installation README.TXT
kernel 7.0.1
mirror 1 , mirror 2 , mirror 3 , mirror 4 , mirror 5
irradium-3.8-riscv64-core-orange_pi_rv-7.0.1-build-20260425.img.zst
irradium-3.8-riscv64-core-orange_pi_rv-7.0.1-build-20260425.img.zst.sha25
U-Boot SPL 2026.04-jh7110 (Apr 10 2026 - 23:09:11 +0000)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.8.1
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Name : StarFive VisionFive 2 v1.3B
Platform Features : medeleg
Platform HART Count : 4
Platform HART Protection : pmp
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Platform CPPC Device : ---
Firmware Base : 0x40000000
Firmware Size : 357 KB
Firmware RW Offset : 0x40000
Firmware RW Size : 101 KB
Firmware Heap Offset : 0x4d000
Firmware Heap Size : 49 KB (total), 0 KB (reserved), 13 KB (used), 35 KB (free)
Firmware Scratch Size : 4096 B (total), 416 B (used), 3680 B (free)
Runtime SBI Version : 3.0
Standard SBI Extensions : time,rfnc,ipi,base,hsm,srst,pmu,dbcn,fwft,legacy,dbtr,sse
Experimental SBI Extensions : none
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 HARTs : 1*,2*,3*,4*
Domain0 Region00 : 0x0000000040040000-0x000000004005ffff M: (F,R,W) S/U: ()
Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (F,R,X) S/U: ()
Domain0 Region02 : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region03 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region04 : 0x000000000c000000-0x000000000fffffff M: (I,R,W) S/U: (R,W)
Domain0 Region05 : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Arg1 : 0x00000000402e46d8
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA Extensions : zihpm,sdtrig
Boot HART PMP Count : 8
Boot HART PMP Granularity : 12 bits
Boot HART PMP Address Bits : 34
Boot HART MHPM Info : 2 (0x00000018)
Boot HART Debug Triggers : 8 triggers
U-Boot 2026.04-jh7110 (Apr 10 2026 - 23:09:11 +0000)
CPU: sifive,u74-mc
Model: StarFive VisionFive 2 v1.3B
DRAM: 8 GiB
Core: 159 devices, 30 uclasses, devicetree: board
WDT: Not starting watchdog@13070000
MMC: mmc@16010000: 0, mmc@16020000: 1
Product full SN: VF7110B1-2228-D008E000-00000579
PCB revision: 0x1
Ethernet MAC0 address: c0:74:2b:fc:f5:42
Ethernet MAC1 address: 6c:cf:39:00:00:00
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
starting USB...
USB XHCI 1.00
Bus xhci_pci: 2 USB Device(s) found
Working FDT set to ff6f5060
cyclic function mmc@16020000 took too long: 6525us vs 5000us max
** File not found ubootefi.var **
No EFI variables loaded
** Unable to write file ubootefi.var **
Failed to persist EFI variables
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 1' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
** File not found /boot.bmp **
** Booting bootflow 'mmc@16020000.bootdev.part_3' with script
Boot script loaded from mmc 1:3
139 bytes read in 2 ms (67.4 KiB/s)
34615 bytes read in 5 ms (6.6 MiB/s)
26299488 bytes read in 772 ms (32.5 MiB/s)
Working FDT set to 46000000
Failed to load '/dtb/starfive/overlay/starfive-fixup.scr'
8546402 bytes read in 359 ms (22.7 MiB/s)
## Flattened Device Tree blob at 46000000
Booting using the fdt blob at 0x46000000
Loading Ramdisk to fdbd9000, end fe3ff862 ... OK
Loading Device Tree to 00000000fe64d000, end 00000000fe6bdfff ... OK
Working FDT set to fe64d000
Starting kernel ...
debugfs: '16008000.dma-controller' already exists in 'dmaengine'
verisilicon-dc 29400000.display: can't deassert reset lines
verisilicon-dc 29400000.display: probe with driver verisilicon-dc failed with error -110
starfive-inno-hdmi-controller 29590000.hdmi:controller: probe with driver starfive-inno-hdmi-controller failed with error -110
irradium (orange-pi-rv) (ttyS0)
orange-pi-rv login:
