I’ve received my board and found an SD card. I managed to upgrade SPL and U-Boot in order to run the minimal version of Image-69. All good so far.
I noticed that in the release notes for 2.4.4
Support FFmpeg using h264_omx/hevc_omx hard decoding/encoding plug-in;
However, I can’t seem to get it to work. I’ve tried the following command
ffmpeg -i /dev/video4 -c:v h264_omx test.mp4
Which gives the error:
[h264_omx @ 0x2ab59a8950] libOMX_Core.so not found
[h264_omx @ 0x2ab59a8950] libOmxCore.so not found
The only solution that I can find through google, is to install the libomxil-bellagio-dev package which I’ve done but it doesn’t help. /dev/video4 is a USB webcam, however, I’ve tried it with a video file on the SD card and it makes no difference.
Any help would be greatly appreciated.
Thanks, Nick
Manux
January 8, 2023, 1:22pm
2
Hi
There are reports in other threads that starfive did change some PATHS in the image so stuff is not where it should be or looked for by the system.
I would do the following:
Find the libOMX_Core.so and libOmxCore.so in your system. Add that PATH to the PATH variable of your Terminal. Then this should be found.
You can also try:
LD_LIBRARY_PATH=/usr/local/lib ldd ./app
This will give you some output. Please post it here.
Thanks!
I searched the entire SD card for libOMX_Core.so and libOmxCore.so neither of them appear to exist. I’ve also tried googling to see if there is a Debian package that contains them and couldn’t find anything.
Here is the output of ldd
root@starfive:~# LD_LIBRARY_PATH=/usr/local/lib ldd /usr/bin/ffmpeg
linux-vdso.so.1 (0x0000003fa54c7000)
libavdevice.so.58 => /usr/lib/riscv64-linux-gnu/libavdevice.so.58 (0x0000003fa5452000)
libavfilter.so.7 => /usr/lib/riscv64-linux-gnu/libavfilter.so.7 (0x0000003fa50df000)
libavformat.so.58 => /usr/lib/riscv64-linux-gnu/libavformat.so.58 (0x0000003fa4ec6000)
libavcodec.so.58 => /usr/lib/riscv64-linux-gnu/libavcodec.so.58 (0x0000003fa3d89000)
libpostproc.so.55 => /usr/lib/riscv64-linux-gnu/libpostproc.so.55 (0x0000003fa3d7c000)
libswresample.so.3 => /usr/lib/riscv64-linux-gnu/libswresample.so.3 (0x0000003fa3d67000)
libswscale.so.5 => /usr/lib/riscv64-linux-gnu/libswscale.so.5 (0x0000003fa3cf4000)
libavutil.so.56 => /usr/lib/riscv64-linux-gnu/libavutil.so.56 (0x0000003fa3a58000)
libm.so.6 => /lib/riscv64-linux-gnu/libm.so.6 (0x0000003fa39d4000)
libpthread.so.0 => /lib/riscv64-linux-gnu/libpthread.so.0 (0x0000003fa39ba000)
libc.so.6 => /lib/riscv64-linux-gnu/libc.so.6 (0x0000003fa38a9000)
/lib/ld-linux-riscv64-lp64d.so.1 (0x0000003fa54c8000)
libraw1394.so.11 => /usr/lib/riscv64-linux-gnu/libraw1394.so.11 (0x0000003fa389d000)
libavc1394.so.0 => /usr/lib/riscv64-linux-gnu/libavc1394.so.0 (0x0000003fa3896000)
librom1394.so.0 => /usr/lib/riscv64-linux-gnu/librom1394.so.0 (0x0000003fa3891000)
libiec61883.so.0 => /usr/lib/riscv64-linux-gnu/libiec61883.so.0 (0x0000003fa3886000)
libjack.so.0 => /usr/lib/riscv64-linux-gnu/libjack.so.0 (0x0000003fa383b000)
libdrm.so.2 => /usr/local/lib/libdrm.so.2 (0x0000003fa382a000)
libopenal.so.1 => /usr/lib/riscv64-linux-gnu/libopenal.so.1 (0x0000003fa3761000)
libxcb.so.1 => /usr/local/lib/libxcb.so.1 (0x0000003fa3732000)
libxcb-shm.so.0 => /usr/local/lib/libxcb-shm.so.0 (0x0000003fa372e000)
libxcb-shape.so.0 => /usr/local/lib/libxcb-shape.so.0 (0x0000003fa3729000)
libxcb-xfixes.so.0 => /usr/local/lib/libxcb-xfixes.so.0 (0x0000003fa3720000)
libcdio_paranoia.so.2 => /usr/lib/riscv64-linux-gnu/libcdio_paranoia.so.2 (0x0000003fa3719000)
libcdio_cdda.so.2 => /usr/lib/riscv64-linux-gnu/libcdio_cdda.so.2 (0x0000003fa3712000)
libdc1394.so.25 => /usr/lib/riscv64-linux-gnu/libdc1394.so.25 (0x0000003fa36a4000)
libasound.so.2 => /usr/lib/riscv64-linux-gnu/libasound.so.2 (0x0000003fa35e4000)
libcaca.so.0 => /usr/lib/riscv64-linux-gnu/libcaca.so.0 (0x0000003fa3525000)
libGL.so.1 => /usr/lib/riscv64-linux-gnu/libGL.so.1 (0x0000003fa348f000)
libpulse.so.0 => /usr/lib/riscv64-linux-gnu/libpulse.so.0 (0x0000003fa3452000)
libSDL2-2.0.so.0 => /usr/local/lib/libSDL2-2.0.so.0 (0x0000003fa3304000)
libXv.so.1 => /usr/local/lib/libXv.so.1 (0x0000003fa32fc000)
libX11.so.6 => /usr/local/lib/libX11.so.6 (0x0000003fa31b3000)
libXext.so.6 => /usr/local/lib/libXext.so.6 (0x0000003fa31a0000)
libpocketsphinx.so.3 => /usr/lib/riscv64-linux-gnu/libpocketsphinx.so.3 (0x0000003fa3167000)
libsphinxbase.so.3 => /usr/lib/riscv64-linux-gnu/libsphinxbase.so.3 (0x0000003fa3134000)
libbs2b.so.0 => /usr/lib/riscv64-linux-gnu/libbs2b.so.0 (0x0000003fa312e000)
liblilv-0.so.0 => /usr/lib/riscv64-linux-gnu/liblilv-0.so.0 (0x0000003fa3118000)
libdl.so.2 => /lib/riscv64-linux-gnu/libdl.so.2 (0x0000003fa3114000)
librubberband.so.2 => /usr/lib/riscv64-linux-gnu/librubberband.so.2 (0x0000003fa30dd000)
libmysofa.so.1 => /usr/lib/riscv64-linux-gnu/libmysofa.so.1 (0x0000003fa30d2000)
libflite_cmu_us_awb.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmu_us_awb.so.1 (0x0000003fa2d12000)
libflite_cmu_us_kal.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmu_us_kal.so.1 (0x0000003fa2bad000)
libflite_cmu_us_kal16.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmu_us_kal16.so.1 (0x0000003fa27d2000)
libflite_cmu_us_rms.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmu_us_rms.so.1 (0x0000003fa2378000)
libflite_cmu_us_slt.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmu_us_slt.so.1 (0x0000003fa1fb7000)
libflite.so.1 => /usr/lib/riscv64-linux-gnu/libflite.so.1 (0x0000003fa1f89000)
libfribidi.so.0 => /usr/lib/riscv64-linux-gnu/libfribidi.so.0 (0x0000003fa1f6e000)
libass.so.9 => /usr/lib/riscv64-linux-gnu/libass.so.9 (0x0000003fa1f4c000)
libva.so.2 => /usr/lib/riscv64-linux-gnu/libva.so.2 (0x0000003fa1f24000)
libvidstab.so.1.1 => /usr/lib/riscv64-linux-gnu/libvidstab.so.1.1 (0x0000003fa1f15000)
libzmq.so.5 => /usr/lib/riscv64-linux-gnu/libzmq.so.5 (0x0000003fa1e78000)
libzimg.so.2 => /usr/lib/riscv64-linux-gnu/libzimg.so.2 (0x0000003fa1e48000)
libOpenCL.so.1 => /usr/lib/riscv64-linux-gnu/libOpenCL.so.1 (0x0000003fa1e3c000)
libfontconfig.so.1 => /usr/local/lib/libfontconfig.so.1 (0x0000003fa1df6000)
libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x0000003fa1d28000)
libxml2.so.2 => /usr/lib/riscv64-linux-gnu/libxml2.so.2 (0x0000003fa1bff000)
libbz2.so.1.0 => /lib/riscv64-linux-gnu/libbz2.so.1.0 (0x0000003fa1bf0000)
libgme.so.0 => /usr/lib/riscv64-linux-gnu/libgme.so.0 (0x0000003fa1baa000)
libopenmpt.so.0 => /usr/lib/riscv64-linux-gnu/libopenmpt.so.0 (0x0000003fa19d9000)
libchromaprint.so.1 => /usr/lib/riscv64-linux-gnu/libchromaprint.so.1 (0x0000003fa19c8000)
libbluray.so.2 => /usr/lib/riscv64-linux-gnu/libbluray.so.2 (0x0000003fa198d000)
libz.so.1 => /usr/local/lib/libz.so.1 (0x0000003fa196f000)
libgnutls.so.30 => /usr/lib/riscv64-linux-gnu/libgnutls.so.30 (0x0000003fa17eb000)
librabbitmq.so.4 => /usr/lib/riscv64-linux-gnu/librabbitmq.so.4 (0x0000003fa17d7000)
libsrt-gnutls.so.1.4 => /usr/lib/riscv64-linux-gnu/libsrt-gnutls.so.1.4 (0x0000003fa172f000)
libssh-gcrypt.so.4 => /usr/lib/riscv64-linux-gnu/libssh-gcrypt.so.4 (0x0000003fa16c3000)
libvpx.so.7 => /usr/lib/riscv64-linux-gnu/libvpx.so.7 (0x0000003fa154e000)
libwebpmux.so.3 => /usr/lib/riscv64-linux-gnu/libwebpmux.so.3 (0x0000003fa1546000)
libwebp.so.7 => /usr/lib/riscv64-linux-gnu/libwebp.so.7 (0x0000003fa1506000)
liblzma.so.5 => /lib/riscv64-linux-gnu/liblzma.so.5 (0x0000003fa14e7000)
libdav1d.so.6 => /usr/lib/riscv64-linux-gnu/libdav1d.so.6 (0x0000003fa143a000)
librsvg-2.so.2 => /usr/lib/riscv64-linux-gnu/librsvg-2.so.2 (0x0000003fa0aef000)
libgobject-2.0.so.0 => /usr/lib/riscv64-linux-gnu/libgobject-2.0.so.0 (0x0000003fa0aa5000)
libglib-2.0.so.0 => /usr/lib/riscv64-linux-gnu/libglib-2.0.so.0 (0x0000003fa09af000)
libcairo.so.2 => /usr/local/lib/libcairo.so.2 (0x0000003fa087c000)
libzvbi.so.0 => /usr/lib/riscv64-linux-gnu/libzvbi.so.0 (0x0000003fa0805000)
libsnappy.so.1 => /usr/lib/riscv64-linux-gnu/libsnappy.so.1 (0x0000003fa07fc000)
libaom.so.3 => /usr/lib/riscv64-linux-gnu/libaom.so.3 (0x0000003fa0570000)
libcodec2.so.1.0 => /usr/lib/riscv64-linux-gnu/libcodec2.so.1.0 (0x0000003f9f6d8000)
libgsm.so.1 => /usr/lib/riscv64-linux-gnu/libgsm.so.1 (0x0000003f9f6ca000)
libmp3lame.so.0 => /usr/lib/riscv64-linux-gnu/libmp3lame.so.0 (0x0000003f9f664000)
libopenjp2.so.7 => /usr/lib/riscv64-linux-gnu/libopenjp2.so.7 (0x0000003f9f620000)
libopus.so.0 => /usr/lib/riscv64-linux-gnu/libopus.so.0 (0x0000003f9f5dd000)
libshine.so.3 => /usr/lib/riscv64-linux-gnu/libshine.so.3 (0x0000003f9f5d2000)
libspeex.so.1 => /usr/lib/riscv64-linux-gnu/libspeex.so.1 (0x0000003f9f5bb000)
libtheoraenc.so.1 => /usr/lib/riscv64-linux-gnu/libtheoraenc.so.1 (0x0000003f9f590000)
libtheoradec.so.1 => /usr/lib/riscv64-linux-gnu/libtheoradec.so.1 (0x0000003f9f57c000)
libtwolame.so.0 => /usr/lib/riscv64-linux-gnu/libtwolame.so.0 (0x0000003f9f55c000)
libvorbis.so.0 => /usr/lib/riscv64-linux-gnu/libvorbis.so.0 (0x0000003f9f538000)
libvorbisenc.so.2 => /usr/lib/riscv64-linux-gnu/libvorbisenc.so.2 (0x0000003f9f498000)
libx264.so.163 => /usr/lib/riscv64-linux-gnu/libx264.so.163 (0x0000003f9f29c000)
libx265.so.199 => /usr/lib/riscv64-linux-gnu/libx265.so.199 (0x0000003f9f04b000)
libxvidcore.so.4 => /usr/lib/riscv64-linux-gnu/libxvidcore.so.4 (0x0000003f9ef72000)
libsoxr.so.0 => /usr/lib/riscv64-linux-gnu/libsoxr.so.0 (0x0000003f9ef1f000)
libva-drm.so.2 => /usr/lib/riscv64-linux-gnu/libva-drm.so.2 (0x0000003f9ef1b000)
libva-x11.so.2 => /usr/lib/riscv64-linux-gnu/libva-x11.so.2 (0x0000003f9ef13000)
libvdpau.so.1 => /usr/lib/riscv64-linux-gnu/libvdpau.so.1 (0x0000003f9ef0e000)
libdb-5.3.so => /usr/lib/riscv64-linux-gnu/libdb-5.3.so (0x0000003f9eddd000)
librt.so.1 => /lib/riscv64-linux-gnu/librt.so.1 (0x0000003f9edd5000)
libstdc++.so.6 => /usr/lib/riscv64-linux-gnu/libstdc++.so.6 (0x0000003f9ec00000)
libgcc_s.so.1 => /lib/riscv64-linux-gnu/libgcc_s.so.1 (0x0000003f9ebea000)
libsndio.so.7.0 => /usr/lib/riscv64-linux-gnu/libsndio.so.7.0 (0x0000003f9ebdb000)
libXau.so.6 => /usr/local/lib/libXau.so.6 (0x0000003f9ebd7000)
libXdmcp.so.6 => /usr/local/lib/libXdmcp.so.6 (0x0000003f9ebcf000)
libcdio.so.19 => /usr/lib/riscv64-linux-gnu/libcdio.so.19 (0x0000003f9ebad000)
