USB转UART线的芯片型号
买了一根PL2303TA的线,只能从minicom接收的log, 但是不能发送数据,无法login。
有经验的同学可否告知能通过UART从host发送数据到开发板的线的芯片,我再买一根。CH340,FT232,PL2303HX?
最好是Linux Host可以用的
普通的ch340就可以 实测
个人建议是ft232r/ch343,ch340的驱动兼容性一直问题很大。如果想顺便玩玩裸机开发可以搞一个ft2232h
我用 PL2303TA 连 VisionFive v1 没有问题(虽然,有时候需要在 picocom 中按 Ctrl + C 退出重试好几次),但我用的是 picocom,没有用 minicom
主机上的 lsusb 信息
Bus 001 Device 008: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Action MA-8910P
在主机上使用串口访问 VisionFive 1
$ picocom -b 115200 /dev/ttyUSB0
picocom v3.1
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 115200
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
hangup is      : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
logfile is     : none
initstring     : none
exit_after is  : not set
exit is        : no
Type [C-a] [C-h] to see available commands
Terminal ready
;��[  OK  ] Finished Create Volatile Files and Directories.
         Starting Security Auditing Service...
[  OK  ] Started Security Auditing Service.
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Timeline of Snapper Snapshots.
[  OK  ] Reached target Timer Units.
         Starting Postfix Mail Transport Agent...
[  OK  ] Started Network Manager Script Dispatcher Service.
         Starting WPA Supplicant daemon...
[  OK  ] Started WPA Supplicant daemon.
[  OK  ] Reached target Preparation for Network.
Welcome to openSUSE Tumbleweed 20230130 - Kernel 6.2.0-rc7-67-default (ttyS0).
eth0:
wlan0: 10.0.0.10 fe80::ff11:7573:d5e7:fb9a
vision-five-1 login: root
Password:
Have a lot of fun...
Last login: Tue Jan 24 08:00:44 from 10.0.0.1
vision-five-1:~ # uname -a
Linux vision-five-1.domain.tld 6.2.0-rc7-67-default #1 SMP Sun Feb  5 23:03:04 UTC 2023 (225bfb7) riscv64 riscv64 riscv64 GNU/Linux
vision-five-1:~ # logout
eth0:
