Since jh7110 is using U74MC, so I read the datasheet provided by SiFive and found that users can config the L2 cache and prefetcher (such as enable/disable specific cache way, turn on/off the prefetcher, which is meaningful for researches on microarchitecture) by writing to the controlled registers of L2 Cache Controller.
I’m looking for methods to write these control registers. I found the memory mapped address of L2 Cache Controller(which is 0x0201_0000-0x0201_3FFF) and L2 prefetcher(for hart 1, it’s 0x0203_0000-0x0203_1FFF) in page 96. However, directly read from these addresses(such as *((unsigned long long*)(0x02010000))) got a segment fault.
After reading the source code of freedom-metal of SiFive, I found they get the memory mapped base addr from the dtb file. So I checked the dts file of the linux repo of Starfive and found the right cache controller definitions in the upstream branch(not in devel branch, which may be the reason for the failed direct read mentioned above).
ccache: cache-controller@2010000 {
compatible = "starfive,jh7110-ccache", "sifive,ccache0", "cache";
reg = <0x0 0x2010000 0x0 0x4000>;
interrupts = <1>, <3>, <4>, <2>;
cache-block-size = <64>;
cache-level = <2>;
cache-sets = <2048>;
cache-size = <2097152>;
cache-unified;
So I want to ask 2 questions(especially for the second):
1.Can I get access to the memory mapped registers of L2 Cache Controller after I replace the kernel and dtb file builded from the upstream branch? If so, is the usage of “*((unsigned long long*)(0x02010000))” right?
2. How can I get access to the L2 prefetcher? I didn’t find the l2pf item and its corresponding address in the dts file. (Since the SiFive U74 core provides many config options to the L2 prefetcher, a lot of performance tuning work can be done. I’m in this area and have great interest in that.)
I also noticed that engineers of StarFive are submitting dtb related patches to the mainline recently. Thanks for your work. By the way, do you have the plan of supporting L2 prefetcher configurations?
Any suggestion will be appreciated!