libusb-1.0.so.0 => /usr/lib/riscv64-linux-gnu/libusb-1.0.so.0 (0x0000003f9eb94000)
libslang.so.2 => /usr/lib/riscv64-linux-gnu/libslang.so.2 (0x0000003f9e8b4000)
libncursesw.so.6 => /lib/riscv64-linux-gnu/libncursesw.so.6 (0x0000003f9e88b000)
libtinfo.so.6 => /lib/riscv64-linux-gnu/libtinfo.so.6 (0x0000003f9e860000)
libGLdispatch.so.0 => /usr/lib/riscv64-linux-gnu/libGLdispatch.so.0 (0x0000003f9e7b8000)
libGLX.so.0 => /usr/lib/riscv64-linux-gnu/libGLX.so.0 (0x0000003f9e7aa000)
libpulsecommon-15.0.so => /usr/lib/riscv64-linux-gnu/pulseaudio/libpulsecommon-15.0.so (0x0000003f9e744000)
libdbus-1.so.3 => /lib/riscv64-linux-gnu/libdbus-1.so.3 (0x0000003f9e707000)
libblas.so.3 => /usr/lib/riscv64-linux-gnu/libblas.so.3 (0x0000003f9e6c3000)
liblapack.so.3 => /usr/lib/riscv64-linux-gnu/liblapack.so.3 (0x0000003f9e2d0000)
libserd-0.so.0 => /usr/lib/riscv64-linux-gnu/libserd-0.so.0 (0x0000003f9e2bf000)
libsord-0.so.0 => /usr/lib/riscv64-linux-gnu/libsord-0.so.0 (0x0000003f9e2b4000)
libsratom-0.so.0 => /usr/lib/riscv64-linux-gnu/libsratom-0.so.0 (0x0000003f9e2ac000)
libflite_usenglish.so.1 => /usr/lib/riscv64-linux-gnu/libflite_usenglish.so.1 (0x0000003f9e283000)
libflite_cmulex.so.1 => /usr/lib/riscv64-linux-gnu/libflite_cmulex.so.1 (0x0000003f9e1ed000)
libharfbuzz.so.0 => /usr/lib/riscv64-linux-gnu/libharfbuzz.so.0 (0x0000003f9e135000)
libgomp.so.1 => /usr/lib/riscv64-linux-gnu/libgomp.so.1 (0x0000003f9e102000)
libbsd.so.0 => /usr/lib/riscv64-linux-gnu/libbsd.so.0 (0x0000003f9e0f1000)
libsodium.so.23 => /usr/lib/riscv64-linux-gnu/libsodium.so.23 (0x0000003f9e0bd000)
libpgm-5.3.so.0 => /usr/lib/riscv64-linux-gnu/libpgm-5.3.so.0 (0x0000003f9e07b000)
libnorm.so.1 => /usr/lib/riscv64-linux-gnu/libnorm.so.1 (0x0000003f9df67000)
libgssapi_krb5.so.2 => /usr/lib/riscv64-linux-gnu/libgssapi_krb5.so.2 (0x0000003f9df2e000)
libexpat.so.1 => /usr/local/lib/libexpat.so.1 (0x0000003f9defa000)
libicuuc.so.71 => /usr/lib/riscv64-linux-gnu/libicuuc.so.71 (0x0000003f9dd45000)
libmpg123.so.0 => /usr/lib/riscv64-linux-gnu/libmpg123.so.0 (0x0000003f9dd01000)
libvorbisfile.so.3 => /usr/lib/riscv64-linux-gnu/libvorbisfile.so.3 (0x0000003f9dcf9000)
libudfread.so.0 => /usr/lib/riscv64-linux-gnu/libudfread.so.0 (0x0000003f9dcf1000)
libp11-kit.so.0 => /usr/lib/riscv64-linux-gnu/libp11-kit.so.0 (0x0000003f9dc15000)
libidn2.so.0 => /usr/lib/riscv64-linux-gnu/libidn2.so.0 (0x0000003f9dbf6000)
libunistring.so.2 => /usr/lib/riscv64-linux-gnu/libunistring.so.2 (0x0000003f9da62000)
libtasn1.so.6 => /usr/lib/riscv64-linux-gnu/libtasn1.so.6 (0x0000003f9da51000)
libnettle.so.8 => /usr/lib/riscv64-linux-gnu/libnettle.so.8 (0x0000003f9da0e000)
libhogweed.so.6 => /usr/lib/riscv64-linux-gnu/libhogweed.so.6 (0x0000003f9d9d0000)
libgmp.so.10 => /usr/lib/riscv64-linux-gnu/libgmp.so.10 (0x0000003f9d970000)
libssl.so.3 => /usr/lib/riscv64-linux-gnu/libssl.so.3 (0x0000003f9d8ef000)
libcrypto.so.3 => /usr/lib/riscv64-linux-gnu/libcrypto.so.3 (0x0000003f9d5e1000)
libgcrypt.so.20 => /usr/lib/riscv64-linux-gnu/libgcrypt.so.20 (0x0000003f9d50b000)
libgpg-error.so.0 => /lib/riscv64-linux-gnu/libgpg-error.so.0 (0x0000003f9d4ef000)
libcairo-gobject.so.2 => /usr/lib/riscv64-linux-gnu/libcairo-gobject.so.2 (0x0000003f9d4e3000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/riscv64-linux-gnu/libgdk_pixbuf-2.0.so.0 (0x0000003f9d4c2000)
libgio-2.0.so.0 => /usr/lib/riscv64-linux-gnu/libgio-2.0.so.0 (0x0000003f9d36d000)
