After mostly using simple applications I switched to a full KDE Plasma Wayland shell on my Yocto build today. I tried with a few QML based applications and can get all of them to a full UI freeze. The Kernel is still functional, but I have to restart the whole desktop to get out of this broken state. However, the GPU seems to stay in a very broken memory state, due to heavy artifacts on the screen.
Where should such problems be reported because this seems to be inside the proprietary GPU driver:
[ 103.389447] PVR_K: 179: ------------[ PVR DBG: START (High) ]------------
[ 103.396498] PVR_K: 179: OS kernel info: Linux 5.15.0 #1 SMP Mon Jun 19 07:38:34 UTC 2023 riscv64
[ 103.397473] systemd-journald[169]: Sent WATCHDOG=1 notification.
[ 103.405445] PVR_K: 179: DDK info: Rogue_DDK_Linux_WS rogueddk 1.19@6345021 (release) sf_7110
[ 103.420022] PVR_K: 179: Time now: 103420016us
[ 103.424475] PVR_K: 179: Services State: OK
[ 103.428721] PVR_K: 179: Server Errors: 0
[ 103.432758] PVR_K: 179: Connections Device ID:0(128) P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland,
[ 103.447944] PVR_K: 179: Connections Device ID:0(128) P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland, P334-V334-T334-kwin_wayland,
[ 103.463129] PVR_K: 179: Connections Device ID:0(128) P334-V334-T334-kwin_wayland, P337-V337-T337-ksplashqml, P379-V379-T379-Xwayland, P379-V379-T379-Xwayland, P379-V379-T379-Xwayland,
[ 103.479596] PVR_K: 179: Connections Device ID:0(128) P379-V379-T379-Xwayland, P379-V379-T379-Xwayland, P379-V379-T379-Xwayland, P395-V395-T395-plasmashell, P442-V442-T442-plasmashell,
[ 103.496080] PVR_K: 179: Connections Device ID:0(128) P442-V442-T442-plasmashell, P442-V442-T442-plasmashell, P442-V442-T442-plasmashell, P442-V442-T442-plasmashell,
[ 103.510913] PVR_K: 179: Connections Device ID:0(128) P442-V442-T442-plasmashell, P442-V442-T442-plasmashell, P442-V442-T452-QSGRenderThread, P442-V442-T452-QSGRenderThread,
[ 103.526434] PVR_K: 179: Connections Device ID:0(128) P442-V442-T452-QSGRenderThread, P442-V442-T452-QSGRenderThread, P442-V442-T452-QSGRenderThread, P442-V442-T470-QSGRenderThread,
[ 103.542626] PVR_K: 179: Connections Device ID:0(128) P442-V442-T470-QSGRenderThread, P442-V442-T470-QSGRenderThread, P442-V442-T470-QSGRenderThread, P442-V442-T477-QSGRenderThread,
[ 103.558844] PVR_K: 179: Connections Device ID:0(128) P442-V442-T477-QSGRenderThread, P442-V442-T477-QSGRenderThread, P442-V442-T477-QSGRenderThread, P479-V479-T479-elisa,
[ 103.574186] PVR_K: 179: Connections Device ID:0(128) P479-V479-T479-elisa, P479-V479-T479-elisa, P442-V442-T484-QSGRenderThread, P442-V442-T484-QSGRenderThread, P442-V442-T484-QSGRenderThread,
[ 103.591418] PVR_K: 179: Connections Device ID:0(128) P442-V442-T484-QSGRenderThread, P479-V479-T506-QSGRenderThread, P479-V479-T506-QSGRenderThread, P479-V479-T506-QSGRenderThread,
[ 103.607603] PVR_K: 179: Connections Device ID:0(128) P479-V479-T506-QSGRenderThread, P479-V479-T506-QSGRenderThread
[ 103.618143] PVR_K: 179: ------[ Driver Info ]------
[ 103.623111] PVR_K: 179: Comparison of UM/KM components: MATCHING
[ 103.629246] PVR_K: 179: KM Arch: 64 Bit
[ 103.633175] PVR_K: 179: UM Connected Clients: 64 Bit
[ 103.638259] PVR_K: 179: UM info: 1.19 @ 6345021 (release) build options: 0x80000810
[ 103.646115] PVR_K: 179: KM info: 1.19 @ 6345021 (release) build options: 0x00000810
[ 103.653948] PVR_K: 179: Window system: nulldrmws
[ 103.658682] PVR_K: 179: ------[ Server Thread Summary ]------
[ 103.664525] PVR_K: 179: pvr_defer_free : Running
[ 103.669444] PVR_K: 179: Number of deferred cleanup items Queued : 0
[ 103.677552] PVR_K: 179: Number of deferred cleanup items dropped after retry limit reached : 0
[ 103.687977] PVR_K: 179: pvr_device_wdg : Running
[ 103.694208] PVR_K: 179: ------[ RGX Device ID:0 Start ]------
[ 103.701439] PVR_K: 179: ------[ RGX Info ]------
[ 103.707523] PVR_K: 179: Device Node (Info): 0000000017fd10ac (00000000fa4a56f9)
[ 103.716292] PVR_K: 179: DevmemHistoryRecordStats - CBWC:0 MAC:3402 UMAC:1936 MRC:1683 UMRC:1256 TSC:6532 MAX:209715 CHD:14809
[ 103.729386] PVR_K: 179: RGX BVNC: 36.50.54.182 (rogue)
[ 103.735992] PVR_K: 179: RGX Device State: Active
[ 103.742046] PVR_K: 179: RGX Power State: OFF
[ 103.747815] PVR_K: 179: FW info: 1.19 @ 6345021 (release) build options: 0x80000810
[ 103.757012] PVR_K: 179: RGX FW State: OK (HWRState 0x00000001: HWR OK;)
[ 103.765077] PVR_K: 179: RGX FW Power State: RGXFWIF_POW_OFF (APM enabled: 24 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 24 total. Latency: 100 ms)
[ 103.779762] PVR_K: 179: RGX DVFS: 0 frequency changes. Current frequency: 593.935 MHz (sampled at 101639182836 ns). FW frequency: 594.000 MHz.
