U-Boot SPL 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000)
DDR version: dc2e84f0.
Trying to boot from MMC2
OpenSBI VF2_515_v3.1.5_IMG1.19
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000), Build: jenkins-VisionFive2-SDK-Components-135
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 4 GiB
Product full SN: VF7110B1-2317-D004E000-17401838
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:74:de
Ethernet MAC1 address: 6c:cf:39:00:74:df
In: serial
Out: serial
Err: serial
Error: 1 bit/pixel mode, but BMP has 24 bit/pixel
bootmode sd device 1/0
Failed to load 'vf2_uEnv.txt'
Importing environment from 1/0 ...
## Info: input data size = 482 = 0x1E2
## Error: "boot2" not defined
406 bytes read in 5 ms (79.1 KiB/s)
50235 bytes read in 10 ms (4.8 MiB/s)
50235 bytes written in 15 ms (3.2 MiB/s)
792 bytes read in 7 ms (110.4 KiB/s)
U-Boot menu
Enter choice: 1
Retrieving file: /initrd.img-5.15.0-starfive
9272081 bytes read in 406 ms (21.8 MiB/s)
Retrieving file: /vmlinuz-5.15.0-starfive
8574915 bytes read in 377 ms (21.7 MiB/s)
append: root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Uncompressing Kernel Image
Moving Image from 0x44000000 to 0x40200000, end=419b2000
Using Device Tree in place at 0000000048000000, end 000000004800f43a
Starting kernel ...
[ 0.000000] Linux version 5.15.0-starfive (sw_buildbot@mdcsw01) (riscv64-unknown-linux-gnu-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP Sun Jun 11 07:48:39 UTC 2023
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] earlycon: uart0 at MMIO32 0x0000000010000000 (options '115200')
[ 0.000000] printk: bootconsole [uart0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000013fffffff]
[ 0.000000] SBI specification v1.0 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10002
[ 0.000000] SBI SRST extension detected
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] percpu: Embedded 18 pages/cpu s34024 r8192 d31512 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1033735
[ 0.000000] Kernel command line: root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Unknown command line parameters: stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:byref_all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 3449684K/4192256K available (10638K kernel code, 5013K rwdata, 4096K rodata, 2197K init, 666K bss, 218284K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] random: get_random_bytes called from start_kernel+0x4dc/0x6f6 with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.008997] clocksource: timer@13050000.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.020319] clocksource: timer@13050000.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.031641] clocksource: timer@13050000.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.042964] clocksource: timer@13050000.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.054507] Console: colour dummy device 80x25
[ 0.060756] printk: console [tty0] enabled
[ 0.065314] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=40000)
[ 0.076538] pid_max: default: 32768 minimum: 301
[ 0.081793] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.090027] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.100092] ASID allocator disabled
[ 0.104031] rcu: Hierarchical SRCU implementation.
[ 0.109482] EFI services will not be available.
[ 0.114865] smp: Bringing up secondary CPUs ...
[ 0.121502] smp: Brought up 1 node, 4 CPUs
[ 0.127198] devtmpfs: initialized
[ 0.139581] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.150450] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.170951] pinctrl core: initialized pinctrl subsystem
[ 0.177632] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.184840] thermal_sys: Registered thermal governor 'step_wise'
[ 0.185200] cpuidle: using governor menu
[ 0.219908] platform soc:dsi-output: Fixing up cyclic dependency with 29400000.dc8200
[ 0.229109] platform 295d0000.mipi: Fixing up cyclic dependency with soc:dsi-output
[ 0.237978] platform 29590000.hdmi: Fixing up cyclic dependency with 29400000.dc8200
[ 0.259929] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.267332] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.278398] vgaarb: loaded
[ 0.281628] SCSI subsystem initialized
[ 0.286086] usbcore: registered new interface driver usbfs
[ 0.292237] usbcore: registered new interface driver hub
[ 0.298110] usbcore: registered new device driver usb
[ 0.303915] mc: Linux media interface: v0.10
[ 0.308638] videodev: Linux video capture interface: v2.00
[ 0.314894] Advanced Linux Sound Architecture Driver Initialized.
