RISC-V is now an official Debian architecture. After Debian approves the official support architecture for RISC-V, there may be many dependencies on Debian open source projects to complete support for RISC-V in a short period of time.
The last post shows a CoreMark of 4826.254826 (or 3.22 CoreMark/MHz) for 1 HART of the JH7110: CoreMark 1.0 : 4826.254826 / GCC12.2.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
I compiled CoreMark about a month ago and got a 24% higher result by tweaking the compiler options to use all the available features of the U74-MC in the JH7110 SoC: CoreMark 1.0 : 5976.961530 / GCC12.2.0 -O2 -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3 -DPERFORMANCE_RUN=1 -lrt / Heap
CoreMark of 5977 or 3.985 CoreMark/MHz for 1 HART of the JH7110
user@starfive:~/src/coremark$ sudo cpupower frequency-set -g performance
Setting cpu: 0
Setting cpu: 1
Setting cpu: 2
Setting cpu: 3
user@starfive:~/src/coremark$ cpupower frequency-info
analyzing CPU 0:
driver: cpufreq-dt
CPUs which run at the same hardware frequency: 0 1 2 3
CPUs which need to have their frequency coordinated by software: 0 1 2 3
maximum transition latency: Cannot determine or is not supported.
hardware limits: 313 MHz - 1.50 GHz
available frequency steps: 313 MHz, 375 MHz, 417 MHz, 500 MHz, 625 MHz, 750 MHz, 1.25 GHz, 1.50 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 313 MHz and 1.50 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: 1.50 GHz (asserted by call to hardware)
user@starfive:~/src/coremark$ make PORT_DIR=linux clean
user@starfive:~/src/coremark$ make PORT_DIR=linux XCFLAGS='-march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3'
user@starfive:~/src/coremark$ ./coremark.exe
2K performance run parameters for coremark.
CoreMark Size : 666
Total ticks : 18416
Total time (secs): 18.416000
Iterations/Sec : 5973.066898
Iterations : 110000
Compiler version : GCC12.2.0
Compiler flags : -O2 -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3 -DPERFORMANCE_RUN=1 -lrt
Memory location : Please put data memory location here
(e.g. code in flash, data on heap etc)
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcmatrix : 0x1fd7
[0]crcstate : 0x8e3a
[0]crcfinal : 0x33ff
Correct operation validated. See README.md for run and reporting rules.
CoreMark 1.0 : 5973.066898 / GCC12.2.0 -O2 -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3 -DPERFORMANCE_RUN=1 -lrt / Heap
Or If I use all four HART’s:
user@starfive:~/src/coremark$ make PORT_DIR=linux XCFLAGS='-DMULTITHREAD=4 -DUSE_PTHREAD -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3'
user@starfive:~/src/coremark$ cat run1.log
CoreMark Size : 666
Total ticks : 18479
Total time (secs): 18.479000
Iterations/Sec : 23810.812273
Iterations : 440000
Compiler flags : -O2 -DMULTITHREAD=4 -DUSE_PTHREAD -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3 -DPERFORMANCE_RUN=1 -lrt
Parallel PThreads : 4
seedcrc : 0xe9f5
[0]crclist : 0xe714
[1]crclist : 0xe714
[2]crclist : 0xe714
[3]crclist : 0xe714
[1]crcmatrix : 0x1fd7
[2]crcmatrix : 0x1fd7
[3]crcmatrix : 0x1fd7
[1]crcstate : 0x8e3a
[2]crcstate : 0x8e3a
[3]crcstate : 0x8e3a
[1]crcfinal : 0x33ff
[2]crcfinal : 0x33ff
[3]crcfinal : 0x33ff
CoreMark 1.0 : 23810.812273 / GCC12.2.0 -O2 -DMULTITHREAD=4 -DUSE_PTHREAD -march=rv64imafdc_zicsr_zifencei_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -mabi=lp64d -O3 -DPERFORMANCE_RUN=1 -lrt / Heap / 4:PThreads
I got a CoreMark score of 23811 or 3.968 CoreMark/MHz using all 4 HART’s.