[ 103.793982] PVR_K: 179: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; Isolation group: 0; MTS off;
[ 103.805360] PVR_K: 179: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(3/3+0), 3D(1/1+0), CDM(0/0+0), RAY(0/0+0), TA2(0/0+0), FALSE(0,0,0,0,0,0,0)
[ 103.819309] PVR_K: 179: DM 0 (GP)
[ 103.824069] PVR_K: 179: DM 1 (HWRflags 0x00000000: working;)
[ 103.831203] PVR_K: 179: DM 2 (HWRflags 0x00000000: working;)
[ 103.838337] PVR_K: 179: Recovery 1: Core = 0, PID = 479 / elisa, frame = 72, HWRTData = 0xC012F200, EventStatus = 0x00000000, Guilty Lockup
[ 103.852491] PVR_K: 179: CRTimer = 0x0000003AEFB8, OSTimer = 103.303984755, CyclesElapsed = 44032
[ 103.863927] PVR_K: 179: PreResetTimeInCycles = 22272, HWResetTimeInCycles = 14336, FreelistReconTimeInCycles = 989952, TotalRecoveryTimeInCycles = 1026560
[ 103.880399] PVR_K: 179: BIF0 - FAULT:
[ 103.885873] PVR_K: 179: * MMU status (0x0000000000007001): PC = 7, Page Size = 0 (Page Table).
[ 103.896457] PVR_K: 179: * Request (0x00101480010d8010): MCU PDS USCA (-), Reading from 0x80010D8010.
[ 103.907575] PVR_K: 179: PCE for index 512 = 0x004881f1 and is valid
[ 103.915632] PVR_K: 179: PDE for index 8 = 0x0000000047037001 and is valid
[ 103.924210] PVR_K: 179: PTE for index 216 = 0x00000badbad00b88 and is not valid
[ 103.933339] PVR_K: 179: Device memory history for page fault address 0x80010D8010, PID: 479 (elisa, unregistered: 0) OS time: 103.907567500
[ 103.947649] PVR_K: 179: No matching Devmem History for fault address
[ 103.955982] PVR_K: 179: DevmemHistoryRecordStats - CBWC:0 MAC:3403 UMAC:1946 MRC:1683 UMRC:1256 TSC:6549 MAX:209715 CHD:14837
[ 103.969079] PVR_K: 179: Records Searched - PP:0 FP:0 NP:0
[ 103.976461] PVR_K: 179: Recovery 2: Core = 0, PID = 479 / elisa, frame = 75, HWRTData = 0xC012F500, EventStatus = 0x00000000, Innocent Lockup
[ 103.990771] PVR_K: 179: CRTimer = 0x0000003D1E53, OSTimer = 103.365622422, CyclesElapsed = 96000
[ 104.002222] PVR_K: 179: PreResetTimeInCycles = 39424, HWResetTimeInCycles = 14848, FreelistReconTimeInCycles = 1157376, TotalRecoveryTimeInCycles = 1211648
[ 104.018786] PVR_K: 179: BIF0 - FAULT:
[ 104.024245] PVR_K: 179: * MMU status (0x0000000000007001): PC = 7, Page Size = 0 (Page Table).
[ 104.034844] PVR_K: 179: * Request (0x00101480010d8010): MCU PDS USCA (-), Reading from 0x80010D8010.
[ 104.045954] PVR_K: 179: PCE for index 512 = 0x004881f1 and is valid
[ 104.054007] PVR_K: 179: PDE for index 8 = 0x0000000047037001 and is valid
[ 104.062613] PVR_K: 179: PTE for index 216 = 0x00000badbad00b88 and is not valid
[ 104.071727] PVR_K: 179: Device memory history for page fault address 0x80010D8010, PID: 479 (elisa, unregistered: 0) OS time: 104.045949000
[ 104.086037] PVR_K: 179: No matching Devmem History for fault address
[ 104.094356] PVR_K: 179: DevmemHistoryRecordStats - CBWC:0 MAC:3403 UMAC:1946 MRC:1683 UMRC:1256 TSC:6549 MAX:209715 CHD:14837
[ 104.107468] PVR_K: 179: Records Searched - PP:0 FP:0 NP:0
[ 104.114837] PVR_K: 179: Recovery 3: Core = 0, PID = 479 / elisa, frame = 76, HWRTData = 0xC012F200, EventStatus = 0x00000000, Guilty Lockup
[ 104.128987] PVR_K: 179: CRTimer = 0x00000040BB66, OSTimer = 103.467696999, CyclesElapsed = 52480
[ 104.140444] PVR_K: 179: PreResetTimeInCycles = 23296, HWResetTimeInCycles = 15872, FreelistReconTimeInCycles = 586752, TotalRecoveryTimeInCycles = 625920
[ 104.156830] PVR_K: 179: BIF0 - FAULT:
[ 104.162289] PVR_K: 179: * MMU status (0x0000000000003001): PC = 3, Page Size = 0 (Page Table).
