回头看下这两家的,谢谢
从github上下载2.5.0版本的sdimage,有800M,多次下载失败,请问有没有其他方式可以下载?
github从国内连接建议使用代理,直连不稳定
对,可以的
试了下后,发现当前的VF2板子,更新SPL和U-Boot后,是先从QSPI启动U-Boot(SPL => U-Boot ???),再启动SD卡里的69版本的系统(当前刷的是minimal),这样理解是不是正确的?
应该没错
是的,直接拨动启动模式为SD卡启动是失败的;只有拨到QSPI模式下,才能启动SD卡里刷的系统。有个问题就是,当前这种模式,是否能从QSPI启动EMMC里刷的系统?
或者更进一步,是否能从QSPI启动NMVE SSD里刷的系统?
NVME应该不行,目前uboot不包含7110 soc的pcie驱动;EMMC我正在测试
好的,谢谢,如果EMMC可以请通知一下。
没能启动,提示载入设备树失败,我再看看
U-Boot SPL 2021.10 (Dec 25 2022 - 20:59:18 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x40000000
Firmware Size : 360 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 3
Domain0 Region01 : 0x0000000040000000-0x000000004007ffff ()
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 3
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Dec 25 2022 - 20:59:18 +0800), Build: jenkins-github_visionfive2-4
CPU: rv64imacu
Model: StarFive VisionFive V2
DRAM: 4 GiB
Product full SN: VF7110B1-2253-D004E000-40000003
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:28:dd
Ethernet MAC1 address: 6c:cf:39:00:28:de
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
switch to partitions #0, OK
mmc0(part 0) is current device
bootmode flash device 0
Can't set block device
Failed to load '/boot/uEnv.txt'
Importing environment from mmc0 ...
Couldn't find partition mmc 1:2
## Error: "boot2" not defined
Scanning mmc 0:2...
Found /boot/extlinux/extlinux.conf
823 bytes read in 3 ms (267.6 KiB/s)
U-Boot menu
Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
9684953 bytes read in 210 ms (44 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.0-starfive
8015200 bytes read in 174 ms (43.9 MiB/s)
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Retrieving file: /boot/dtbs/starfive/starfive_visionfive2.dtb
Failed to load '/boot/dtbs/starfive/starfive_visionfive2.dtb'
kernel_comp_addr_r or kernel_comp_size is not provided!
8015200 bytes read in 175 ms (43.7 MiB/s)
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 single
SCRIPT FAILED: continuing...
** Unable to read file ubootefi.var **
Failed to load EFI variables
Scanning mmc 0:3...
ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
StarFive #
重新刷写了一遍也没能起来,@Michael.Zhu 你们试过吗?
你是说的debian image,我们没有这么试过,buildroot的image我们试过
你是在sd的debian image系统里,通过dd烧录image到emmc,对么?
是的,我把原版镜像复制到sd卡然后dd进入emmc
你说的buildroot是指的Linux还是U-Boot ? 有没有SPL 和 U-Boot 的架构和流程图说明 ?对这方面是小白,有没有合适的文档说明 VF2 的整个启动流程?
还有就是 U-Boot 是怎么加载 debian 的?如果实现直接SD卡、EMMC、NVME启动,是需要在SPL还是U-Boot里实现?
sdk(基于buildroot),麻烦给个地址
