我看到upstream目前只能支持beagleV的板子,所以都是同一款soc
然后我试了5.18.3的内核,分析在visionfive上无法启动:卡在这里了
[ 0.617972] 9pnet: Installing 9P2000 support
[ 0.622429] Key type dns_resolver registered
[ 0.627667] debug_vm_pgtable: [debug_vm_pgtable ]: Validating architecture page table helpers
应该还不行
The kernel will boot and set up clocks, resets, gpio and serial port, but it can’t access mmc, usb, ethernet or any other peripheral with its own dma。
Esmil add a minimal root filesystem in an initrd, and a defconfig file that will build it into the kernel: [NOT-FOR-UPSTREAM] Add minimal starlight_defconfig · esmil/linux@d2f0dd1 · GitHub
Ok,thanks
