Got my VisionFive2 board with 8GB ram and playing around a bit.
My NVMe SSD, a WD Black 500GB is not recognized. I use the Image-69
Any advice? The SPI is up to date.
root@starfive:~# blkid
/dev/mmcblk1p3: LABEL="root" UUID="6fb32149-b83b-4969-8ffb-cf73044b135e" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a4643a54-b504-8941-b1c8-21c58de8a576"
/dev/mmcblk1p1: PARTUUID="00d7afd1-99de-42bf-9a5f-2177370c9fdc"
/dev/mmcblk1p2: SEC_TYPE="msdos" UUID="2BBA-0725" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="70e8fa63-f9fc-410b-8322-b0950c6d22fb"
root@starfive:~# lspci
00:00.0 PCI bridge: PLDA XpressRich-AXI Ref Design (rev 02)
01:00.0 USB controller: VIA Technologies, Inc. VL805/806 xHCI USB 3.0 Controller (rev 01)
root@starfive:~# dmesg | grep -e pcie
[ 2.502695] pcie_plda 2b000000.pcie: host bridge /soc/pcie@2B000000 ranges:
[ 2.510461] pcie_plda 2b000000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 2.519415] pcie_plda 2b000000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000
[ 2.895656] pcie_plda 2b000000.pcie: Port link up.
[ 2.901102] pcie_plda 2b000000.pcie: PCI host bridge to bus 0000:00
[ 3.091697] pcie_plda 2b000000.pcie: msi#0 address_hi 0x0 address_lo 0x190
[ 3.142278] pcie_plda 2c000000.pcie: host bridge /soc/pcie@2C000000 ranges:
[ 3.150022] pcie_plda 2c000000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 3.158978] pcie_plda 2c000000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000
[ 3.615816] pcie_plda 2c000000.pcie: Port link down, exit.
[ 4.777848] input: Logitech USB Keyboard as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C31C.0001/input/input0
[ 4.879507] input: Logitech USB Keyboard Consumer Control as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31C.0002/input/input1
[ 4.965887] input: Logitech USB Keyboard System Control as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31C.0002/input/input2
[ 5.918144] input: Logitech USB Receiver as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C52F.0003/input/input3
[ 5.951922] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/2b000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52F.0004/input/input4
root@starfive:~# lspci -v
00:00.0 PCI bridge: PLDA XpressRich-AXI Ref Design (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Memory at <unassigned> (64-bit, prefetchable)
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00000000-00000fff [size=4K]
Memory behind bridge: 30000000-300fffff [size=1M]
Prefetchable memory behind bridge: 0000000000000000-00000000000fffff [size=1M]
Capabilities: [80] Express Root Port (Slot+), MSI 00
Capabilities: [e0] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [f8] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
Capabilities: [200] Advanced Error Reporting
01:00.0 USB controller: VIA Technologies, Inc. VL805/806 xHCI USB 3.0 Controller (rev 01) (prog-if 30 [XHCI])
Subsystem: VIA Technologies, Inc. VL805/806 xHCI USB 3.0 Controller
Flags: bus master, fast devsel, latency 0, IRQ 58
Memory at 30000000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable+ Count=1/4 Maskable- 64bit+
Capabilities: [c4] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: xhci_hcd
Thanks for the RISC-V boards ![]()