[ 104.172888] PVR_K: 179: * Request (0x00101480010d8010): MCU PDS USCA (-), Reading from 0x80010D8010.
[ 104.183999] PVR_K: 179: PCE for index 512 = 0x004881f1 and is valid
[ 104.192064] PVR_K: 179: PDE for index 8 = 0x0000000047037001 and is valid
[ 104.200657] PVR_K: 179: PTE for index 216 = 0x00000badbad00b88 and is not valid
[ 104.209770] PVR_K: 179: Device memory history for page fault address 0x80010D8010, PID: 479 (elisa, unregistered: 0) OS time: 104.183993000
[ 104.224080] PVR_K: 179: No matching Devmem History for fault address
[ 104.232414] PVR_K: 179: DevmemHistoryRecordStats - CBWC:0 MAC:3403 UMAC:1946 MRC:1683 UMRC:1256 TSC:6549 MAX:209715 CHD:14837
[ 104.245512] PVR_K: 179: Records Searched - PP:0 FP:0 NP:0
[ 104.252879] PVR_K: 179: DM 3 (HWRflags 0x00000000: working;)
[ 104.260013] PVR_K: 179: Recovery 2: Core = 0, PID = 334 / kwin_wayland, frame = 0, HWRTData = 0xC002E380, EventStatus = 0x00000000, Innocent Lockup
[ 104.274842] PVR_K: 179: CRTimer = 0x0000003D1E94, OSTimer = 103.365650438, CyclesElapsed = 36352
[ 104.286295] PVR_K: 179: PreResetTimeInCycles = 22784, HWResetTimeInCycles = 14848, FreelistReconTimeInCycles = 1157376, TotalRecoveryTimeInCycles = 1195008
[ 104.302860] PVR_K: 179: BIF0 - FAULT:
[ 104.308333] PVR_K: 179: * MMU status (0x0000000000007001): PC = 7, Page Size = 0 (Page Table).
[ 104.318918] PVR_K: 179: * Request (0x00101480010d8010): MCU PDS USCA (-), Reading from 0x80010D8010.
[ 104.330029] PVR_K: 179: PCE for index 512 = 0x004881f1 and is valid
[ 104.338095] PVR_K: 179: PDE for index 8 = 0x0000000047037001 and is valid
[ 104.346687] PVR_K: 179: PTE for index 216 = 0x00000badbad00b88 and is not valid
[ 104.355801] PVR_K: 179: Device memory history for page fault address 0x80010D8010, PID: 479 (elisa, unregistered: 0) OS time: 104.330023500
[ 104.370111] PVR_K: 179: No matching Devmem History for fault address
[ 104.378445] PVR_K: 179: DevmemHistoryRecordStats - CBWC:0 MAC:3403 UMAC:1946 MRC:1683 UMRC:1256 TSC:6549 MAX:209715 CHD:14837
[ 104.391542] PVR_K: 179: Records Searched - PP:0 FP:0 NP:0
[ 104.398925] PVR_K: 179: DM 4 (HWRflags 0x00000000: working;)
[ 104.406044] PVR_K: 179: DM 5 (HWRflags 0x00000000: working;)
[ 104.413148] PVR_K: 179: DM 6 (HWRflags 0x00000000: working;)
[ 104.420283] PVR_K: 179: RGX Kernel CCB WO:0x45 RO:0x45
[ 104.426878] PVR_K: 179: RGX Firmware CCB WO:0x1E RO:0x1E
[ 104.433635] PVR_K: 179: RGX Kernel CCB commands executed = 14917
[ 104.441114] PVR_K: 179: RGX SLR: Forced UFO updates requested = 0
[ 104.448666] PVR_K: 179: RGX Errors: WGP:0, TRP:0
[ 104.454732] PVR_K: 179: Thread0: FW IRQ count = 25022
[ 104.461257] PVR_K: 179: Last sampled IRQ count in LISR = 25022
[ 104.468553] PVR_K: 179: FW System config flags = 0x00020010 (Ctx switch options: Medium CSW profile; Power Rascal/Dust;)
[ 104.480870] PVR_K: 179: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
[ 104.490327] PVR_K: 179: (!) RGX power is down. No registers dumped
[ 104.498052] PVR_K: 179: ------[ RGX FW Trace Info ]------
[ 104.504897] PVR_K: 179: Debug log type: none
[ 104.510642] PVR_K: 179: RGX FW thread 0: Trace buffer not yet allocated
[ 104.518713] PVR_K: 179: ------[ Full CCB Status ]------
[ 104.525402] PVR_K: 179: FWCtx 0xC002BDC0 (TQ_3D-P334-T334-kwin_wayland)
[ 104.533457] PVR_K: 179: `--<Empty>