[ 0.322018] Bluetooth: Core ver 2.22
[ 0.325991] NET: Registered PF_BLUETOOTH protocol family
[ 0.331836] Bluetooth: HCI device and connection manager initialized
[ 0.338850] Bluetooth: HCI socket layer initialized
[ 0.344228] Bluetooth: L2CAP socket layer initialized
[ 0.349807] Bluetooth: SCO socket layer initialized
[ 0.355518] clocksource: Switched to clocksource riscv_clocksource
[ 0.362569] FS-Cache: Loaded
[ 0.373197] NET: Registered PF_INET protocol family
[ 0.379101] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.391128] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[ 0.400652] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.409787] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.419030] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.426458] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.434217] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.442612] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.449499] RPC: Registered named UNIX socket transport module.
[ 0.456047] RPC: Registered udp transport module.
[ 0.461221] RPC: Registered tcp transport module.
[ 0.466404] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.474230] PCI: CLS 0 bytes, default 64
[ 0.478987] Unpacking initramfs...
[ 0.479575] Initialise system trusted keyrings
[ 0.488806] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 0.502946] NFS: Registering the id_resolver key type
[ 0.508593] Key type id_resolver registered
[ 0.513209] Key type id_legacy registered
[ 0.517758] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.525147] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.533387] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.538510] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.545755] fuse: init (API version 7.34)
[ 0.590083] NET: Registered PF_ALG protocol family
[ 0.595399] Key type asymmetric registered
[ 0.599967] Asymmetric key parser 'x509' registered
[ 0.605458] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.613653] io scheduler mq-deadline registered
[ 0.618670] io scheduler kyber registered
[ 0.726515] clk-starfive-jh7110 13020000.clock-controller: starfive JH7110 clkgen init successfully.
[ 0.737941] L2CACHE: DataError @ 0x00000000.08040140
[ 0.743490] L2CACHE: DataFail @ 0x00000000.0804000C
[ 0.749011] L2CACHE: No. of Banks in the cache: 8
[ 0.754203] L2CACHE: No. of ways per bank: 16
[ 0.759027] L2CACHE: Sets per bank: 256
[ 0.763260] L2CACHE: Bytes per cache block: 64
[ 0.768179] L2CACHE: Index of the largest way enabled: 15
[ 0.774448] jh7110-pmu 17030000.power-controller: registered 8 power domains
[ 0.851618] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.875478] loop: module loaded
[ 0.883455] spi-nor spi0.0: gd25lq128d (16384 Kbytes)
[ 1.487869] Freeing initrd memory: 9052K
[ 1.510067] 3 fixed-partitions partitions found on MTD device 13010000.spi.0
[ 1.517906] Creating 3 MTD partitions on "13010000.spi.0":
[ 1.523970] 0x000000000000-0x000000040000 : "spl"
[ 1.531032] 0x000000100000-0x000000400000 : "uboot"
[ 1.538073] 0x000000f00000-0x000001000000 : "data"
[ 1.546177] libphy: Fixed MDIO Bus: probed
[ 1.552268] CAN device driver interface
[ 1.557090] starfive-eth-plat 16030000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.568517] starfive-eth-plat 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 1.576806] starfive-eth-plat 16030000.ethernet: DWMAC4/5
[ 1.582862] starfive-eth-plat 16030000.ethernet: DMA HW capability register supported
[ 1.591509] starfive-eth-plat 16030000.ethernet: RX Checksum Offload Engine supported
[ 1.600154] starfive-eth-plat 16030000.ethernet: Wake-Up On Lan supported
[ 1.607715] starfive-eth-plat 16030000.ethernet: TSO supported
[ 1.614156] starfive-eth-plat 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.623391] starfive-eth-plat 16030000.ethernet: Enabled Flow TC (entries=1)
[ 1.631168] starfive-eth-plat 16030000.ethernet: TSO feature enabled
[ 1.638179] starfive-eth-plat 16030000.ethernet: Using 40 bits DMA width
[ 1.899772] libphy: stmmac: probed
[ 1.903549] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.914514] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.926766] starfive-eth-plat 16040000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.938169] starfive-eth-plat 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 1.946454] starfive-eth-plat 16040000.ethernet: DWMAC4/5
