmc1: card is polling.
[ 3.092930] mmc_host mmc0: card is non-removable.
[ 3.170928] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.214809] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.223467] cfg80211: failed to load regulatory.db
[ 3.315902] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 3.385919] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 3.569239] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 50000000Hz, actual 49500000HZ div = 2)
[ 3.579384] mmc1: new high speed SDHC card at address 0007
[ 3.586676] mmcblk1: mmc1:0007 SD32G 29.0 GiB
[ 3.605601] mmcblk1: p1 p2 p3 p4
[ 3.612164] starfive soc:display-subsystem: bound 29400000.dc8200 (ops 0xffffffff80e7b1d0)
[ 3.620479] innohdmi-starfive 29590000.hdmi: inno hdmi bind begin
[ 3.627840] innohdmi-starfive 29590000.hdmi: [drm:inno_hdmi_bind] ERROR cannot get hpd gpio property
[ 3.637189] Kernel BUG [#1]
[ 3.639989] Modules linked in:
[ 3.643050] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 5.15.0+ #2
[ 3.649060] Hardware name: StarFive VisionFive V2 (DT)
[ 3.654202] epc : _regulator_put+0x14a/0x14e
[ 3.658483] ra : regulator_put+0x26/0x3c
[ 3.662498] epc : ffffffff8040c95e ra : ffffffff8040c988 sp : ffffffd00400b9e0
[ 3.669735] gp : ffffffff815045a8 tp : ffffffe0bff40000 t0 : ffffffd00400b648
[ 3.676963] t1 : 0000000000000002 t2 : 0000000000000000 s0 : ffffffd00400ba10
[ 3.684200] s1 : ffffffe0c30efa80 a0 : ffffffe0c30efa80 a1 : 0000000000000115
[ 3.691437] a2 : 0000000000000000 a3 : ffffffe1f8999590 a4 : 0000000000000000
[ 3.698673] a5 : 0000000000000001 a6 : 0000000200000022 a7 : ffffffe0c30eaf40
[ 3.705910] s2 : ffffffff814a3348 s3 : ffffffe0c0638810 s4 : ffffffd00400ba48
[ 3.713147] s5 : 0000000000000009 s6 : ffffffe0c2804000 s7 : fffffffffffffffe
[ 3.720383] s8 : ffffffff814adbb8 s9 : 0000000000000000 s10: 0000000000000000
[ 3.727620] s11: 0000000000000000 t3 : 0000000007200720 t4 : 0000000000000001
[ 3.734856] t5 : ffffffff81044448 t6 : 6720647068207465
[ 3.740172] status: 0000000200000120 badaddr: 0000000000000000 cause: 0000000000000003
[ 3.748105] _regulator_put+0x14a/0x14e
[ 3.753685] regulator_put+0x26/0x3c
[ 3.759000] devm_regulator_release+0xe/0x16
[ 3.765011] devres_release_group+0xa2/0x102
[ 3.771024] component_bind_all+0xdc/0x1b6
[ 3.776866] vs_drm_bind+0x76/0x112
[ 3.782101] try_to_bring_up_master+0x102/0x140
[ 3.788377] component_master_add_with_match+0xc4/0x104
[ 3.795347] vs_drm_platform_probe+0x12c/0x19c
[ 3.801536] platform_probe+0x4e/0x92
[ 3.806940] really_probe.part.0+0x66/0x232
[ 3.812867] __driver_probe_device+0x70/0xde
[ 3.818877] driver_probe_device+0x2c/0xb0
[ 3.824718] __driver_attach+0x60/0xf4
[ 3.830211] bus_for_each_dev+0x6e/0xae
[ 3.835789] driver_attach+0x1a/0x22
[ 3.835806] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 300000Hz, actual 300000HZ div = 330)
[ 3.841104] bus_add_driver+0xe6/0x198
[ 3.841110] driver_register+0x50/0xe4
[ 3.841116] __platform_driver_register+0x1c/0x24
[ 3.868179] vs_drm_init+0x34/0x56
[ 3.873325] do_one_initcall+0x4e/0x178
[ 3.878905] kernel_init_freeable+0x1a8/0x20a
[ 3.885005] kernel_init+0x1e/0x104
[ 3.890237] ret_from_exception+0x0/0xc
[ 3.895850] —[ end trace d8bf584a996f34f9 ]—
[ 3.900477] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 3.908148] SMP: stopping secondary CPUs
[ 3.912083] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]—
looks like you didnt get the updated dtb files for the new kernel
