Booting from the microSD card fails when I add an empty NVMe:
U-Boot SPL 2021.10 (Jun 21 2023 - 13:42:04 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Jun 21 2023 - 13:42:04 +0800), Build: jenkins-github_visionfive2-15
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
Product full SN: VF7110B1-<redacted>
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:<redacted>
Ethernet MAC1 address: 6c:cf:39:<redacted>
In: serial
Out: serial
Err: serial
PCI: Failed autoconfig bar 10
pci enum ...
IDE device 0: Vendor: 0x144d Rev: 1B4QFXO7 Prod: S649NG0R313425L
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
bootmode flash device 1/0
** No partition table - nvme 0 **
Couldn't find partition nvme 0:3
Can't set block device
Importing environment from 1/0 ...
## Error: "boot2" not defined
pci enum ...
Type: Hard Disk
ethernet@16030000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 192.168.3.172 (3268 ms)
TFTP from server 192.168.3.1; our IP address is 192.168.3.172
Filename 'boot.scr.uimg'.
Load address: 0x43900000
Loading: *
TFTP server died; starting again
BOOTP broadcast 1
DHCP client bound to address 192.168.3.172 (5 ms)
Load address: 0x40200000
Loading: *
StarFive #
After unplucking the NVMe the system boots fine from the microSD:
*** local echo: yes ***
OpenSBI v1.2
Domain0 Name : root
Boot HART ID : 1
DRAM: 8 GiB
PCB revision: 0xb2
In: serial
Out: serial
Err: serial
pci enum ...
no nvme devices available
switch to partitions #0, OK
mmc1 is current device
found device 1
Couldn't find partition mmc 0xa0000000
Hit any key to stop autoboot: 2
Please support this use case.