[ 1.952506] starfive-eth-plat 16040000.ethernet: DMA HW capability register supported
[ 1.961149] starfive-eth-plat 16040000.ethernet: RX Checksum Offload Engine supported
[ 1.969794] starfive-eth-plat 16040000.ethernet: Wake-Up On Lan supported
[ 1.977353] starfive-eth-plat 16040000.ethernet: TSO supported
[ 1.983789] starfive-eth-plat 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.993034] starfive-eth-plat 16040000.ethernet: Enabled Flow TC (entries=1)
[ 2.000814] starfive-eth-plat 16040000.ethernet: TSO feature enabled
[ 2.007829] starfive-eth-plat 16040000.ethernet: Using 40 bits DMA width
[ 2.268518] libphy: stmmac: probed
[ 2.272296] YT8531 Gigabit Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 2.283262] YT8531 Gigabit Ethernet stmmac-1:01: attached PHY driver (mii_bus:phy_addr=stmmac-1:01, irq=POLL)
[ 2.295866] Intel(R) Wireless WiFi driver for Linux
[ 2.303679] cdns3-starfive 10210000.usbdrd: usb mode 2 2.0 probe success
[ 2.311878] usbcore: registered new interface driver uas
[ 2.317818] usbcore: registered new interface driver usb-storage
[ 2.335977] starfive-rtc 17040000.rtc: registered as rtc0
[ 2.341949] starfive-rtc 17040000.rtc: setting system clock to 2001-01-01T00:00:00 UTC (978307200)
[ 2.352001] i2c_dev: i2c /dev entries driver
[ 2.357271] usbcore: registered new interface driver uvcvideo
[ 2.375548] thermal thermal_zone0: failed to read out thermal zone (-110)
[ 2.383692] starfive-wdt 13070000.wdog: Heartbeat: timeout=15, count/2=180000000 (0aba9500)
[ 2.393481] Bluetooth: HCI UART driver ver 2.3
[ 2.398410] Bluetooth: HCI UART protocol H4 registered
[ 2.404778] sdhci: Secure Digital Host Controller Interface driver
[ 2.411632] sdhci: Copyright(c) Pierre Ossman
[ 2.416485] Synopsys Designware Multimedia Card Interface Driver
[ 2.423427] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.430854] jh7110-sec 16000000.crypto: Unable to request sec_m dma channel in DMA channel
[ 2.440009] jh7110-sec 16000000.crypto: Cannot initial dma chan
[ 2.446852] usbcore: registered new interface driver usbhid
[ 2.453010] usbhid: USB HID core driver
[ 2.457459] riscv-pmu-sbi: SBI PMU extension is available
[ 2.463437] riscv-pmu-sbi: 16 firmware and 4 hardware counters
[ 2.469890] riscv-pmu-sbi: Perf sampling/filtering is not supported as sscof extension is not available
[ 2.480655] usbcore: registered new interface driver snd-usb-audio
[ 2.491500] NET: Registered PF_INET6 protocol family
[ 2.498204] Segment Routing with IPv6
[ 2.502273] In-situ OAM (IOAM) with IPv6
[ 2.506732] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.513870] NET: Registered PF_PACKET protocol family
[ 2.519484] can: controller area network core
[ 2.524365] NET: Registered PF_CAN protocol family
[ 2.529675] can: raw protocol
[ 2.532949] can: broadcast manager protocol
[ 2.537586] can: netlink gateway - max_hops=1
[ 2.542679] Bluetooth: RFCOMM TTY layer initialized
[ 2.548105] Bluetooth: RFCOMM socket layer initialized
[ 2.553798] Bluetooth: RFCOMM ver 1.11
[ 2.557960] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.563821] Bluetooth: BNEP filters: protocol multicast
[ 2.569604] Bluetooth: BNEP socket layer initialized
[ 2.575139] lib80211: common routines for IEEE802.11 drivers
[ 2.581589] 9pnet: Installing 9P2000 support
[ 2.586370] Key type dns_resolver registered
[ 2.591886] Loading compiled-in X.509 certificates
[ 2.635192] @@ dev ptr:ffffffe0bfede800/1500/1
[ 2.640384] PVR_K: 1: Read BVNC 36.50.54.182 from HW device registers
[ 2.647669] PVR_K: 1: RGX Device registered BVNC 36.50.54.182 with 1 core in the system
[ 2.662497] PVR_K: 1: RGX Firmware image 'rgx.fw.36.50.54.182' loaded
[ 2.673458] PVR_K: 1: Shader binary image 'rgx.sh.36.50.54.182' loaded
[ 2.683728] [drm] Initialized pvr 1.19.6345021 20170530 for 18000000.gpu on minor 0
[ 2.693276] starfive_jh7110-pinctrl 13040000.gpio: StarFive GPIO chip registered 64 GPIOs
[ 2.703064] starfive_jh7110-pinctrl 17020000.gpio: StarFive GPIO chip registered 4 GPIOs
[ 2.712224] pl08xdmac 16008000.sec_dma: initialized 8 virtual memcpy channels
[ 2.720135] pl08xdmac 16008000.sec_dma: initialized 16 virtual slave channels
[ 2.729862] debugfs: Directory '16008000.sec_dma' with parent 'dmaengine' already present!
