All this in the hopes of following the recipe to build a Fedora 33 Image for VF2 and ultimately bringup and Fedora Silverblue Image afterwards. I found these related links.
Directly on the VisionFive 2 board with the debian sid image on a 128GB sdcard, and avoiding the sources and using the pre-built debian binaries as much as possible, I’m trying to follow the steps.
All the debian sid packages installed were more recent versions of course.
sudo apt-cache search ostree
sudo apt-get install ostree
sudo apt-cache search rclone
sudo apt-get install rclone
sudo apt-cache search podman
sudo apt-get install podman
sudo apt-cache search runc
sudo apt-get install runc
sudo apt-cache search containernetworking
sudo apt-get install containernetworking-plugins
sudo apt-cache search containers |grep common
sudo apt-get install golang-github-containers-common liblxc-common
sudo modprobe tun
mkdir helloworld
cd helloworld/
gcc -static hello.c -o hello
podman build . -t helloworld
podman run --network=host --privileged helloworld
Hello from Docker!
This message shows that your installation appears to be working correctly.
What kernel are you running ?
I installed podman with sudo apt install podman containers-storage and testing the standard hello-world worked first try: podman run hello-world
Resolved "hello-world" as an alias (/etc/containers/registries.conf.d/shortnames.conf)
Trying to pull docker.io/library/hello-world:latest...
Getting image source signatures
Copying blob 3caa6dc69d0b done
Copying config b3593dab05 done
Writing manifest to image destination
Storing signatures
Hello from Docker!
CORRECTION: I am using hexdump0815’s experimental sid image.
I did an update/upgrade of packages within there.
UPDATE: I reverted to starfive engineering image 69 and it didn’t feel good.
I’m back on hexdump0815’s image. It doesn’t have starfive’s latest kernel or any of the other gpu/chromium and such, but at least I’ve got access to the full debian riscv sid package repos unlike the buildroot image.
uart connection is absolutely a wise choice, I have it hooked up permanently to a nearby computer.
Also, make sure to copy the modules over as well, the ipv6, bridge stuff etc is there and not in the kernel itself.
