I’ve been trying to boot the debian images all day but it doesn’t work.
I’ve tried:
Debian 69 Image (with the appropriate firmware flashed to boot it)
Debian 202303 (with the latest firmware)
Debian 202302 (with firmware version 2.6.0)
Ubuntu 23 Image with the Latest Firmware
for each image I’ve waited at least 5 - 10 minutes, after that I changed the dip switch to the SD card mode, still nothing
my model its the super early bird 8GB. I’m using a Kingstom CANVAS Select Plus 32gb Class 10 as the SD Card. I don’t know what to do I’ve been trying things all day and I couldn’t get it to boot.
VisionFive 2 Debian 202303 Image support, Please update latest u-boot-spl.bin.normal.out and visionfive2_fw_payload.img binaries by following Guide: 4.3 charpter 155 before running this 202303 Debian image. this is very important.
That filesize of 3145729 (1+3145728) bytes looks wrong. If the size of the files are different the odds of the hashes/checksums matching are almost zero.
Info about VF2_v2.11.5 u-boot-spl.bin.normal.out and visionfive2_fw_payload.img are:
I repeated the test and the sha256sums do match, so the firmware is there. I still don’t know why is it not booting if it has the required firmware ;w;
I wonder if there’s a way to “convert” the sdcard.img into a debian image? since its the only one that boots sucessfully that could work or inject the same bootloader that sdcard.img has into a debian image
in theory that would only require copying some files since the sdcard.img is a linux distro
With the switches in the SD position did you try to boot from Debian 202303 image ?
It was the first image to be able to boot using bootloaders from the SD card. None of the previous images could boot from the SD card they required the boot switch to be in the factory default position FLASH.
Maybe the file you download was incomplete or corrupt, did you check the filesize and checksum/hash with the one listed on the website ?
Yes I tried that with all the images I listed on the first post xP. one difference I noticed is that the SOC gets a little bit warmer when I boot with the switches in the SD Position, but after 10 minutes it still doesn’t boot; How much time does it usually takes to boot these debian images for the first time? maybe that’s just me being inpatient xP
I just flashed this image (debian 202303) to my SD Card and updated my firmware to this new release, and I plugged it in; I’ll wait 1 hour this time to see if it does anything. I’ve also set the switches to the SD booting
I already checked the SDCard using a tool, and its not a fake card xP. I tested all of the 32gb of the card (the test took 1 hour xP) and it did not give me any error; and yes this SD Card is brand new, I bought it yesterday ago just for the starfive x3
(I edited this because the forum doesn’t allow me to reply anymore WHYY)
The only other possibility I can think of is a bad (Or possibly a fake SD card, plug “fake SD card” into your search engine of choice). The the first 838881280 bytes (Or 204805 4K blocks) are fine (the filesize of VF2_v2.11.5_sdcard.img) , but somewhere after that it is corrupt.
Is it new, or a reused card ? Have you tried a different SD card ?
Maybe it is an anti-spammer block, probably a limit on the number of posts you can create. I checked your account and it has “Joined 2 days” and 9 posts created. My guess is give it 1/6/24 hours and you will be able to post more and the limit will increase or go away over time, maybe do the tutorials might get you more posts (proves you are a human and not a bot).
You must have received mail from discobot at the beginning. http://forum.rvspace.org/t/greetings/701?u=sunwukong
Answer him and after a few question/answer games you will have a higher status in the forum in a few minutes, which will allow you more interactions.
Did you try all combinations with the dip switches? I had first inverted them (the documentation is a confusing IMO), so the device wouldn’t boot on SD.
If you have an HDMI monitor, it should show some activity within seconds.
