串口信息如下:
U-Boot SPL 2021.10 (Sep 26 2023 - 22:53:52 +0800)
LPDDR4: 4G version: g8ad50857.
Trying to boot from SPI
OpenSBI v1.2
/ __ \ / | _ _ |
| | | | __ ___ _ __ | ( | |) || |
_/| ./ _|| ||/|/___|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : —
Platform PMU Device : —
Platform Suspend Device : —
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Sep 26 2023 - 22:53:52 +0800), Build: jenkins-github_visionfive2-18
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 4 GiB
Loading Environment from SPIFlash… SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Product full SN: VF7110B1-2310-D004E000-00001875
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:53:14
Ethernet MAC1 address: 6c:cf:39:00:53:15
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
Try booting from MMC1 …
Failed to load ‘vf2_uEnv.txt’
Warning: Input data exceeds 1048576 bytes - truncated
Info: input data size = 1048578 = 0x100002
Error: “boot2” not defined
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link down.
Device 0: unknown device
Tring booting distro …
Failed to load ‘/uEnv.txt’
Warning: defaulting to text format
Failed to load ‘/dtbs/starfive/jh7110-visionfive-v2.dtb’
fatwrite - write file into a dos filesystem
Usage:
fatwrite <dev[:part]> [ []]
- write file ‘filename’ from the address ‘addr’ in RAM
to ‘dev’ on ‘interface’
Failed to load ‘/extlinux/extlinux.conf’
Error reading config file
StarFive #
