Web Browsers related help
Hi fellow risc-v pioneers!
I have few questions about the available browsers:
  1. The Web (epiphany) browser doesn’t seem to work. It crashes after few seconds with the message: Aborted (core dump). I reinstalled it but didn’t help. Any ideas?
  2. The Firefox browser although installed, it is not part of the official repository. I realized that to my surprise after I dnf remove it. I tried to dnf install it again but it is not available. The original packages had the @koji-f33-build-1216 repository as origin. How do I add that repository to my repolist?
  3. Chromium Browser was mentioned long time ago that is going to be ported but nothing yet on the official repository. There is a github code repository with instructions: GitHub - starfive-tech/riscv-chromium-patch
    Are we supposed to cross compile it ourselves? When is it going to be included in the distribution?
  4. Midori Browser does not work. It always gives the message: Ops, something went wrong…
Please anyone having some advice reply here.
Thank you
Konstantinos
Web browser, Firefox is the one that currently supports better on visionfive.It is recommended to use Firefox.
Something for me
I use lubuntu and I cannot found chromium or Firefox
But epiphany and Midori work and can visit my blog (https://sy.sa) and google homepage
other websites will make it crash
But Firefox in fedora was best option ( I like lubuntu more because lightweight )
When I was in fedora I cloud access github google youtube and play some videos ( only few frames rendered the rest is dropped every second)
Thank you both for the reply.
But as I said I can’t reinstall Firefox from the fedora repository, it is not there!
Do I need to reinstall the whole image again from the beginning on the micro-sd card? Is there a way to reinstall Firefox?
Thanks
we’ll give you a reply later.
Thank you Julie, I am waiting for your answer.
Repo is not included by default.
you can try to reinstall manually as follows:
  1. download firefox rpm
  2. install firefox on visionfive
    rpm -ivh firefox-92.0.1-1.fc33.riscv64.rpm
If prompted to install dependencies, you could dnf install xxx
Can I get same browser for lubuntu? because lxqt lightweight more then lxde and fedora
Thank you Jianlong Huang!
I don’t think it works for Lubuntu, but you can try it
For question #3, the Github code repo contains the work in progress of porting chromium browser. It is not a working piece yet. As the porting work is a huge effort, we posted the said code repo with a purpose to show what we have achieved so far, to gain traction with the open source community and calling for collaboration in order to speed up the porting process. As of now, we do not have a fixed timeline about when is it going to be included in the distribution.
i’ve maybe not installed the ‘correct’ distro as my Debian has no browser and no other software to speak off
@gbar I assume you are on the 202306 Debian release.
Here are the instructions to get the patched versions of Firefox, Chromium, VLC and LibreOffice.
wget https://github.com/starfive-tech/Debian/releases/download/v0.8.0-engineering-release-wayland/install_package_and_dependencies.sh
chmod +x install_package_and_dependencies.sh
sudo ./install_package_and_dependencies.sh
Here is my YouTube video showing the installation.
Great, it’s churning away now and installing.
Any info on USB wireless functionality? i stupidly purchased non-wifi model
Just a quick check, I suspect that you do not have a VisionFive V1 board - the category of the Forum (Visionfive(English Forum)) where you have posted this post.
See below link for a picture of a VisionFive V1 board (which had built in 2.4 GHz Wi-Fi and Bluetooth 4.2 - BLE)
Or do you have as I strongly suspect a VisionFive V2 - posts normally go in this category of the Forum (Visionfive 2(English Forum)
See below link for a picture of a VisionFive V2 board:
my bad, you’re right
