config:
root@KensStarFive:/etc/lightdm# lightdm --show-config
[Seat:*]
A greeter-session=lightdm-greeter
A greeter-hide-users=true
A session-wrapper=/etc/X11/Xsession
B display-setup-script=xrandr -s 1920x1080
B autologin-user=user
B autologin-user-timeout=0
Sources:
A /usr/share/lightdm/lightdm.conf.d/01_debian.conf
B /etc/lightdm/lightdm.conf
lightdm.log:
+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.26.0, UID=0 PID=2592
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/01_debian.conf
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Registered seat module unity
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Using cross-namespace EXTERNAL authentication (this will deadlock if server is GDBus < 2.73.3)
[+0.01s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.01s] DEBUG: Monitoring logind for seats
[+0.01s] DEBUG: New seat added from logind: seat0
[+0.01s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.01s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.01s] DEBUG: Seat seat0: Starting
[+0.01s] DEBUG: Seat seat0: Creating user session
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.02s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.03s] DEBUG: Seat seat0: Creating display server of type x
[+0.04s] DEBUG: Using VT 7
[+0.04s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.04s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.04s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
[+0.04s] DEBUG: XServer 0: Launching X Server
[+0.04s] DEBUG: Launching process 2598: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.04s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.04s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.04s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.08s] DEBUG: Process 2598 exited with return value 1
[+0.08s] DEBUG: XServer 0: X server stopped
[+0.08s] DEBUG: Releasing VT 7
[+0.08s] DEBUG: XServer 0: Removing X server authority /var/run/lightdm/root/:0
[+0.08s] DEBUG: Seat seat0: Display server stopped
[+0.08s] DEBUG: Seat seat0: Stopping session
[+0.08s] DEBUG: Seat seat0: Session stopped
+0.09s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.09s] DEBUG: Seat seat0: Active display server stopped, starting greeter
[+0.09s] DEBUG: Seat seat0: Creating greeter session
[+0.09s] DEBUG: Seat seat0: Creating display server of type x
[+0.09s] DEBUG: Using VT 7
[+0.09s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.09s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.09s] DEBUG: XServer 0: Writing X server authority to /var/run/lightdm/root/:0
[+0.09s] DEBUG: XServer 0: Launching X Server
[+0.09s] DEBUG: Launching process 2599: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.09s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.12s] DEBUG: Process 2599 exited with return value 1
[+0.12s] DEBUG: XServer 0: X server stopped
[+0.12s] DEBUG: Releasing VT 7
[+0.12s] DEBUG: XServer 0: Removing X server authority /var/run/lightdm/root/:0
[+0.12s] DEBUG: Seat seat0: Display server stopped
[+0.12s] DEBUG: Seat seat0: Stopping session
[+0.12s] DEBUG: Seat seat0: Session stopped
[+0.12s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.12s] DEBUG: Seat seat0: Stopping; greeter display serve
Hi.
I am trying to bring up Ubuntu image on VisionFive2 board using SD card.
I flashed the ubuntu-23.04-preinstalled-server-riscv64+visionfive2.img into micro-SD card using BalenaEtcher software.
I follow the steps to install ubuntu image on VisionFive2 board as:
The boot mode set to SPI flash (DIP switches RGPIO_0 = 0, RGPIO_1 = 0) as the Ubuntu image comes without U-Boot.
Connect to the UART using a UART-TTL USB adapter. For accessing the serial console you can use minicom: sudo minicom -D /dev/ttyUSB0 -b 115200
Insert the SD card, Connect Ethernet cable and power on the board.
Booted successfully and able to login with user ubuntu and the password ubuntu.
After login, I found the IP address of VisionFive2 board by using command as ip a.
I have confirmed that ssh, scp and ping are working correctly.
Then, I run the command for basic package installation as, sudo apt-get update. After running that command, I am getting an error as shown in below figure.