libpangocairo-1.0.so.0 => /usr/lib/riscv64-linux-gnu/libpangocairo-1.0.so.0 (0x0000003f9d360000)
libpango-1.0.so.0 => /usr/lib/riscv64-linux-gnu/libpango-1.0.so.0 (0x0000003f9d310000)
libffi.so.8 => /usr/lib/riscv64-linux-gnu/libffi.so.8 (0x0000003f9d307000)
libpcre.so.3 => /lib/riscv64-linux-gnu/libpcre.so.3 (0x0000003f9d2c9000)
libpixman-1.so.0 => /usr/local/lib/libpixman-1.so.0 (0x0000003f9d072000)
libpng16.so.16 => /usr/local/lib/libpng16.so.16 (0x0000003f9d034000)
libxcb-render.so.0 => /usr/local/lib/libxcb-render.so.0 (0x0000003f9d023000)
libXrender.so.1 => /usr/local/lib/libXrender.so.1 (0x0000003f9d017000)
libogg.so.0 => /usr/lib/riscv64-linux-gnu/libogg.so.0 (0x0000003f9d00c000)
libXfixes.so.3 => /usr/local/lib/libXfixes.so.3 (0x0000003f9d005000)
libudev.so.1 => /usr/lib/riscv64-linux-gnu/libudev.so.1 (0x0000003f9cfe6000)
libsndfile.so.1 => /usr/lib/riscv64-linux-gnu/libsndfile.so.1 (0x0000003f9cf81000)
libX11-xcb.so.1 => /usr/local/lib/libX11-xcb.so.1 (0x0000003f9cf7c000)
libsystemd.so.0 => /usr/lib/riscv64-linux-gnu/libsystemd.so.0 (0x0000003f9cedc000)
libasyncns.so.0 => /usr/lib/riscv64-linux-gnu/libasyncns.so.0 (0x0000003f9ced6000)
libwrap.so.0 => /usr/lib/riscv64-linux-gnu/libwrap.so.0 (0x0000003f9cecd000)
libgfortran.so.5 => /usr/lib/riscv64-linux-gnu/libgfortran.so.5 (0x0000003f9cdd0000)
libgraphite2.so.3 => /usr/lib/riscv64-linux-gnu/libgraphite2.so.3 (0x0000003f9cdb0000)
libmd.so.0 => /usr/lib/riscv64-linux-gnu/libmd.so.0 (0x0000003f9cda3000)
libkrb5.so.3 => /usr/lib/riscv64-linux-gnu/libkrb5.so.3 (0x0000003f9ccfb000)
libk5crypto.so.3 => /usr/lib/riscv64-linux-gnu/libk5crypto.so.3 (0x0000003f9cccd000)
libcom_err.so.2 => /lib/riscv64-linux-gnu/libcom_err.so.2 (0x0000003f9ccc9000)
libkrb5support.so.0 => /usr/lib/riscv64-linux-gnu/libkrb5support.so.0 (0x0000003f9ccbc000)
libicudata.so.71 => /usr/lib/riscv64-linux-gnu/libicudata.so.71 (0x0000003f9afb7000)
libgmodule-2.0.so.0 => /usr/lib/riscv64-linux-gnu/libgmodule-2.0.so.0 (0x0000003f9afb2000)
libjpeg.so.62 => /usr/lib/riscv64-linux-gnu/libjpeg.so.62 (0x0000003f9af5d000)
libmount.so.1 => /usr/lib/riscv64-linux-gnu/libmount.so.1 (0x0000003f9af12000)
libselinux.so.1 => /lib/riscv64-linux-gnu/libselinux.so.1 (0x0000003f9aeed000)
libresolv.so.2 => /lib/riscv64-linux-gnu/libresolv.so.2 (0x0000003f9aedc000)
libpangoft2-1.0.so.0 => /usr/lib/riscv64-linux-gnu/libpangoft2-1.0.so.0 (0x0000003f9aec9000)
libthai.so.0 => /usr/lib/riscv64-linux-gnu/libthai.so.0 (0x0000003f9aec1000)
libFLAC.so.8 => /usr/lib/riscv64-linux-gnu/libFLAC.so.8 (0x0000003f9ae99000)
libcap.so.2 => /lib/riscv64-linux-gnu/libcap.so.2 (0x0000003f9ae8f000)
libzstd.so.1 => /usr/lib/riscv64-linux-gnu/libzstd.so.1 (0x0000003f9ade3000)
liblz4.so.1 => /usr/lib/riscv64-linux-gnu/liblz4.so.1 (0x0000003f9adc0000)
libnsl.so.2 => /usr/lib/riscv64-linux-gnu/libnsl.so.2 (0x0000003f9adad000)
libkeyutils.so.1 => /lib/riscv64-linux-gnu/libkeyutils.so.1 (0x0000003f9ada8000)
libblkid.so.1 => /usr/lib/riscv64-linux-gnu/libblkid.so.1 (0x0000003f9ad62000)
libpcre2-8.so.0 => /usr/lib/riscv64-linux-gnu/libpcre2-8.so.0 (0x0000003f9ad0d000)
libdatrie.so.1 => /usr/lib/riscv64-linux-gnu/libdatrie.so.1 (0x0000003f9ad07000)
libtirpc.so.3 => /lib/riscv64-linux-gnu/libtirpc.so.3 (0x0000003f9ace5000)
Nick
mzs
January 8, 2023, 2:21pm
4
One problem with ldd is that it only shows up
dynamically linked shared libraries that were linked at compile time.