[ 2.739035] pl08xdmac 16008000.sec_dma: DMA: PL080 rev0 at 0x16008000 irq 23
[ 2.747068] ssp-pl022 10060000.spi: ARM PL022 driver for StarFive SoC platform, device ID: 0x00041022
[ 2.757272] ssp-pl022 10060000.spi: mapped registers from 0x0000000010060000 to (____ptrval____)
[ 2.767448] ssp-pl022 10060000.spi: Requested frequency: 10000000 Hz is unsupported,select by default 8250000 Hz
[ 2.779084] ssp-pl022 10060000.spi: will use autosuspend for runtime pm, delay 100ms
[ 2.789050] i2c 2-0045: Fixing up cyclic dependency with 295d0000.mipi
[ 2.796553] seeed_panel 2-0045: Unknown Atmel firmware revision: 0x00
[ 2.803871] tinker_ft5406 2-0038: Address = 0x38
[ 2.808988] tinker_ft5406 2-0038: width = 800, height = 480, reverse = 1
[ 2.816527] tinker_ft5406 2-0038: i2c read error, -121
[ 2.822198] tinker_ft5406 2-0038: Checking touch ic failed
[ 2.828271] tinker_ft5406: probe of 2-0038 failed with error -121
[ 2.835193] i2c 2-0019: Fixing up cyclic dependency with 295d0000.mipi
[ 2.843377] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator
[ 2.851301] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator
[ 2.975677] Goodix-TS 2-0014: i2c test failed attempt 1: -121
[ 3.015677] Goodix-TS 2-0014: i2c test failed attempt 2: -121
[ 3.055563] Goodix-TS 2-0014: I2C communication failure: -121
[ 3.062072] Goodix-TS: probe of 2-0014 failed with error -121
[ 3.068645] i2c 2-0020: Fixing up cyclic dependency with 295d0000.mipi
[ 3.077188] at24 5-0050: supply vcc not found, using dummy regulator
[ 3.085036] at24 5-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 3.094536] axp15060-regulator 5-0036: Register mipi_0p9 done! vol range:900 ~ 900 mV
[ 3.104686] axp15060-regulator 5-0036: Register hdmi_1p8 done! vol range:1800 ~ 1800 mV
[ 3.115066] axp15060-regulator 5-0036: Register sdio_vdd done! vol range:1800 ~ 1800 mV
[ 3.125423] axp15060-regulator 5-0036: Register hdmi_0p9 done! vol range:900 ~ 900 mV
[ 3.135614] axp15060-regulator 5-0036: Register vcc_3v3 done! vol range:3300 ~ 3300 mV
[ 3.145876] axp15060-regulator 5-0036: Register cpu_vdd done! vol range:500 ~ 1540 mV
[ 3.155335] i2c 6-0010: Fixing up cyclic dependency with 19800000.vin_sysctl
[ 3.163525] imx219 6-0010: supply VANA not found, using dummy regulator
[ 3.170962] imx219 6-0010: supply VDIG not found, using dummy regulator
[ 3.178363] imx219 6-0010: supply VDDL not found, using dummy regulator
[ 3.200394] imx219 6-0010: failed to read chip id 219
[ 3.206199] imx219: probe of 6-0010 failed with error -5
[ 3.212257] i2c 6-001a: Fixing up cyclic dependency with 19800000.vin_sysctl
[ 3.220434] imx708 6-001a: supply VANA1 not found, using dummy regulator
[ 3.227968] imx708 6-001a: supply VANA2 not found, using dummy regulator
[ 3.235402] imx708 6-001a: supply VDIG not found, using dummy regulator
[ 3.242798] imx708 6-001a: supply VDDL not found, using dummy regulator
[ 3.259429] imx708 6-001a: failed to read chip id 708, with error -5
[ 3.266723] imx708: probe of 6-001a failed with error -5
[ 3.274983] pcie_plda 2b000000.pcie: Failed to get power-gpio, but maybe it's always on.
