Hello guys,
received my VF2 yesterday and got it successfully to run latest Debian 202306 Image. I flashed the latest U-Boot/SPL with mtd-tools and it restarted successful.
Hello @XeroX - I’m not sure I understand, I think you’d have to have this set to boot anything from SDcard, but:
On my VisionFive2 board, 1.3B the 2 dip switches have to be set to 1-right and 2-left to boot from SDcard.
To clarify, with the board facing you and the large “StarFive” above the JH7110 chip readable, the top switch has to pushed right (1-on) and the bottom switch left (2-off).
i’m having the issue with the ubuntu 23.04 image. However I have an NVMe
(i didnt not have problems with my debian image i wiped away)
i burned the image to the nvme, but it is giving this error:
** Invalid partition 3 **
Couldn't find partition nvme 0:3
Can't set block device
Importing environment from 1/0 ...
## Error: "boot2" not defined
pci enum ...
IDE device 0: Vendor: 0x1987 Rev: EDFM80.1 Prod: 7E9607331EBE00233190
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete....... done
