When ever I attempt to boot with an SSD ’
In: serial
Out: serial
Err: serial
Model: StarFive VisionFive V2
PCI: Failed autoconfig bar 10
pci enum ...
IDE device 0: Vendor: 0x15b7 Rev: 731100WD Prod: 23034L800475
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
bootmode flash device 1/0
** No partition table - nvme 0 **
Couldn't find partition nvme 0:3
Can't set block device
Importing environment from 1/0 ...
## Error: "boot2" not defined
pci enum ...
Type: Hard Disk
ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT!
phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto ne!
phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto ne!
I am attempting to boot off of a microsd card with DietPi on it.
