Perhaps a FAQ but I did not find anything regarding this issue. I tried to build buildroot-initramfs for the new v3.8.2 release but it stops immediatly with an error regarding the sha256 sum of the firmware blob:
Ok, found the reason…the download site http://sources.buildroot.net/ really does not contain that binary blob for the firmware, so the download fails:
--2023-11-04 20:25:35-- http://sources.buildroot.net/img-gpu-powervr-bin-1.19.6345021.tar.gz
Auflösen des Hostnamens sources.buildroot.net (sources.buildroot.net)… 2606:4700:20::681a:25, 2606:4700:20::681a:125, 2606:4700:20::ac43:4838, ...
Verbindungsaufbau zu sources.buildroot.net (sources.buildroot.net)|2606:4700:20::681a:25|:80 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 404 Not Found
2023-11-04 20:25:35 FEHLER 404: Not Found.
it is caused by the hash is different between your local and remote.
maybe you can updare your branch of buildroot and soft_3rdpart to the latest release,the hash will update.