[ 104.538511] PVR_K: 179: FWCtx 0xC0030CC0 (TQ_3D-P379-T379-Xwayland)
[ 104.546233] PVR_K: 179: `--<Empty>
[ 104.551260] PVR_K: 179: FWCtx 0xC0031D40 (TQ_3D-P442-T452-QSGRenderThre)
[ 104.559430] PVR_K: 179: `--<Empty>
[ 104.564458] PVR_K: 179: FWCtx 0xC012B300 (TQ_3D-P479-T506-QSGRenderThre)
[ 104.572629] PVR_K: 179: `--<Empty>
[ 104.577670] PVR_K: 179: FWCtx 0xC002B080 (TA-P334-T334-kwin_wayland)
[ 104.585479] PVR_K: 179: `--<Empty>
[ 104.590506] PVR_K: 179: FWCtx 0xC002B130 (3D-P334-T334-kwin_wayland)
[ 104.598329] PVR_K: 179: `--<Empty>
[ 104.603355] PVR_K: 179: FWCtx 0xC0030900 (TA-P379-T379-Xwayland)
[ 104.610831] PVR_K: 179: `--<Empty>
[ 104.615873] PVR_K: 179: FWCtx 0xC00309B0 (3D-P379-T379-Xwayland)
[ 104.623323] PVR_K: 179: `--<Empty>
[ 104.628376] PVR_K: 179: FWCtx 0xC0031000 (TA-P442-T442-plasmashell)
[ 104.636100] PVR_K: 179: `--<Empty>
[ 104.641127] PVR_K: 179: FWCtx 0xC00310B0 (3D-P442-T442-plasmashell)
[ 104.648864] PVR_K: 179: `--<Empty>
[ 104.653892] PVR_K: 179: FWCtx 0xC0031300 (TA-P442-T442-plasmashell)
[ 104.661630] PVR_K: 179: `--<Empty>
[ 104.666670] PVR_K: 179: FWCtx 0xC00313B0 (3D-P442-T442-plasmashell)
[ 104.674380] PVR_K: 179: `--<Empty>
[ 104.679435] PVR_K: 179: FWCtx 0xC0031600 (TA-P442-T452-QSGRenderThread)
[ 104.687505] PVR_K: 179: `--<Empty>
[ 104.692532] PVR_K: 179: FWCtx 0xC00316B0 (3D-P442-T452-QSGRenderThread)
[ 104.700615] PVR_K: 179: `--<Empty>
[ 104.705656] PVR_K: 179: FWCtx 0xC0031980 (TA-P442-T452-QSGRenderThread)
[ 104.713712] PVR_K: 179: `--<Empty>
[ 104.718766] PVR_K: 179: FWCtx 0xC0031A30 (3D-P442-T452-QSGRenderThread)
[ 104.726836] PVR_K: 179: `--<Empty>
[ 104.731865] PVR_K: 179: FWCtx 0xC0268000 (TA-P442-T470-QSGRenderThread)
[ 104.739947] PVR_K: 179: `--<Empty>
[ 104.744975] PVR_K: 179: FWCtx 0xC02680B0 (3D-P442-T470-QSGRenderThread)
[ 104.753057] PVR_K: 179: `--<Empty>
[ 104.758098] PVR_K: 179: FWCtx 0xC002EA00 (TA-P442-T470-QSGRenderThread)
[ 104.766168] PVR_K: 179: `--<Empty>
[ 104.771195] PVR_K: 179: FWCtx 0xC002EAB0 (3D-P442-T470-QSGRenderThread)
[ 104.779278] PVR_K: 179: `--<Empty>
[ 104.784305] PVR_K: 179: FWCtx 0xC0117000 (TA-P442-T477-QSGRenderThread)
[ 104.792389] PVR_K: 179: `--<Empty>
[ 104.797429] PVR_K: 179: FWCtx 0xC01170B0 (3D-P442-T477-QSGRenderThread)
[ 104.805499] PVR_K: 179: `--<Empty>
[ 104.810526] PVR_K: 179: FWCtx 0xC0117380 (TA-P442-T477-QSGRenderThread)
[ 104.818608] PVR_K: 179: `--<Empty>
[ 104.823635] PVR_K: 179: FWCtx 0xC0117430 (3D-P442-T477-QSGRenderThread)
[ 104.831719] PVR_K: 179: `--<Empty>
[ 104.836759] PVR_K: 179: FWCtx 0xC0129880 (TA-P442-T484-QSGRenderThread)
[ 104.844817] PVR_K: 179: `--<Empty>
[ 104.849871] PVR_K: 179: FWCtx 0xC0129930 (3D-P442-T484-QSGRenderThread)
[ 104.857941] PVR_K: 179: `--<Empty>
[ 104.862968] PVR_K: 179: FWCtx 0xC0129C40 (TA-P442-T484-QSGRenderThread)
[ 104.871052] PVR_K: 179: `--<Empty>
[ 104.876092] PVR_K: 179: FWCtx 0xC0129CF0 (3D-P442-T484-QSGRenderThread)
[ 104.884150] PVR_K: 179: `--<Empty>
[ 104.889203] PVR_K: 179: FWCtx 0xC012AB40 (TA-P479-T506-QSGRenderThread)
[ 104.897273] PVR_K: 179: `--<Empty>
[ 104.902300] PVR_K: 179: FWCtx 0xC012ABF0 (3D-P479-T506-QSGRenderThread)
[ 104.910384] PVR_K: 179: `--<Empty>
[ 104.910451] systemd-journald[169]: Data hash table of /run/log/journal/9d8de5dbfb3c41f2874f4a4fbd93980e/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation.
