1 DOWNLOAD SDIMAGE from github (about 800MB)
2 LOAD SDIMAGE into a sdcard
3 Plug in the ethernet cable on the “middle” ethernet port. The one on the edge does not give you a DHCP address.
3 Insert the microsd card and TURN ON the VF2 board
4 LOOK for the ip of the VF2 board (I used fing from my mobile phone)
5 With a SSH CLIENT use the ip of the VF2 board and log in with user root and password starfive
6 DOWNLOAD the updated U-Boot and SPL files from github and load them on a usb stick
7 CONNECT the usb stick to the VF2 board and mount it in a folder
8 UPDATE the firmware from the terminal
9 VERIFY with the command cat /proc/mtd and check the output that looks like this:
dev: size erase size name
mtd0:00020000 00001000 “spl”
mtd1:00300000 00001000 “uboot”
mtd2: 00100000 00001000 “date”
10 UPDATE spl with command
11 UPDATE u-boot with the command
you should see output like this
Erasing blocks: 32/32 (100%)
Writing data: 124k/124k (100%)
Verifying data: 124k/124k (100%)
Erasing blocks: 682/682 (100%)
Writing data: 2727k/2727k (100%)
Verifying data: 2727k/2727k (100%)
12 Shut down the vf2 board and you are ready to use the debian 69 image.
I wanted to share my experience with you because in other ways it is not so simple
