No Disk Space on 1TB NVME
I have successfully updated the firmware for VisionFive2 and am running the 202306 version off of a 1TB NVME drive. The first thing I did was try to get the packages and dependencies using:
wget https://github.com/starfive-tech/Debian/releases/download/v0.7.1-engineering-release-wayland/install_package_and_dependencies.sh
chmod +x install_package_and_dependencies.sh
./install_package_and_dependencies.sh
However, 2 hours later I received “Unrecoverable fatal error: no space left on device” When I ran fdisk -l, the system does recognize I am using a 1TB drive. However when running df -h it says I am at 100% utilization and that the drive is only 2.8GB large. Can someone please tell me what I can do?
I can’t believe I posted this when it’s obvious, I didn’t add the other unallocated space into the primary partition
First you need to extend the partition using the parted tool Extend Partition on SD Card or eMMC
Then you need to run sudo resize2fs /dev/mmcblk1p4 to resize the file system.
Then reboot and you should all be good.