[ 104.915423] PVR_K: 179: FWCtx 0xC012B000 (TA-P479-T506-QSGRenderThread)
[ 104.915431] PVR_K: 179: `--<Empty>
[ 104.915438] PVR_K: 179: FWCtx 0xC012B0B0 (3D-P479-T506-QSGRenderThread)
[ 104.915446] PVR_K: 179: `--<Empty>
[ 104.915453] PVR_K: 179: ------[ RGX Device ID:0 End ]------
[ 104.915468] PVR_K: 179: ------[ Device ID: 128 - Phys Heaps ]------
[ 104.937958] systemd-journald[169]: /run/log/journal/9d8de5dbfb3c41f2874f4a4fbd93980e/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 104.945977] PVR_K: 179: 0x00000000d7ab4ecc -> PdMs: SYSMEM, Type: UMA, Usage Flags: 0x00000002 (, GPU_LOCAL), Refs: 11, Free Size: 2896089088B, Total Size: 4082970624B
[ 104.950989] systemd-journald[169]: Rotating...
[ 104.959065] PVR_K: 179: ------[ System Summary Device ID:0 ]------
[ 104.959073] PVR_K: 179: Device System Power State: ON
[ 104.965850] systemd-journald[169]: Reserving 333 entries in field hash table.
[ 104.971140] PVR_K: 179: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (1500ms,3600000ms)
[ 104.982307] systemd-journald[169]: Reserving 14563 entries in data hash table.
[ 104.994823] PVR_K: 179: ------[ AppHint Settings ]------
[ 104.994831] PVR_K: 179: Build Vars
[ 104.994839] PVR_K: 179: EnableTrustedDeviceAceConfig: N
[ 105.011730] systemd-journald[169]: Vacuuming...
[ 105.017042] PVR_K: 179: CleanupThreadPriority: 0x00000005
[ 105.017051] PVR_K: 179: WatchdogThreadPriority: 0x00000000
[ 105.017060] PVR_K: 179: HWPerfClientBufferSize: 0x000c0000
[ 105.025181] systemd-journald[169]: Vacuuming done, freed 0B of archived journals from /run/log/journal/9d8de5dbfb3c41f2874f4a4fbd93980e.
[ 105.031194] PVR_K: 179: DevmemHistoryBufSizeLog2: 0x0000000b
[ 105.046703] systemd-journald[169]: Failed to re-enable copy-on-write for /run/log/journal/9d8de5dbfb3c41f2874f4a4fbd93980e/system@3314aa2f415843b6ad52077993a324d5-0000000000005922-00060126ca2ad5c1.journal: Inappropriate ioctl for device, rewriting file
[ 105.049944] PVR_K: 179: DevmemHistoryMaxEntries: 0x00002710
[ 105.157227] PVR_K: 179: Module Params
[ 105.162498] PVR_K: 179: none
[ 105.167197] PVR_K: 179: Debug Info Params
[ 105.172834] PVR_K: 179: CacheOpConfig: 0x00000008
[ 105.179357] PVR_K: 179: Debug Info Params Device ID: 0
[ 105.186134] PVR_K: 179: none
[ 105.190809] PVR_K: 179: ------[ HTB Log state: Off ]------
[ 105.197766] PVR_K: 179: ------[ Active Sync Checkpoints ]------
[ 105.205132] PVR_K: 179: (SyncCP Counts: InUse:79 Max:138)
[ 105.212037] sw: RM_SWTimeline-kwin_wayland-334 @0 cur=0
[ 105.218602] sw: RM_SWTimeline-Xwayland-379 @0 cur=0
[ 105.224841] sw: RM_SWTimeline-plasmashell-442 @0 cur=0
[ 105.231366] sw: RM_SWTimeline-elisa-479 @0 cur=0
[ 105.237358] ------[ Native Fence Sync: timelines ]------
[ 105.244032] foreign_sync: @0 ctx=3 refs=1
[ 105.249429] rogue-ta3d: @0 ctx=6 refs=1
[ 105.254629] rogue-ta3d: @4434 ctx=7 refs=12
[ 105.260190] @2836: (++) refs=1 fwaddr=0xc0029019 enqueue=2 status=Signalled 2836-update fence
[ 105.270168] @2948: (++) refs=1 fwaddr=0xc00292c1 enqueue=2 status=Signalled 2948-update fence
[ 105.280146] @3000: (++) refs=1 fwaddr=0xc00293d9 enqueue=2 status=Signalled 3000-update fence
[ 105.290124] @3796: (++) refs=1 fwaddr=0xc0029229 enqueue=2 status=Signalled 3796-update fence
[ 105.300102] @3822: (++) refs=1 fwaddr=0xc0029301 enqueue=2 status=Signalled 3822-update fence
[ 105.310080] @4068: (++) refs=1 fwaddr=0xc0029161 enqueue=2 status=Signalled 4068-update fence
[ 105.320058] @4072: (++) refs=1 fwaddr=0xc0029071 enqueue=2 status=Signalled 4072-update fence
