Neo
December 27, 2022, 8:04am
1
用BalenaEtcher制作完sd卡后
在uboot加载出现了如下问题
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
Model: StarFive VisionFive V2
switch to partitions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
Can't set block device
Failed to load '/boot/uEnv.txt'
## Error: "boot2" not defined
Scanning mmc 1:2...
Found /boot/extlinux/extlinux.conf
823 bytes read in 4 ms (200.2 KiB/s)
U-Boot menu
Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
9684953 bytes read in 410 ms (22.5 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.0-starfive
8015200 bytes read in 339 ms (22.5 MiB/s)
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Retrieving file: /boot/dtbs/starfive/starfive_visionfive2.dtb
Failed to load '/boot/dtbs/starfive/starfive_visionfive2.dtb'
kernel_comp_addr_r or kernel_comp_size is not provided!
9684953 bytes read in 411 ms (22.5 MiB/s)
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 single
SCRIPT FAILED: continuing...
** Unable to read file ubootefi.var **
Failed to load EFI variables
Scanning mmc 1:3...
ethernet@16040000 Waiting for PHY auto negotiation to complete.... done
BOOTP broadcast 1
我尝试在uboot中输入该命令去测试这个问题
load mmc 1:2 0xa0000000 boot/dtbs/starfive/starfive_visionfive2.dtb
结果和上面的log是一样的。
但是我用fatls命令是能看到该文件的
StarFive # fatls mmc 1:2 boot/dtbs/starfive/
64747 jh7110-evb-can-pdm-pwmdac.dtb
64147 jh7110-evb-dvp-rgb2hdmi.dtb
64611 jh7110-evb-i2s-ac108.dtb
65042 jh7110-evb-pcie-i2s-sd.dtb
64267 jh7110-evb-spi-uart2.dtb
64303 jh7110-evb-uart1-rgb2hdmi.dtb
64805 jh7110-evb-uart4-emmc-spdif.dtb
64903 jh7110-evb-uart5-pwm-i2c-tdm.dtb
64251 jh7110-evb-usbdevice.dtb
64564 jh7110-evb.dtb
63408 jh7110-fpga.dtb
47118 jh7110-visionfive-v2-A10.dtb
47294 jh7110-visionfive-v2-A11.dtb
48184 jh7110-visionfive-v2-ac108.dtb
48247 jh7110-visionfive-v2-wm8960.dtb
47546 jh7110-visionfive-v2.dtb
evb-overlay/
vf2-overlay/
16 file(s), 4 dir(s)
这种问题需要怎么解决?已经升级了论坛里的新固件
fb4dabdefecd21ebcd8b0c3c84174aea,visionfive2_fw_payload.img
1a8e399f270982acc6de88bb21bc9070,u-boot-spl.bin.normal.out
请更新下uboot和spl,因为这个版本解决了eth0网络不同以及ddr容量不对的问题;
具体更新办法详见更新SPL和U-Boot 通过在uboot环境下输入tftpboot命令,教程里只举例在ubuntu下面通过tftpd传输文件至开发板,如果你是windows PC,请下载tftpd32 再传输,其他类似;
最新的uboot和spl请从这里下载昉·星光 2 Debian Image 69工程版本推出
Neo
December 28, 2022, 2:19am
6
U-Boot SPL 2021.10 (Dec 25 2022 - 20:59:18 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x40000000
Firmware Size : 360 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region01 : 0x0000000040000000-0x000000004007ffff ()
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Dec 25 2022 - 20:59:18 +0800), Build: jenkins-github_visionfive2-4
CPU: rv64imacu
DRAM: 4 GiB
OK
Product full SN: VF7110A1-2249-D004E000-xxxxxxxx
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:xxxxx
Ethernet MAC1 address: 6c:cf:39:00:xxxxx
In: serial@10000000
found device 1
Scanning mmc 1:2...
U-Boot menu
Scanning mmc 1:3...
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
DHCP client bound to address 192.168.xxx.xxx (7781 ms)
Using ethernet@16040000 device
TFTP from server 192.168.xxx.xxx; our IP address is 192.168.xxx.xxx; sending through gateway 192.168.xxx.1
Filename 'boot.scr.uimg'.
Load address: 0x88100000
Loading: *
TFTP error: 'File not found' (1)
Not retrying...
BOOTP broadcast 1
DHCP client bound to address 192.168.xxx.xxx (21 ms)
Load address: 0x44000000
Loading: *
Not retrying...
你改过环境变量吗?请清除下uboot下的环境变量eraseenv,再重启试试
olofj
January 13, 2023, 11:01pm
10
I can confirm that for me, updating u-boot and SBI helped.
What’s awkward is needing to do tftpboot setup. Instead, I just copied in the files onto the EFI partition (FAT filesystem) on the SD card, and loaded from there. It might be a good enhancement of both the image contents by always having it included, and the instructions to make it easier. Could even do an alias in u-boot for it so it’s a one-command thing.
kesmik
January 16, 2023, 1:20pm
11
Hello,
Agree with @olofj , I have written information on how I reflashed SPL and u-Boot without tftboot here: VisionFive 2 Debian Image Released - #73 by kesmik
May be usefull for someone IDK
