The certificates on the snapshot repository used by the 202405 debian release expired today. 22 aug 2024.
It is no longer possible to run apt get to install additional software etc. Or run the install_package_and_dependencies.sh script on new installs.
Suggestions?
- adding
[trusted=yes]to the line in/etc/apt/sources.listdoes not work.
root@starfive:~# cat /etc/apt/sources.list
deb [trusted=yes] https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable main
But when I tried to install an additional package I get:
root@starfive:~# apt install python3-pip
Reading package lists... Done
The following additional packages will be installed:
python3-setuptools python3-wheel
Suggested packages:
python-setuptools-doc
The following NEW packages will be installed:
python3-pip python3-setuptools python3-wheel
0 upgraded, 3 newly installed, 0 to remove and 19 not upgraded.
Need to get 1872 kB of archives.
After this operation, 9517 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-setuptools all 65.5.0-1.1
Ign:2 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-wheel all 0.38.4-1
Ign:3 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-pip all 22.3.1+dfsg-1
Err:1 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-setuptools all 65.5.0-1.1
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 185.213.153.170 443]
Err:2 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-wheel all 0.38.4-1
Err:3 https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable/main riscv64 python3-pip all 22.3.1+dfsg-1
E: Failed to fetch https://snapshot.debian.org/archive/debian-ports/20221225T084846Z/pool/main/s/setuptools/python3-setuptools_65.5.0-1.1_all.deb Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 185.213.153.170 443]
E: Failed to fetch https://snapshot.debian.org/archive/debian-ports/20221225T084846Z/pool/main/w/wheel/python3-wheel_0.38.4-1_all.deb Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 185.213.153.170 443]
E: Failed to fetch https://snapshot.debian.org/archive/debian-ports/20221225T084846Z/pool/main/p/python-pip/python3-pip_22.3.1%2bdfsg-1_all.deb Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 185.213.153.170 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