[ 105.330036] @4116: (++) refs=1 fwaddr=0xc0029371 enqueue=2 status=Signalled 4116-update fence
[ 105.340015] @4127: (++) refs=1 fwaddr=0xc0029141 enqueue=2 status=Signalled 4127-update fence
[ 105.349993] @4430: (++) refs=2 fwaddr=0xc00291b9 enqueue=2 status=Signalled 4430-update fence
[ 105.359972] @4432: (++) refs=1 fwaddr=0xc0029289 enqueue=2 status=Signalled 4432-update fence
[ 105.369949] @4433: (++) refs=1 fwaddr=0xc00293a1 enqueue=1 status=Signalled 4433-update fence
[ 105.379941] V3-kwin_wayland-334: @10111 ctx=8 refs=1
[ 105.386266] @36: (++) refs=1 fwaddr=0xc00291c9 enqueue=1 status=Signalled 36-es3_DoKickTA_35
[ 105.396171] P3-kwin_wayland-334: @10111 ctx=9 refs=1
[ 105.402497] @36: (++) refs=1 fwaddr=0xc00291b1 enqueue=1 status=Signalled 36-es3_DoKick3D_35
[ 105.412401] rogue-tq3d: @1256 ctx=10 refs=1
[ 105.417958] rogue-ta3d: @0 ctx=130 refs=1
[ 105.423331] rogue-tq3d: @0 ctx=131 refs=1
[ 105.428730] rogue-ta3d: @0 ctx=3080 refs=1
[ 105.434190] rogue-ta3d: @0 ctx=3084 refs=1
[ 105.439677] rogue-ta3d: @35 ctx=3426 refs=3
[ 105.445223] @33: (++) refs=1 fwaddr=0xc0029251 enqueue=47 status=Signalled 33-update fence
[ 105.454942] @34: (++) refs=1 fwaddr=0xc0029329 enqueue=93 status=Signalled 34-update fence
[ 105.464674] rogue-ta3d: @0 ctx=3427 refs=1
[ 105.470144] rogue-tq3d: @0 ctx=3449 refs=1
[ 105.475617] V3-smashell-QSGRenderThread-442: @44 ctx=3471 refs=6
[ 105.482984] @10: (++) refs=1 fwaddr=0xc00292d9 enqueue=1 status=Signalled 10-es3_DoKickTA_10
[ 105.492875] @12: (++) refs=1 fwaddr=0xc0029361 enqueue=1 status=Signalled 12-es3_DoKickTA_11
[ 105.502768] @35: (++) refs=1 fwaddr=0xc00292f1 enqueue=1 status=Signalled 35-es3_DoKickTA_311
[ 105.512746] @42: (++) refs=1 fwaddr=0xc00293c9 enqueue=1 status=Signalled 42-es3_DoKickTA_618
[ 105.522724] @43: (++) refs=2 fwaddr=0xc0029051 enqueue=1 status=Signalled 43-es3_DoKickTA_634
[ 105.532716] P3-smashell-QSGRenderThread-442: @44 ctx=3472 refs=11
[ 105.540169] @9: (++) refs=1 fwaddr=0xc0029359 enqueue=1 status=Signalled 9-es3_DoKick3D_5
[ 105.549801] @10: (++) refs=2 fwaddr=0xc00291a1 enqueue=1 status=Signalled 10-es3_DoKick3D_10
[ 105.559694] @11: (++) refs=1 fwaddr=0xc00293a9 enqueue=1 status=Signalled 11-es3_DoKick3D_0
[ 105.569498] @12: (++) refs=1 fwaddr=0xc0029351 enqueue=1 status=Signalled 12-es3_DoKick3D_11
[ 105.579390] @33: (++) refs=1 fwaddr=0xc0029291 enqueue=1 status=Signalled 33-es3_DoKick3D_285
[ 105.589369] @34: (++) refs=1 fwaddr=0xc0029331 enqueue=1 status=Signalled 34-es3_DoKick3D_302
[ 105.599347] @35: (++) refs=1 fwaddr=0xc00292d1 enqueue=1 status=Signalled 35-es3_DoKick3D_311
[ 105.609326] @41: (++) refs=1 fwaddr=0xc0029399 enqueue=1 status=Signalled 41-es3_DoKick3D_599
[ 105.619303] @42: (++) refs=2 fwaddr=0xc00290e1 enqueue=1 status=Signalled 42-es3_DoKick3D_618
[ 105.629282] @43: (++) refs=2 fwaddr=0xc0029181 enqueue=1 status=Signalled 43-es3_DoKick3D_634
[ 105.639274] QE-smashell-QSGRenderThread-442: @394 ctx=4365 refs=5
[ 105.646726] @0: (++) refs=1 fwaddr=0xc0029389 enqueue=1 status=Signalled 0-TDM
[ 105.655403] @337: (++) refs=1 fwaddr=0xc0029061 enqueue=1 status=Signalled 337-TDM
[ 105.664429] @338: (++) refs=1 fwaddr=0xc0029159 enqueue=1 status=Signalled 338-TDM
[ 105.673454] @393: (++) refs=1 fwaddr=0xc0029369 enqueue=1 status=Signalled 393-TDM
[ 105.682492] rogue-ta3d: @228 ctx=4458 refs=4
[ 105.688125] @224: (++) refs=1 fwaddr=0xc0029221 enqueue=2 status=Signalled 224-update fence
[ 105.697931] @226: (++) refs=1 fwaddr=0xc0029029 enqueue=3 status=Signalled 226-update fence
[ 105.707736] @227: (++) refs=1 fwaddr=0xc00290d1 enqueue=77 status=Signalled 227-update fence