I only learned recently there there are also dynamic, manually loaded at runtime libraries (man dlopen) that ldd does not show. I have no idea how to show what the program is trying to access and from where, other than to debug the program as it runs with strace.
An example of this would be where a programmer scans the USB ports looking for SDR devices (Software Defined Radio) and then only attempts at runtime to load the libraries for the hardware that was plugged into the computer. And then only use functions that were in the libraries that were loaded to access the hardware that is present at that time.
Manux
January 8, 2023, 2:23pm
5
Then this is your main problem. If they are not there they are not detected. Could it be that the -dev packages only holds the source code to build the libs yourself.
A short search turned up: Debian -- Details of package libomxil-bellagio-bin in sid
There seems to be a bin file of the same thing. This should be precompiled.
But there is also this: Debian -- Details of package libomxil-bellagio0 in sid
Point beeing: Make sure you install the package you need
You could also recompile ffmpeg. Could be that the names are not correct. See: ffmpeg h264_omx encoder - libomxcore.so missing. - Raspberry Pi Forums
Issue with libOmxCore.so not found on RPi4 on Arch Linux · Issue #1715 · jellyfin/jellyfin · GitHub
Manux
January 8, 2023, 2:26pm
6
Thanks did not know this!
Thanks for that.
I did try compiling FFMPEG last night for the h264_v4l2m2m codec as I read somewhere that the OMX codec was being deprecated (I can’t find the article right now, I’ll add it here if I can find it again). That didn’t work (not that I’m overly surprised) the error being:
[h264_v4l2m2m @ 0x2ad66b3be0] Could not find a valid device
[h264_v4l2m2m @ 0x2ad66b3be0] can't configure encoder
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
I’ll try recompiling specifically for h264_omx and report back.
Edit: Link to article mentioned above Hardware Accelerated Video Encoding on the Raspberry Pi 4 on Ubuntu 20.04 64-bit
Manux
January 8, 2023, 2:53pm
8
I would first try to find the right package to install so you the get needed .so files in the system. If that does not work try to recompile ffmpeg.
mzs
January 8, 2023, 3:52pm
9
Have you checked is the file missing:
ls -l /usr/local/lib/libOMX_Core.so
ls -l /usr/local/lib/libf-omx-il.so
EDIT: Just noticed that you are running the “minimal version”
Did you download and install the package ?
Goto https://debian.starfivetech.com/ → select either one → Engineering Release → Image-69 → minimal → debian-packs → download ffmpeg_gstreamer_riscv64.deb
Or there is always source code: https://github.com/starfive-tech/soft_3rdpart/tree/JH7110_VisionFive2_devel/omx-il
Ahhh that’s helped alot thank you. I originally installed ffmpeg using APT.
Having installed debian-packs → download ffmpeg_gstreamer_riscv64.deb the .so not found errors have now gone. Progress! I also installed the extra packages noted in the Readme.md file in debian-packs.
The next error that I’m chasing down is
[h264_omx @ 0x2ad9799d40] No component for role video_encoder.avc found
I’m starting to wonder if I should install the full version and see if it works there, then chase down issues with minimal later.
mzs
January 8, 2023, 4:26pm
12
At time like this a spare SD card or two is useful.
I’ve installed that many random packages onto this one now that it’ll almost certainly end up getting nuked soon anyway, but yes in hindsight I probably should have bought a few to chop and change.
So I’ve nuked the SD card and installed the full version of image-69. FFMPEG was already installed this time, I didn’t have to install it which was good. I ran the command again ffmpeg -i /dev/video4 -c:v h264_omx ./test.mp4 with the same error message as before.
[h264_omx @ 0x2ace8e0d40] No component for role video_encoder.avc found
This is promising for the minimal image at least once this error is solved.
