I understand that the VF2 uses the U74 cpu from SiFive
But when compiling I get the error
Error: unknown CSR `mtvt’
This register should be present in the cpu, So I am assuming the compiler is not supporting it.
Is there a plan to add this register so that customers can use the “asm volatile(“csrr %0, 0x307” : “=r”(mtvt));”
for work on ecalls and other privileged modes?
My very first step would be to check the version of my assembler (“as --version”) if it was failing to understand what should be a valid instruction. My second step would be to upgrade to the very latest “GNU Binutils” package for the OS I was using. And if that was too old then my next step would be to get the very latest source code for for “as” (the GNU assembler) and compile my own “as” (and I would remove the package before I “make install” the newly compiled source code).
Mtvt seems belong to clic spec which isn’t ratified yet. So sifive uses a pre-standard spec version for it and thus it needs a downstream compiler toolchain for it unless you choose to not use clic.
I did a “rgrep mtvt *” on the latest binutils source code and the one and only mention of “mtvt” is totally unrelated to RISC-V, for the PowerPC architecture.
So I would agree, until ratified, it is probably not going to be supported upstream.
I could be wrong but it looks like “mtvt” 0x307 is not in the current draft of riscv privileged instructions. But “mtvec” (0x305) (Machine Trap-Vector Base-Address Register) which is in the current draft is supported by “as” (the GNU assembler) as a draft instruction. To me it looks like “mtvec” has replaced “mtvt”, so I suspect that it might never be added upstream.
Hi, if I understand correctly mtvt is only used when the CLIC is available, which is only available in the E24 core.
As mentioned before the mtvt is probably only going to come to gas and llvm-as releases after it’s ratified, though I’d mention that if you use numeric CSR numbers like:
asm volatile("csrr %0, 0x307" : "=r"(mtvt) : :);
It should already be possible on existing assemblers.
