I connected a Kingston UV500 to JMB585.
Reading using dd averages at 180MB/s.
root@starfive:~# dd if=/dev/sda of=/dev/null bs=1M status=progress
480022364160 bytes (480 GB, 447 GiB) copied, 2559 s, 188 MB/s
457862+1 records in
457862+1 records out
480103981056 bytes (480 GB, 447 GiB) copied, 2563.27 s, 187 MB/s
I could see the partitions using fdisk:
root@starfive:~# fdisk /dev/sda
Welcome to fdisk (util-linux 2.38).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p
Disk /dev/sda: 447.13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KINGSTON SUV5004
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 2EE6FD09-5568-4336-B0E9-F46EAD760552
Device Start End Sectors Size Type
/dev/sda1 2048 1085439 1083392 529M Windows recovery environment
/dev/sda2 1085440 1290239 204800 100M EFI System
/dev/sda3 1290240 1323007 32768 16M Microsoft reserved
/dev/sda4 1323008 937701375 936378368 446.5G Microsoft basic data
SMART before dd:
root@starfive:~# smartctl -a /dev/sda
smartctl 7.3 2022-02-28 r5338 [riscv64-linux-5.15.0-starfive] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Kingston SSDNow UV400/500
Device Model: KINGSTON SUV500480G
Serial Number: 50026B7682744CE9
LU WWN Device Id: 5 0026b7 682744ce9
Firmware Version: 003056RR
User Capacity: 480,103,981,056 bytes [480 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-4, ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Apr 22 13:38:38 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 5) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 5) minutes.
Conveyance self-test routine
recommended polling time: ( 0) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 48
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 516747
5 Reallocated_Sector_Ct 0x0033 089 089 010 Pre-fail Always - 148
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 981
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 269
100 Unknown_Kingston_Attr 0x0032 100 100 000 Old_age Always - 752000
101 Unknown_Kingston_Attr 0x0032 100 100 000 Old_age Always - 175072
170 Reserved_Block_Count 0x0032 100 100 000 Old_age Always - 148
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 34
175 Program_Fail_Count_Chip 0x0032 100 100 000 Old_age Always - 0
176 Erase_Fail_Count_Chip 0x0032 100 100 000 Old_age Always - 0
177 Wear_Leveling_Count 0x0032 100 100 000 Old_age Always - 283
178 Used_Rsvd_Blk_Cnt_Chip 0x0002 100 100 000 Old_age Always - 15
180 Unused_Rsvd_Blk_Cnt_Tot 0x0002 100 100 000 Old_age Always - 1181
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 3
187 Reported_Uncorrect 0x0033 100 100 000 Pre-fail Always - 1378
194 Temperature_Celsius 0x0022 029 100 000 Old_age Always - 29 (Min/Max 19/55)
195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 516747
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 148
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 75
199 UDMA_CRC_Error_Count 0x0012 100 100 000 Old_age Always - 0
201 Unc_Read_Error_Rate 0x0032 100 100 000 Old_age Always - 0
204 Soft_ECC_Correction 0x0032 100 100 000 Old_age Always - 515369
231 SSD_Life_Left 0x0032 100 100 000 Old_age Always - 0
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 2643
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2032
241 Host_Writes_GiB 0x0032 100 100 000 Old_age Always - 1833
242 Host_Reads_GiB 0x0032 100 100 000 Old_age Always - 2223
250 Read_Retry_Count 0x0032 100 100 000 Old_age Always - 516415
SMART Error Log Version: 0
No Errors Logged
SMART Self-test log structure revision number 0
Warning: ATA Specification requires self-test log structure revision number = 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SMART after dd:
Local Time is: Sat Apr 22 14:25:04 2023 UTC
was never started.
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 521486
100 Unknown_Kingston_Attr 0x0032 100 100 000 Old_age Always - 753536
101 Unknown_Kingston_Attr 0x0032 100 100 000 Old_age Always - 175456
194 Temperature_Celsius 0x0022 030 100 000 Old_age Always - 30 (Min/Max 19/55)
195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 521486
204 Soft_ECC_Correction 0x0032 100 100 000 Old_age Always - 520108
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 2648
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2036
242 Host_Reads_GiB 0x0032 100 100 000 Old_age Always - 2670
250 Read_Retry_Count 0x0032 100 100 000 Old_age Always - 521259
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