Some more debugging info just in case it helps anyone.
root@starfive:~# lsmod
Module Size Used by
jpu 24576 0
vdec 28672 0
venc 28672 0
root@starfive:~# ls /dev
autofs i2c-6 mtd2ro ptyb4 ptyd0 ptyec ptyq8 ptys4 ptyu0 ptyvc ptyx8 ptyz4 tty14 tty4 tty8 ttyb4 ttyd0 ttyec ttyq7 ttys3 ttytf ttyvb ttyx7 ttyz3 vcsa5
block i2c-7 mtdblock0 ptyb5 ptyd1 ptyed ptyq9 ptys5 ptyu1 ptyvd ptyx9 ptyz5 tty15 tty40 tty9 ttyb5 ttyd1 ttyed ttyq8 ttys4 ttyu0 ttyvc ttyx8 ttyz4 vcsa6
bus initctl mtdblock1 ptyb6 ptyd2 ptyee ptyqa ptys6 ptyu2 ptyve ptyxa ptyz6 tty16 tty41 ttyS0 ttyb6 ttyd2 ttyee ttyq9 ttys5 ttyu1 ttyvd ttyx9 ttyz5 vcsa7
char input mtdblock2 ptyb7 ptyd3 ptyef ptyqb ptys7 ptyu3 ptyvf ptyxb ptyz7 tty17 tty42 ttyS1 ttyb7 ttyd3 ttyef ttyqa ttys6 ttyu2 ttyve ttyxa ttyz6 vcsu
console jpu null ptyb8 ptyd4 ptyp0 ptyqc ptys8 ptyu4 ptyw0 ptyxc ptyz8 tty18 tty43 ttyS2 ttyb8 ttyd4 ttyp0 ttyqb ttys7 ttyu3 ttyvf ttyxb ttyz7 vcsu1
cpu_dma_latency kmsg port ptyb9 ptyd5 ptyp1 ptyqd ptys9 ptyu5 ptyw1 ptyxd ptyz9 tty19 tty44 ttyS3 ttyb9 ttyd5 ttyp1 ttyqc ttys8 ttyu4 ttyw0 ttyxc ttyz8 vcsu2
cuse log ptmx ptyba ptyd6 ptyp2 ptyqe ptysa ptyu6 ptyw2 ptyxe ptyza tty2 tty45 ttyS4 ttyba ttyd6 ttyp2 ttyqd ttys9 ttyu5 ttyw1 ttyxd ttyz9 vcsu3
disk loop-control pts ptybb ptyd7 ptyp3 ptyqf ptysb ptyu7 ptyw3 ptyxf ptyzb tty20 tty46 ttyS5 ttybb ttyd7 ttyp3 ttyqe ttysa ttyu6 ttyw2 ttyxe ttyza vcsu4
dri loop0 ptya0 ptybc ptyd8 ptyp4 ptyr0 ptysc ptyu8 ptyw4 ptyy0 ptyzc tty21 tty47 ttya0 ttybc ttyd8 ttyp4 ttyqf ttysb ttyu7 ttyw3 ttyxf ttyzb vcsu5
dwdma loop1 ptya1 ptybd ptyd9 ptyp5 ptyr1 ptysd ptyu9 ptyw5 ptyy1 ptyzd tty22 tty48 ttya1 ttybd ttyd9 ttyp5 ttyr0 ttysc ttyu8 ttyw4 ttyy0 ttyzc vcsu6
fd loop2 ptya2 ptybe ptyda ptyp6 ptyr2 ptyse ptyua ptyw6 ptyy2 ptyze tty23 tty49 ttya2 ttybe ttyda ttyp6 ttyr1 ttysd ttyu9 ttyw5 ttyy1 ttyzd vcsu7
full loop3 ptya3 ptybf ptydb ptyp7 ptyr3 ptysf ptyub ptyw7 ptyy3 ptyzf tty24 tty5 ttya3 ttybf ttydb ttyp7 ttyr2 ttyse ttyua ttyw6 ttyy2 ttyze vdec
fuse loop4 ptya4 ptyc0 ptydc ptyp8 ptyr4 ptyt0 ptyuc ptyw8 ptyy4 random tty25 tty50 ttya4 ttyc0 ttydc ttyp8 ttyr3 ttysf ttyub ttyw7 ttyy3 ttyzf venc
gpiochip0 loop5 ptya5 ptyc1 ptydd ptyp9 ptyr5 ptyt1 ptyud ptyw9 ptyy5 rtc tty26 tty51 ttya5 ttyc1 ttydd ttyp9 ttyr4 ttyt0 ttyuc ttyw8 ttyy4 urandom vga_arbiter
gpiochip1 loop6 ptya6 ptyc2 ptyde ptypa ptyr6 ptyt2 ptyue ptywa ptyy6 rtc0 tty27 tty52 ttya6 ttyc2 ttyde ttypa ttyr5 ttyt1 ttyud ttyw9 ttyy5 v4l video0
hugepages loop7 ptya7 ptyc3 ptydf ptypb ptyr7 ptyt3 ptyuf ptywb ptyy7 shm tty28 tty53 ttya7 ttyc3 ttydf ttypb ttyr6 ttyt2 ttyue ttywa ttyy6 vcs video1
hvc0 media0 ptya8 ptyc4 ptye0 ptypc ptyr8 ptyt4 ptyv0 ptywc ptyy8 snd tty29 tty54 ttya8 ttyc4 ttye0 ttypc ttyr7 ttyt3 ttyuf ttywb ttyy7 vcs1 video2
hvc1 mem ptya9 ptyc5 ptye1 ptypd ptyr9 ptyt5 ptyv1 ptywd ptyy9 spidev1.0 tty3 tty55 ttya9 ttyc5 ttye1 ttypd ttyr8 ttyt4 ttyv0 ttywc ttyy8 vcs2 video3
hvc2 mmcblk1 ptyaa ptyc6 ptye2 ptype ptyra ptyt6 ptyv2 ptywe ptyya stderr tty30 tty56 ttyaa ttyc6 ttye2 ttype ttyr9 ttyt5 ttyv1 ttywd ttyy9 vcs3 video4