[ 105.717640] rogue-ta3d: @0 ctx=4459 refs=1
[ 105.723099] V3-smashell-QSGRenderThread-442: @228 ctx=4489 refs=4
[ 105.730565] @224: (++) refs=1 fwaddr=0xc0029191 enqueue=1 status=Signalled 224-es3_DoKickTA_688
[ 105.740717] @226: (++) refs=1 fwaddr=0xc0029239 enqueue=1 status=Signalled 226-es3_DoKickTA_690
[ 105.750868] @227: (++) refs=2 fwaddr=0xc0029139 enqueue=1 status=Signalled 227-es3_DoKickTA_691
[ 105.761033] P3-smashell-QSGRenderThread-442: @228 ctx=4490 refs=8
[ 105.768486] @115: (++) refs=1 fwaddr=0xc0029281 enqueue=1 status=Signalled 115-es3_DoKick3D_421
[ 105.778638] @116: (++) refs=1 fwaddr=0xc0029179 enqueue=1 status=Signalled 116-es3_DoKick3D_424
[ 105.788790] @117: (++) refs=1 fwaddr=0xc0029211 enqueue=1 status=Signalled 117-es3_DoKick3D_426
[ 105.798942] @224: (++) refs=1 fwaddr=0xc00290e9 enqueue=1 status=Signalled 224-es3_DoKick3D_688
[ 105.809095] @225: (++) refs=1 fwaddr=0xc0029349 enqueue=1 status=Signalled 225-es3_DoKick3D_689
[ 105.819247] @226: (++) refs=2 fwaddr=0xc00293e1 enqueue=1 status=Signalled 226-es3_DoKick3D_690
[ 105.829399] @227: (++) refs=2 fwaddr=0xc0029311 enqueue=1 status=Signalled 227-es3_DoKick3D_691
[ 105.839563] QE-kwin_wayland-334: @1303 ctx=4497 refs=1
[ 105.846074] rogue-ta3d: @31 ctx=4988 refs=4
[ 105.851621] @26: (++) refs=1 fwaddr=0xc0029241 enqueue=2 status=Signalled 26-update fence
[ 105.861253] @29: (++) refs=1 fwaddr=0xc00291f9 enqueue=4 status=Signalled 29-update fence
[ 105.870886] @30: (++) refs=1 fwaddr=0xc0029341 enqueue=10 status=Signalled 30-update fence
[ 105.880616] rogue-ta3d: @0 ctx=4989 refs=1
[ 105.886088] V3-smashell-QSGRenderThread-442: @34 ctx=5012 refs=5
[ 105.893453] @28: (++) refs=1 fwaddr=0xc0029169 enqueue=1 status=Signalled 28-es3_DoKickTA_517
[ 105.903431] @30: (++) refs=1 fwaddr=0xc00292e1 enqueue=1 status=Signalled 30-es3_DoKickTA_519
[ 105.913409] @31: (++) refs=1 fwaddr=0xc0029149 enqueue=1 status=Signalled 31-es3_DoKickTA_520
[ 105.923387] @33: (++) refs=1 fwaddr=0xc00292a1 enqueue=1 status=Signalled 33-es3_DoKickTA_521
[ 105.933378] P3-smashell-QSGRenderThread-442: @34 ctx=5013 refs=5
[ 105.940745] @28: (++) refs=1 fwaddr=0xc0029189 enqueue=1 status=Signalled 28-es3_DoKick3D_517
[ 105.950723] @30: (++) refs=1 fwaddr=0xc0029101 enqueue=1 status=Signalled 30-es3_DoKick3D_519
[ 105.960702] @31: (++) refs=2 fwaddr=0xc00290b1 enqueue=1 status=Signalled 31-es3_DoKick3D_520
[ 105.970680] @33: (++) refs=1 fwaddr=0xc0029039 enqueue=1 status=Signalled 33-es3_DoKick3D_521
[ 105.980671] rogue-ta3d: @17 ctx=6484 refs=4
[ 105.986217] @14: (++) refs=1 fwaddr=0xc00293e9 enqueue=2 status=Signalled 14-update fence
[ 105.995849] @15: (++) refs=1 fwaddr=0xc00291c1 enqueue=4 status=Signalled 15-update fence
[ 106.005481] @16: (++) refs=1 fwaddr=0xc00293b9 enqueue=45 status=Signalled 16-update fence
[ 106.015213] rogue-ta3d: @0 ctx=6485 refs=1
[ 106.020683] V3-smashell-QSGRenderThread-442: @17 ctx=6486 refs=5
[ 106.028049] @13: (++) refs=1 fwaddr=0xc0029261 enqueue=1 status=Signalled 13-es3_DoKickTA_629
[ 106.038027] @14: (++) refs=1 fwaddr=0xc0029249 enqueue=1 status=Signalled 14-es3_DoKickTA_630
[ 106.048006] @15: (++) refs=1 fwaddr=0xc0029049 enqueue=1 status=Signalled 15-es3_DoKickTA_631
[ 106.057985] @16: (++) refs=1 fwaddr=0xc0029111 enqueue=1 status=Signalled 16-es3_DoKickTA_632
[ 106.067976] P3-smashell-QSGRenderThread-442: @17 ctx=6487 refs=4
[ 106.075342] @14: (++) refs=2 fwaddr=0xc00291f1 enqueue=1 status=Signalled 14-es3_DoKick3D_630
[ 106.085321] @15: (++) refs=2 fwaddr=0xc0029339 enqueue=1 status=Signalled 15-es3_DoKick3D_631
