By coincidence, someone’s just posted a test of different TIMS for coolers. There are some TIMs that perform significantly worse than ketchup or toothpaste, about the same as a slice of cheese or potato.
Some pushpins don’t - if you have some that are quite low-profile then they can sit under the M.2 drive comfortably. I did install the pushpins without the M.2 drive installed so that I didn’t accidentally “punch through” to it when squeezing the pushpins in.
In the image you can see there’s at least a couple of mm clearance between the pins and the M.2 drive:
Great. And that’s the Odroid XU4 fan you mention above? Can this be purchased independently?
It is.
It can be bought standalone, yeah - I got mine from https://www.odroid.co.uk/odroid-accessories/odroid-cooling/odroid-xu4-blue-fan but it also seems to be available here: https://www.hardkernel.com/shop/cooling-fan-xu4-blue/ (not sure where you’re located - in the UK I ordered mine and got it the following day).
Went ahead and ordered the XU4Q one (fanless, taller). Elsewhere, due to location/shipping.
It’ll likely take a couple of weeks to arrive, but I’ll be sure to do some load testing without and then with.
Fingers crossed about the mount tabs not being gigantic.
Update: XU4Q heatsink arrived. This is a fully passive solution.
I used Artic MX-4 as thermal interface.
Test: nbench, 4 threads, infinite loop: while [ 1 ];do ./nbench;done
Ambient temp: 24C for both tests.
Time: checked both at 15m mark.
From /sys/class/hwmon/hwmon0/temp1_input
w/o heatsink: 72282 (72.3C)
w/ heatsink: 55807 (55.8C)
It seems to do the job, no fan needed.
There is some 1-2mm clearance, eyeballed, from the height of the M.2 screw to the heatsink retaining clips.
edit: I have now installed an SSD (Patriot P300) w/o issue.
In the meantime, I ordered a Heat sink with fan for Odroid XU-4 - blue for each of my two VF2s and they were delivered within four days. And Botland sells cheaper and without penalty fee. I have combined the heat sinks with one NF-A4x10 5V PWM each, which I am still controlling with an Adafruit EMC2101 I2C PC Fan Controller on a Raspberry Pico W for the time being.
But I want to try if I can control the PWM fan directly on GPIO46 using Kernel driver pwm-fan.
VisionFive 2 40-Pin GPIO Header User Guide
Intel spec for 4-Wire PWM Controlled Fans
I would like to warn you not to connect normal 5V fans with two pins directly to a CPU, only real PWM fans with separate power supply and PWM control input may be used!
I had specially ordered the same cooler that you use, but my M.2 drive was still bending, although now much less. After I took another look at your photo, I realised that your M.2 drive is not equipped on the underside.
I wouldn’t have ordered the 512GB NVMe with cache for the VF2 at Christmas if my employer hadn’t given me an Amazon voucher. Now I’ve ordered a 256GB NVMe without cache because it’s single-sided and this one doesn’t bend anymore.