hvc3 mmcblk1p1 ptyab ptyc7 ptye3 ptypf ptyrb ptyt7 ptyv3 ptywf ptyyb stdin tty31 tty57 ttyab ttyc7 ttye3 ttypf ttyra ttyt6 ttyv2 ttywe ttyya vcs4 video5
hvc4 mmcblk1p2 ptyac ptyc8 ptye4 ptyq0 ptyrc ptyt8 ptyv4 ptyx0 ptyyc stdout tty32 tty58 ttyac ttyc8 ttye4 ttyprintk ttyrb ttyt7 ttyv3 ttywf ttyyb vcs5 video6
hvc5 mmcblk1p3 ptyad ptyc9 ptye5 ptyq1 ptyrd ptyt9 ptyv5 ptyx1 ptyyd tty tty33 tty59 ttyad ttyc9 ttye5 ttyq0 ttyrc ttyt8 ttyv4 ttyx0 ttyyc vcs6 video7
hvc6 mqueue ptyae ptyca ptye6 ptyq2 ptyre ptyta ptyv6 ptyx2 ptyye tty0 tty34 tty6 ttyae ttyca ttye6 ttyq1 ttyrd ttyt9 ttyv5 ttyx1 ttyyd vcs7 watchdog
hvc7 mtd0 ptyaf ptycb ptye7 ptyq3 ptyrf ptytb ptyv7 ptyx3 ptyyf tty1 tty35 tty60 ttyaf ttycb ttye7 ttyq2 ttyre ttyta ttyv6 ttyx2 ttyye vcsa watchdog0
hwrng mtd0ro ptyb0 ptycc ptye8 ptyq4 ptys0 ptytc ptyv8 ptyx4 ptyz0 tty10 tty36 tty61 ttyb0 ttycc ttye8 ttyq3 ttyrf ttytb ttyv7 ttyx3 ttyyf vcsa1 zero
i2c-0 mtd1 ptyb1 ptycd ptye9 ptyq5 ptys1 ptytd ptyv9 ptyx5 ptyz1 tty11 tty37 tty62 ttyb1 ttycd ttye9 ttyq4 ttys0 ttytc ttyv8 ttyx4 ttyz0 vcsa2
i2c-2 mtd1ro ptyb2 ptyce ptyea ptyq6 ptys2 ptyte ptyva ptyx6 ptyz2 tty12 tty38 tty63 ttyb2 ttyce ttyea ttyq5 ttys1 ttytd ttyv9 ttyx5 ttyz1 vcsa3
i2c-5 mtd2 ptyb3 ptycf ptyeb ptyq7 ptys3 ptytf ptyvb ptyx7 ptyz3 tty13 tty39 tty7 ttyb3 ttycf ttyeb ttyq6 ttys2 ttyte ttyva ttyx6 ttyz2 vcsa4
root@starfive:~# uname -a
Linux starfive 5.15.0-starfive #1 SMP Mon Dec 19 07:56:37 EST 2022 riscv64 GNU/Linux
Manux
January 8, 2023, 9:37pm
16
This looks to me like an “normal” ffmpeg error. Meaning: The programm functions like it should be (no crashes or librarys missing) but there is an error in the parameters the user sent or something is missing. It feels like you missing a parameter or something but i would say the programm itself works as it should.
Google turns up this:
hi,magicsmoke,
Glad to receive your question,and I can understand what you’re confusion.
Now let me answer your question:
In your command , the encoder used is h264_omx.But VPU didn’t support h264 encoding,so you can change h264_omx to hevc_omx.
ffmpeg -i /dev/video4 -c:v hevc_omx test.mp4
And then you can get test.mp4,you can use ffplay to play it on the desktop
ffplay -i test.mp4
I hope this reply will help you
mzs
January 9, 2023, 10:17am
18
Thanks, makes total sense.
From the JH7110 datasheet :
Video Decode H264/H265 4k@60 fps
Video Encode H265 1080p@30 fps
Ahhh that makes sense.
Thank you for the response it worked perfectly.
Encoding at 10fps with virtually no CPU loading at all. I’m not sure why its 10fps for the moment, it could be my camera, or a setting that needs changing etc. but it’s not a problem right now for my application.
When I get a second I’ll try again with the minimal distribution, though I’m not expecting any issues now I have it running.
Thank you to everyone for your help, so far I’m loving the VisionFive 2 board
mzs
January 9, 2023, 10:46am
20
I’d try:
$ 4l2-ctl --device=/dev/video4 --list-formats
$ v4l2-ctl --device=/dev/video4 --list-formats-ext
(you may need to do a “sudo apt install v4l-utils ”, not sure)
And see what is supported.