[ 3.284132] pcie_plda 2b000000.pcie: host bridge /soc/pcie@2B000000 ranges:
[ 3.291874] pcie_plda 2b000000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 3.300835] pcie_plda 2b000000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000
[ 3.309821] ATR entry: 0x0940000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 3.318387] ATR entry: 0x0030000000 -> 0x0030000000 [0x0008000000] (param: 0x000000)
[ 3.326957] ATR entry: 0x0900000000 -> 0x0900000000 [0x0040000000] (param: 0x000000)
[ 3.685611] pcie_plda 2b000000.pcie: Port link up.
[ 3.691082] pcie_plda 2b000000.pcie: PCI host bridge to bus 0000:00
[ 3.698021] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.704079] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff]
[ 3.711686] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref]
[ 3.719981] pci 0000:00:00.0: [1556:1111] type 01 class 0x060400
[ 3.726629] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xffffffff 64bit pref]
[ 3.734665] pci 0000:00:00.0: supports D1 D2
[ 3.739386] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.750536] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.759529] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 3.766188] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 3.773759] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 3.783580] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.790919] pci 0000:00:00.0: BAR 0: no space for [mem size 0x100000000 64bit pref]
[ 3.799393] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x100000000 64bit pref]
[ 3.808247] pci 0000:00:00.0: BAR 8: assigned [mem 0x30000000-0x300fffff]
[ 3.815746] pci 0000:01:00.0: BAR 0: assigned [mem 0x30000000-0x30000fff 64bit]
[ 3.823827] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.829315] pci 0000:00:00.0: bridge window [mem 0x30000000-0x300fffff]
[ 3.836915] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.843162] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.849447] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x9e8 took 12247 usecs
[ 3.857859] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 3.863642] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 3.872219] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000040000000890
[ 3.882389] pcie_plda 2b000000.pcie: msi#0 address_hi 0x0 address_lo 0x190
[ 3.890476] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 3.896287] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 3.904457] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 3.912170] hub 1-0:1.0: USB hub found
[ 3.916363] hub 1-0:1.0: 1 port detected
[ 3.921811] hub 2-0:1.0: USB hub found
[ 3.926004] hub 2-0:1.0: 4 ports detected
[ 3.933064] pcie_plda 2c000000.pcie: Failed to get power-gpio, but maybe it's always on.
[ 3.942185] pcie_plda 2c000000.pcie: host bridge /soc/pcie@2C000000 ranges:
[ 3.949926] pcie_plda 2c000000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 3.958893] pcie_plda 2c000000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000
[ 3.967868] ATR entry: 0x09c0000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 3.976436] ATR entry: 0x0038000000 -> 0x0038000000 [0x0008000000] (param: 0x000000)
[ 3.984990] ATR entry: 0x0980000000 -> 0x0980000000 [0x0040000000] (param: 0x000000)
[ 4.145584] usb usb2-port2: over-current condition
[ 4.245543] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 4.305568] usb usb2-port4: over-current condition
[ 4.415730] pcie_plda 2c000000.pcie: Port link down, exit.
[ 4.435628] clk-starfive-jh7110-vout 295c0000.clock-controller: starfive JH7110 clk_vout init successfully.
[ 4.458141] clk-starfive-jh7110-isp 19810000.clock-controller: starfive JH7110 clk_isp init successfully.
[ 4.469416] dw_axi_dmac_platform 16050000.dma-controller: DesignWare AXI DMA Controller, 4 channels
[ 4.469948] hub 1-1:1.0: USB hub found
[ 4.480480] printk: console [ttyS0] disabled
[ 4.486736] hub 1-1:1.0: 4 ports detected
Domain0 Name : root
Boot HART ID : 1
DRAM: 4 GiB
PCB revision: 0xb2
In: serial
Out: serial
Err: serial
StarFive # <INTERRUPT>
