Which u-Boot / SPL firmware to be used?
As I read the info below, I have
OpenSBI VF2_515_v3.1.5_IMG1.19 and U-Boot 2021.10-dirty.
I have downloaded the 202306 and flashed as well SD-Card, using the sd image and the nvme ssd, using the NVMe image.
Boot from SSD works. and can see the NVMe SSD. no boot from NVMe. the info on Release VisionFive2 Software v3.4.5 · starfive-tech/VisionFive2 · GitHub states:
Please do not upgrade u-boot/spl for 8GB DDR VisionFive2 since CMA will not allocated successfully under Debian image 202306;
So which u-boot/spl to be flased ?
dwmci_s: Response Timeout.
U-Boot SPL 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000)
DDR version: dc2e84f0.
Trying to boot from MMC2
Platform HART Count       : 5
Platform Suspend Device   : ---
Firmware Size             : 392 KB
Firmware RW Offset        : 0x40000
Domain0 Boot HART         : 1
Domain0 Region00          : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region01          : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region02          : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: ()
Domain0 Region03          : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X)
Domain0 SysSuspend        : yes
Boot HART ID              : 1
Boot HART PMP Count       : 8
Boot HART MHPM Count      : 2
U-Boot 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000), Build: jenkins-VisionFive2-SDK-Components-135
CPU:   rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM:  8 GiB
Product full SN: VF7110A1-####-########-########
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:..:..:..
Ethernet MAC1 address: 6c:cf:39:..:..:..
In:    serial
Out:   serial
Err:   serial
Error: 1 bit/pixel mode, but BMP has 24 bit/pixel
bootmode sd device 1/0
If you wanna use 202306, you can flash u-boot and spl from Release VisionFive2 Software v3.1.5 · starfive-tech/VisionFive2 · GitHub
thank you so much.
however, it is hard to finding the matching u-boot and spl files - the matching ones should be with the downloads of the releases
flashed with 3.1.5, rebooted, jumpered to 0-0 – now booting off NVMe SSD
thanks a lot for your help
