Is it possible to configure Vision Five 2 as a USB 3.0 mass_storage gadget on SuperSpeed? So far, we’ve only managed to get HighSpeed.
My device is work with USB3.
Check the USB cable first.
USB3.0 port is a 9-pin port with new cable.
USB2 use old 5pin, USB3 use new 4pin in 2rd row.
Maybe the new 4pin port have a bad contact.
Sorry, but did you understand the question correctly?
The problem is not connecting the devices to VisionFive2. It works.
I create a Mass Storage Gadget from VisionFive2 using ConfigFS, then i connect VisionFive2 to PC through USB-C port and get only a high-speed USB 2.1 device. I tried two cables with 9 pins USB 3.0.
I saw information about a USB 3.0 hub in the manuals, but I did not find about the UDC 3.0 support in VisionFive2.
To be clear here, you’re trying to make the VF2 behave as a usb device, rather than the usb host?
Yes, according to the manual JH7110 USB Developing Guide paragraph 5.1
VF2’s USB-C port with usb-device-mode ?
This port is USB2.0, no 3.0 support.
