硬盘盒是usb?会不会是供电缘故
是nvme转接USB3的硬盘盒。我感觉应该不是供电问题,这个盒子在不需要额外供电的情况下在五台不同的x86机器都能正常工作,我也在radxa rock 3a(rk3568)上测试能正常工作
你可以再开个终端(ssh)进去看看,是不是这个进程挂了,还是整个系统挂了?另外,读写这张卡的时候有没有什么错误异常的信息?
这个版本的debian支持更换国内的源更新吗?debian snapshot速度有些慢。。。
插入硬盘后未操作时dmesg信息为
[ 201.084949] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[ 201.124580] scsi host0: uas
[ 201.128785] scsi 0:0:0:0: Direct-Access JMicron Tech 0209 PQ: 0 ANSI: 6
[ 203.119676] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 203.127273] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 203.132744] sd 0:0:0:0: [sda] Write Protect is off
[ 203.137653] sd 0:0:0:0: [sda] Mode Sense: 5f 00 00 08
[ 203.138900] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 203.149061] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 203.267339] sda: sda1 sda2 sda4
[ 203.275044] sd 0:0:0:0: [sda] Attached SCSI disk
我这次测试fdisk -l后没有长时间卡住,但是没有读出这块盘的信息。fdisk -l后的dmesg如下,卡住的时候我开启另一个终端连接是可以正常响应的。
[ 355.153618] sd 0:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 355.161713] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 355.203543] scsi host0: uas_eh_device_reset_handler start
[ 355.355043] usb 2-3: reset SuperSpeed USB device number 2 using xhci_hcd
[ 355.388309] scsi host0: uas_eh_device_reset_handler success
[ 363.483469] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=38s
[ 363.493341] sd 0:0:0:0: [sda] tag#14 Sense Key : 0x4 [current]
[ 363.499332] sd 0:0:0:0: [sda] tag#14 ASC=0x44 <<vendor>>ASCQ=0x81
[ 363.505586] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 363.513303] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 363.524181] Buffer I/O error on dev sda, logical block 0, async page read
[ 363.531507] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
[ 363.541174] sd 0:0:0:0: [sda] tag#15 Sense Key : 0x4 [current]
[ 363.547102] sd 0:0:0:0: [sda] tag#15 ASC=0x44 <<vendor>>ASCQ=0x81
[ 363.553290] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 363.560953] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 363.571831] Buffer I/O error on dev sda, logical block 0, async page read
[ 363.579140] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
[ 363.588803] sd 0:0:0:0: [sda] tag#12 Sense Key : 0x4 [current]
[ 363.594731] sd 0:0:0:0: [sda] tag#12 ASC=0x44 <<vendor>>ASCQ=0x81
[ 363.600919] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 363.608582] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 363.619467] Buffer I/O error on dev sda, logical block 0, async page read
[ 405.168590] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
[ 405.178206] sd 0:0:0:0: [sda] tag#8 Sense Key : 0x4 [current]
[ 405.184089] sd 0:0:0:0: [sda] tag#8 ASC=0x44 <<vendor>>ASCQ=0x81
[ 405.190220] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 405.197810] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 405.208738] Buffer I/O error on dev sda, logical block 0, async page read
[ 405.216251] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
[ 405.225959] sd 0:0:0:0: [sda] tag#13 Sense Key : 0x4 [current]
[ 405.231920] sd 0:0:0:0: [sda] tag#13 ASC=0x44 <<vendor>>ASCQ=0x81
[ 405.238120] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 405.245815] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 405.256749] Buffer I/O error on dev sda, logical block 0, async page read
[ 405.264287] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
[ 405.273973] sd 0:0:0:0: [sda] tag#14 Sense Key : 0x4 [current]
[ 405.279906] sd 0:0:0:0: [sda] tag#14 ASC=0x44 <<vendor>>ASCQ=0x81
[ 405.286093] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
[ 405.293789] blk_update_request: critical target error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 405.304697] Buffer I/O error on dev sda, logical block 0, async page read
这时再次fdisk -l不会卡住,但是仍然看不到这块硬盘的信息。lsblk仍然能看到
user@starfive:/dev$ lsblk
sda 8:0 0 232.9G 0 disk
|-sda1 8:1 0 365M 0 part
|-sda2 8:2 0 221G 0 part
`-sda4 8:4 0 11.5G 0 part
mtdblock0 31:0 0 128K 0 disk
mtdblock1 31:1 0 3M 0 disk
mtdblock2 31:2 0 1M 0 disk
mmcblk0 179:0 0 57.6G 0 disk
|-mmcblk0p1 179:1 0 16M 0 part
|-mmcblk0p2 179:2 0 100M 0 part
`-mmcblk0p3 179:3 0 15.5G 0 part
mmcblk1 179:8 0 29.7G 0 disk
|-mmcblk1p1 179:9 0 16M 0 part
|-mmcblk1p2 179:10 0 100M 0 part /boot
`-mmcblk1p3 179:11 0 29.6G 0 part /
mmcblk0boot0 179:16 0 4M 1 disk
mmcblk0boot1 179:24 0 4M 1 disk
试图对其进行挂载会提示如下信息
user@starfive:/dev$ sudo mount /dev/sda4 /mnt/emmc/
sudo: unable to resolve host starfive: Name or service not known
mount: /mnt/emmc: /dev/sda4 is not a valid block device.
dmesg(1) may have more information after failed mount system call.
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use 'systemctl daemon-reload' to reload.
拔下硬盘后dmesg输出如下
[ 865.405145] usb 2-3: USB disconnect, device number 2
[ 865.474845] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 866.074977] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
Debain Image 69版本支持 购买附带的 USB WIFI吗? 如果不支持,需要怎么操作来支持?如果需要编译驱动,那驱动源码有提供的地方吗? 另外就是内核源码在什么地方获取?
谢谢。
目前版本好像没预编译驱动,你参考这个USB Module ESWIN 6600U
谢谢,我之前有按照帖子中尝试,但是编译出来驱动在 69版本中无法insmod, vermagic不匹配。所以我想知道应该用哪个内核来编译
Hello @Stat_headcrabed,
you could self CROSS compile or compile directly on visionfive 2 this kernel source from GitHub - starfive-tech/linux
The Wifi Driver is now included as Module what i see in the commits.
Damian
thanks, actually @kay needs this![]()
In branch JH7110_VisionFive2_devel
insmod得sudo吧
Many thanks, I will try.
文件违规被封禁了么?大文件都看不见了。
阿里云这么无赖
,那没办法了
哪个……好像没说用户名和密码……
我下了 mini 的,改好了分辨率,结果卡在登陆环节…… ![]()
刚安装好,dd到emmc无法启动,这是怎么回事呢?
目前版本debian起不来,buildroot据说可以,但用途不大