[ 106.095300] @16: (++) refs=1 fwaddr=0xc0029009 enqueue=1 status=Signalled 16-es3_DoKick3D_632
[ 106.105290] rogue-ta3d: @77 ctx=6676 refs=4
[ 106.110837] @74: (++) refs=1 fwaddr=0xc0029421 enqueue=2 status=Signalled 74-update fence
[ 106.120468] @75: (++) refs=1 fwaddr=0xc0029391 enqueue=1 status=Signalled 75-update fence
[ 106.130100] @76: (++) refs=1 fwaddr=0xc0029231 enqueue=1 status=Signalled 76-update fence
[ 106.139746] rogue-ta3d: @0 ctx=6677 refs=1
[ 106.145204] rogue-tq3d: @0 ctx=6703 refs=1
[ 106.150690] V3-elisa-QSGRenderThread-479: @108 ctx=6742 refs=4
[ 106.157882] @105: (++) refs=1 fwaddr=0xc0029429 enqueue=1 status=Signalled 105-es3_DoKickTA_447
[ 106.168035] @106: (++) refs=1 fwaddr=0xc0029011 enqueue=1 status=Signalled 106-es3_DoKickTA_448
[ 106.178187] @107: (++) refs=2 fwaddr=0xc0029001 enqueue=1 status=Signalled 107-es3_DoKickTA_459
[ 106.188351] P3-elisa-QSGRenderThread-479: @108 ctx=6743 refs=4
[ 106.195544] @105: (++) refs=2 fwaddr=0xc00292f9 enqueue=1 status=Signalled 105-es3_DoKick3D_447
[ 106.205695] @106: (++) refs=2 fwaddr=0xc0029219 enqueue=1 status=Signalled 106-es3_DoKick3D_448
[ 106.215847] @107: (++) refs=2 fwaddr=0xc0029131 enqueue=1 status=Signalled 107-es3_DoKick3D_459
[ 106.226012] QE-elisa-QSGRenderThread-479: @352 ctx=6744 refs=2
[ 106.233205] @351: (++) refs=1 fwaddr=0xc00292a9 enqueue=1 status=Signalled 351-TDM
[ 106.242242] rogue-ta3d: @0 ctx=7183 refs=0
[ 106.247721] PVR_K: 179: ------------[ PVR DBG: END ]------------
[ 106.255227] ------------[ cut here ]------------
[ 106.261159] WARNING: CPU: 3 PID: 179 at drivers/gpu/drm/img/img-rogue/services/server/common/pvr_notifier.c:645 PVRSRVDebugRequest+0x330/0x5d8 [pvrsrvkm]
[ 106.276256] Modules linked in: starfive_mailbox_test venc(O) vdec(O) jpu(O) starfive_mailbox pvrsrvkm
[ 106.286844] CPU: 3 PID: 179 Comm: pvr_device_wdg Tainted: G O 5.15.0 #1
[ 106.296131] Hardware name: StarFive VisionFive V2 (DT)
[ 106.302646] epc : PVRSRVDebugRequest+0x330/0x5d8 [pvrsrvkm]
[ 106.309596] ra : PVRSRVDebugRequest+0x330/0x5d8 [pvrsrvkm]
[ 106.316545] epc : ffffffff015c6ac6 ra : ffffffff015c6ac6 sp : ffffffd016babd20
[ 106.325142] gp : ffffffff81504430 tp : ffffffe0c2130000 t0 : ffffffff815145af
[ 106.333734] t1 : 0000000000000001 t2 : 0000000000000000 s0 : ffffffd016babd80
[ 106.342331] s1 : ffffffe0c3cd1560 a0 : ffffffff01696590 a1 : 0000000200000022
[ 106.350924] a2 : ffffffe0fc1a5228 a3 : 0000000000000000 a4 : 0000000000000000
[ 106.359517] a5 : 0000000000000000 a6 : 0000000000000000 a7 : ffffffd016baba30
[ 106.368112] s2 : 0000000000000000 s3 : 0000000000000000 s4 : 0000000000000002
[ 106.376705] s5 : ffffffe0c21ed720 s6 : ffffffe0c21ed320 s7 : ffffffe0c21ed720
[ 106.385299] s8 : ffffffe0c21ed608 s9 : ffffffe0c21ed208 s10: ffffffff80028918
[ 106.393896] s11: 0000000000000000 t3 : 0000000000000050 t4 : ffffffffffffffff
[ 106.402489] t5 : ffffffff016540c0 t6 : 45203a4742442052
[ 106.409178] status: 0000000200000120 badaddr: 0000000000000000 cause: 0000000000000003
[ 106.418469] [<ffffffff015c6ac6>] PVRSRVDebugRequest+0x330/0x5d8 [pvrsrvkm]
[ 106.426715] [<ffffffff015c7020>] DevicesWatchdogThread_ForEachVaCb+0x8a/0xca [pvrsrvkm]
[ 106.436090] [<ffffffff015b7832>] List_PVRSRV_DEVICE_NODE_ForEach_va+0x3a/0x62 [pvrsrvkm]
[ 106.445551] [<ffffffff015c6e6e>] DevicesWatchdogThread+0xa0/0x1c8 [pvrsrvkm]
[ 106.453975] [<ffffffff015a41f0>] OSThreadRun+0x22/0x56 [pvrsrvkm]
[ 106.461448] [<ffffffff80028782>] kthread+0xfe/0x114
[ 106.467701] [<ffffffff80003104>] ret_from_exception+0x0/0xc
[ 106.474653] ---[ end trace 56f7236099b0b0bb ]---
